I dont have RPi 5, neither intend to spend money (at least for now) on purchasing it.
My experience with older hardware is as follows:
(1) RPi Model 4 + 64-bit Raspberry Pi OS Bookworm armv8 (2023-10-10 release)
USB is broken. As a result dump1090-fa and dump978-fa fail. I had to upgrade kernel by command sudo rpi-update to upgrade the kernel, then the usb problem was solved.
After kernel upgrade:
Linux raspberrypi 6.1.58-v8+ #1694 SMP PREEMPT Mon Oct 30 11:52:28 GMT 2023 aarch64
After the krnel upgrade, built and installed piaware ver 9.0~dev, dump1090-fa ver 9.0~dev and dump978-fa ver 9.0~dev, and all are working OK (except skyaware978 map).
https://www.flightaware.com/adsb/stats/user/abcd567#stats-76000
(2) RPi Model 4 + 64-bit DietPi OS Bookworm armv8 latest release for RPi
Linux DietPi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
No issues. Works out of box.
built and installed piaware ver 9.0~dev and dump1090-fa ver 9.0~dev, and both are working OK.
https://www.flightaware.com/adsb/stats/user/abcd567#stats-5252
(3) OrangePi PC + 32-bit Armbian_23.8.1_Orangepipc_bookworm
Linux orangepipc 6.1.53-current-sunxi #3 SMP Wed Sep 13 07:43:05 UTC 2023 armv7l GNU/Linux
https://www.flightaware.com/adsb/stats/user/abcd567#stats-6396
(4) H96Max TV Box RockChip 3318 + Armbian_23.8.1_Rk3318-box_bookworm
Linux rk3318-box 6.1.50-current-rockchip64 #3 SMP PREEMPT Wed Aug 30 14:11:13 UTC 2023 aarch64 GNU/Linux
https://www.flightaware.com/adsb/stats/user/abcd567#stats-114692
