Raspberry Pi OS Bookworm Released
Beware that it probably has broken USB at the moment:
Aside from that, we’re working on bookworm packages for piaware etc now – should be a few days.
Yes, it sure has broken USB.
After posting the opening post, I installed dump1090-fa ver 9.0~dev, on it, and it failed to use the dongle. The rtl_test also gave wierd results, sometimes dongle serial missing, sometimes wrong dongle serial.
Finally I got fedup, slipped out the test microSD (which had new release of bookworm), and restored station by slipping in the regular microSD card which I have luckily preserved.
I see that they think that is fixed (looks like a patch was lost).
I presume will be in next kernel update or grab via RPi-update now if desperate.
Thanks @obj and @paulwebsteruk .
Started rpi-update. Let us see how it goes ![]()
Click on Screenshot to See Larger Size
dump978-fa Map
dump1090-fa Map
I installed it on a Pi4 earlier today and as always with a new build, did an update/upgrade straight away. I’ve got it running from an SSD connected via USB with no problems.
That is what I also did on my Pi4, but even then the dump1090-fa failed to grab the dongle, and rtl_test sometimes gave no serial number, and sometimes gave erronous serial numbers of dongles.
Only after I ran sudo rpi-update, the error disappeared and everything started working OK (except dump978-fa’s Map skyaware98, which shows a perpetual rotating gear like wheel).
rpi-update can bring in new and not much tested stuff so nowadays it is not recommended for general use.
In the early days of RPi stuff everyone used to run as part of the general update process but not any more.
I installed it last evening. So there is a gap of many hours between @keithma’s and my installs, and with his experience it seems during this gap they have applied the missing patch.
I will now burn the image again on another spare microSD card (I have plenty of these
) and do apt update && apt upgrade, but no rpi-update. Then install dump1090-fa on it to see if the issue has been fixed now.
Wierd, so many uat messages, zero aircraft (dump978-fa ver 9.0~dev on RaspberryPi OS Bookworm)
cat /var/log/uat_reader/uat_reader.log | grep address
2023-10-15 13:00:43.412 | 23-10-15 13:00:43.412 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-404,"ground_speed":430,"metadata":{"errors":6,"received_at":1697389243.4,"rssi":-23.1},"nic":9,"north_velocity":150,"position":{"lat":42.86515,"lon":-78.4853},"pressure_altitude":36025,"true_track":290.4,"uplink_feedback":3,"utc_coupled":true,"vertical_velocity_barometric":0,"vv_src":"barometric"}
2023-10-15 13:00:44.543 | 23-10-15 13:00:44.543 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-404,"emergency":"none","emitter_category":"A2","flightplan_id":"2737","geometric_altitude":35775,"ground_speed":430,"gva":2,"metadata":{"errors":3,"received_at":1697389244.528,"rssi":-21.0},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":150,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.86599,"lon":-78.48835},"pressure_altitude":36025,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":6,"true_track":290.4,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_barometric":0,"vv_src":"barometric"}
2023-10-15 13:00:45.361 | 23-10-15 13:00:45.361 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"RAX5550","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-404,"emergency":"none","emitter_category":"A2","geometric_altitude":35775,"ground_speed":430,"gva":2,"metadata":{"errors":3,"received_at":1697389245.328,"rssi":-21.3},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":150,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.86655,"lon":-78.49038},"pressure_altitude":36025,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":40,"true_track":290.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:00:59.266 | 23-10-15 13:00:59.266 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-404,"ground_speed":430,"metadata":{"errors":2,"received_at":1697389259.245,"rssi":-23.5},"nic":9,"north_velocity":150,"position":{"lat":42.87623,"lon":-78.52598},"pressure_altitude":36025,"true_track":290.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":64,"vv_src":"barometric"}
2023-10-15 13:01:13.672 | 23-10-15 13:01:13.672 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-404,"ground_speed":430,"metadata":{"errors":5,"received_at":1697389273.655,"rssi":-24.9},"nic":9,"north_velocity":150,"position":{"lat":42.88618,"lon":-78.56259},"pressure_altitude":36025,"true_track":290.4,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:02:33.322 | 23-10-15 13:02:33.322 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-428,"ground_speed":431,"metadata":{"errors":4,"received_at":1697389353.305,"rssi":-21.0},"nic":9,"north_velocity":55,"position":{"lat":42.93457,"lon":-78.76768},"pressure_altitude":36025,"true_track":277.3,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":64,"vv_src":"barometric"}
2023-10-15 13:03:26.610 | 23-10-15 13:03:26.609 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"ground_speed":432,"metadata":{"errors":6,"received_at":1697389406.579,"rssi":-22.0},"nic":9,"north_velocity":27,"position":{"lat":42.94247,"lon":-78.91192},"pressure_altitude":36025,"true_track":273.6,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":64,"vv_src":"barometric"}
2023-10-15 13:03:28.561 | 23-10-15 13:03:28.561 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"ground_speed":432,"metadata":{"errors":5,"received_at":1697389408.546,"rssi":-22.2},"nic":9,"north_velocity":27,"position":{"lat":42.9427,"lon":-78.91735},"pressure_altitude":36025,"true_track":273.6,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":64,"vv_src":"barometric"}
2023-10-15 13:04:44.687 | 23-10-15 13:04:44.686 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-431,"emergency":"none","emitter_category":"A2","flightplan_id":"2737","geometric_altitude":35800,"ground_speed":432,"gva":2,"metadata":{"errors":2,"received_at":1697389484.669,"rssi":-19.2},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":33,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.95423,"lon":-79.12403},"pressure_altitude":36025,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":60,"true_track":274.4,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:04:48.270 | 23-10-15 13:04:48.270 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-431,"ground_speed":432,"metadata":{"errors":3,"received_at":1697389488.218,"rssi":-16.9},"nic":9,"north_velocity":32,"position":{"lat":42.95476,"lon":-79.13379},"pressure_altitude":36025,"true_track":274.2,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:04:49.339 | 23-10-15 13:04:49.339 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-431,"ground_speed":432,"metadata":{"errors":4,"received_at":1697389489.272,"rssi":-16.5},"nic":9,"north_velocity":32,"position":{"lat":42.95491,"lon":-79.1365},"pressure_altitude":36025,"true_track":274.2,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:04:54.875 | 23-10-15 13:04:54.875 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-431,"ground_speed":432,"metadata":{"errors":1,"received_at":1697389494.825,"rssi":-19.0},"nic":9,"north_velocity":32,"position":{"lat":42.95573,"lon":-79.15169},"pressure_altitude":36025,"true_track":274.2,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:04:55.693 | 23-10-15 13:04:55.693 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"RAX5550","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-431,"emergency":"none","emitter_category":"A2","geometric_altitude":35775,"ground_speed":432,"gva":2,"metadata":{"errors":3,"received_at":1697389495.671,"rssi":-18.1},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":32,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.95586,"lon":-79.15388},"pressure_altitude":36025,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":6,"true_track":274.2,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:04:56.259 | 23-10-15 13:04:56.259 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-431,"ground_speed":432,"metadata":{"errors":2,"received_at":1697389496.231,"rssi":-17.2},"nic":9,"north_velocity":32,"position":{"lat":42.95594,"lon":-79.15549},"pressure_altitude":36025,"true_track":274.2,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:04:59.031 | 23-10-15 13:04:59.030 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-431,"geometric_altitude":35775,"ground_speed":432,"metadata":{"errors":5,"received_at":1697389498.997,"rssi":-16.7},"nic":9,"north_velocity":31,"position":{"lat":42.95633,"lon":-79.16255},"pressure_altitude":36025,"true_track":274.1,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":0,"vv_src":"barometric"}
2023-10-15 13:04:59.972 | 23-10-15 13:04:59.972 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-431,"ground_speed":432,"metadata":{"errors":1,"received_at":1697389499.91,"rssi":-16.9},"nic":9,"north_velocity":31,"position":{"lat":42.95646,"lon":-79.16527},"pressure_altitude":36000,"true_track":274.1,"uplink_feedback":5,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:05:00.915 | 23-10-15 13:05:00.915 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-431,"emergency":"none","emitter_category":"A2","flightplan_id":"2737","geometric_altitude":35775,"ground_speed":432,"gva":2,"metadata":{"errors":5,"received_at":1697389500.876,"rssi":-20.5},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":31,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.95661,"lon":-79.16797},"pressure_altitude":36000,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":60,"true_track":274.1,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:05:03.937 | 23-10-15 13:05:03.937 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"geometric_altitude":35775,"ground_speed":433,"metadata":{"errors":4,"received_at":1697389503.902,"rssi":-20.1},"nic":9,"north_velocity":30,"position":{"lat":42.95704,"lon":-79.17613},"pressure_altitude":36000,"true_track":274.0,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:05:08.281 | 23-10-15 13:05:08.281 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"geometric_altitude":35775,"ground_speed":433,"metadata":{"errors":6,"received_at":1697389508.247,"rssi":-19.4},"nic":9,"north_velocity":30,"position":{"lat":42.95764,"lon":-79.18808},"pressure_altitude":36000,"true_track":274.0,"uplink_feedback":5,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:05:09.286 | 23-10-15 13:05:09.285 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"geometric_altitude":35775,"ground_speed":433,"metadata":{"errors":4,"received_at":1697389509.269,"rssi":-19.9},"nic":9,"north_velocity":30,"position":{"lat":42.95779,"lon":-79.1908},"pressure_altitude":36000,"true_track":274.0,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_barometric":0,"vv_src":"barometric"}
2023-10-15 13:05:10.483 | 23-10-15 13:05:10.482 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"ground_speed":433,"metadata":{"errors":5,"received_at":1697389510.452,"rssi":-19.6},"nic":9,"north_velocity":30,"position":{"lat":42.95794,"lon":-79.19407},"pressure_altitude":36000,"true_track":274.0,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-64,"vv_src":"barometric"}
2023-10-15 13:05:18.787 | 23-10-15 13:05:18.787 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"ground_speed":433,"metadata":{"errors":5,"received_at":1697389518.717,"rssi":-19.4},"nic":9,"north_velocity":29,"position":{"lat":42.95905,"lon":-79.21634},"pressure_altitude":36000,"true_track":273.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":64,"vv_src":"barometric"}
2023-10-15 13:05:24.511 | 23-10-15 13:05:24.511 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"geometric_altitude":35775,"ground_speed":432,"metadata":{"errors":5,"received_at":1697389524.475,"rssi":-21.2},"nic":9,"north_velocity":28,"position":{"lat":42.95983,"lon":-79.23211},"pressure_altitude":36000,"true_track":273.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":64,"vv_src":"barometric"}
2023-10-15 13:05:25.455 | 23-10-15 13:05:25.455 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"geometric_altitude":35775,"ground_speed":432,"metadata":{"errors":6,"received_at":1697389525.408,"rssi":-18.9},"nic":9,"north_velocity":28,"position":{"lat":42.95995,"lon":-79.23484},"pressure_altitude":36000,"true_track":273.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":0,"vv_src":"barometric"}
2023-10-15 13:05:28.350 | 23-10-15 13:05:28.349 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-432,"ground_speed":432,"metadata":{"errors":6,"received_at":1697389528.283,"rssi":-18.3},"nic":9,"north_velocity":28,"position":{"lat":42.96032,"lon":-79.24243},"pressure_altitude":36025,"true_track":273.7,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":0,"vv_src":"barometric"}
2023-10-15 13:05:51.561 | 23-10-15 13:05:51.561 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-438,"geometric_altitude":35500,"ground_speed":438,"metadata":{"errors":6,"received_at":1697389551.548,"rssi":-20.1},"nic":9,"north_velocity":19,"position":{"lat":42.96317,"lon":-79.30584},"pressure_altitude":35750,"true_track":272.5,"uplink_feedback":6,"utc_coupled":true,"vertical_velocity_barometric":-1216,"vv_src":"barometric"}
2023-10-15 13:05:53.008 | 23-10-15 13:05:53.008 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-439,"ground_speed":439,"metadata":{"errors":6,"received_at":1697389552.993,"rssi":-20.6},"nic":9,"north_velocity":16,"position":{"lat":42.9633,"lon":-79.3097},"pressure_altitude":35725,"true_track":272.1,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-1280,"vv_src":"barometric"}
2023-10-15 13:06:01.883 | 23-10-15 13:06:01.883 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-443,"ground_speed":443,"metadata":{"errors":0,"received_at":1697389561.821,"rssi":-17.3},"nic":9,"north_velocity":-7,"position":{"lat":42.96343,"lon":-79.3347},"pressure_altitude":35550,"true_track":269.1,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":-1152,"vv_src":"barometric"}
2023-10-15 13:06:02.512 | 23-10-15 13:06:02.512 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-443,"geometric_altitude":35275,"ground_speed":443,"metadata":{"errors":0,"received_at":1697389562.469,"rssi":-17.2},"nic":9,"north_velocity":-8,"position":{"lat":42.96341,"lon":-79.33637},"pressure_altitude":35525,"true_track":269.0,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":-1152,"vv_src":"barometric"}
2023-10-15 13:06:05.594 | 23-10-15 13:06:05.593 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"RAX5550","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-444,"emergency":"none","emitter_category":"A2","geometric_altitude":35225,"ground_speed":444,"gva":2,"metadata":{"errors":1,"received_at":1697389565.544,"rssi":-18.0},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-14,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.96326,"lon":-79.34474},"pressure_altitude":35475,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":5,"true_track":268.2,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":-1216,"vv_src":"barometric"}
2023-10-15 13:06:06.849 | 23-10-15 13:06:06.849 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-444,"ground_speed":444,"metadata":{"errors":1,"received_at":1697389566.789,"rssi":-17.8},"nic":9,"north_velocity":-15,"position":{"lat":42.96317,"lon":-79.34809},"pressure_altitude":35450,"true_track":268.1,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-1216,"vv_src":"barometric"}
2023-10-15 13:06:32.333 | 23-10-15 13:06:32.333 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-453,"ground_speed":454,"metadata":{"errors":2,"received_at":1697389592.295,"rssi":-18.3},"nic":9,"north_velocity":-33,"position":{"lat":42.95998,"lon":-79.4204},"pressure_altitude":34800,"true_track":265.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-1408,"vv_src":"barometric"}
2023-10-15 13:06:35.478 | 23-10-15 13:06:35.478 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-453,"ground_speed":454,"metadata":{"errors":3,"received_at":1697389595.41,"rssi":-19.2},"nic":9,"north_velocity":-34,"position":{"lat":42.95948,"lon":-79.42954},"pressure_altitude":34750,"true_track":265.7,"uplink_feedback":3,"utc_coupled":true,"vertical_velocity_barometric":-1152,"vv_src":"barometric"}
2023-10-15 13:07:28.390 | 23-10-15 13:07:28.390 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-461,"ground_speed":461,"metadata":{"errors":3,"received_at":1697389648.361,"rssi":-21.6},"nic":9,"north_velocity":-23,"position":{"lat":42.9524,"lon":-79.58138},"pressure_altitude":33775,"true_track":267.1,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_barometric":-1152,"vv_src":"barometric"}
2023-10-15 13:07:35.939 | 23-10-15 13:07:35.939 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"RAX5550","capability_codes":{"es_in":true,"tcas_operational":false,"uat_in":true},"east_velocity":-460,"emergency":"none","emitter_category":"A2","geometric_altitude":33300,"ground_speed":460,"gva":2,"metadata":{"errors":6,"received_at":1697389655.885,"rssi":-19.7},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":-22,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.95161,"lon":-79.60339},"pressure_altitude":33650,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":true,"transmit_mso":25,"true_track":267.3,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_barometric":-1088,"vv_src":"barometric"}
2023-10-15 13:07:37.512 | 23-10-15 13:07:37.511 [I] {"address":"a7049a","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-460,"ground_speed":460,"metadata":{"errors":2,"received_at":1697389657.459,"rssi":-20.1},"nic":9,"north_velocity":-22,"position":{"lat":42.95146,"lon":-79.60803},"pressure_altitude":33625,"true_track":267.3,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_barometric":-1024,"vv_src":"barometric"}
2023-10-15 13:43:37.982 | 23-10-15 13:43:37.982 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-26,"ground_speed":369,"metadata":{"errors":2,"received_at":1697391817.947,"rssi":-20.0},"nic":9,"north_velocity":369,"position":{"lat":42.95605,"lon":-79.32045},"pressure_altitude":19050,"true_track":356.0,"uplink_feedback":2,"utc_coupled":true,"vertical_velocity_geometric":-1664,"vv_src":"geometric"}
2023-10-15 13:43:40.248 | 23-10-15 13:43:40.247 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-26,"geometric_altitude":18550,"ground_speed":368,"metadata":{"errors":7,"received_at":1697391820.22,"rssi":-21.7},"nic":9,"north_velocity":368,"position":{"lat":42.96013,"lon":-79.32086},"pressure_altitude":19000,"true_track":356.0,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1664,"vv_src":"geometric"}
2023-10-15 13:43:49.933 | 23-10-15 13:43:49.933 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":true,"uat_in":true},"east_velocity":-26,"emergency":"none","emitter_category":"A2","flightplan_id":"0725","geometric_altitude":18275,"ground_speed":367,"gva":2,"metadata":{"errors":3,"received_at":1697391829.917,"rssi":-20.6},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":367,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":42.97643,"lon":-79.32245},"pressure_altitude":18725,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":false,"transmit_mso":24,"true_track":355.9,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-1856,"vv_src":"geometric"}
2023-10-15 13:44:47.311 | 23-10-15 13:44:47.310 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":true,"uat_in":true},"east_velocity":-27,"emergency":"none","emitter_category":"A2","flightplan_id":"0725","geometric_altitude":16425,"ground_speed":366,"gva":2,"metadata":{"errors":4,"received_at":1697391887.251,"rssi":-20.2},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":365,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.07396,"lon":-79.332},"pressure_altitude":16850,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":false,"transmit_mso":48,"true_track":355.8,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-1920,"vv_src":"geometric"}
2023-10-15 13:45:33.681 | 23-10-15 13:45:33.681 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-25,"geometric_altitude":14925,"ground_speed":350,"metadata":{"errors":5,"received_at":1697391933.645,"rssi":-21.9},"nic":9,"north_velocity":350,"position":{"lat":43.15082,"lon":-79.33972},"pressure_altitude":15375,"true_track":355.9,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-1856,"vv_src":"geometric"}
2023-10-15 13:45:50.540 | 23-10-15 13:45:50.539 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-25,"ground_speed":344,"metadata":{"errors":6,"received_at":1697391950.476,"rssi":-19.6},"nic":9,"north_velocity":344,"position":{"lat":43.17777,"lon":-79.3424},"pressure_altitude":14875,"true_track":355.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1792,"vv_src":"geometric"}
2023-10-15 13:46:06.711 | 23-10-15 13:46:06.711 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-25,"ground_speed":338,"metadata":{"errors":0,"received_at":1697391966.687,"rssi":-19.7},"nic":9,"north_velocity":338,"position":{"lat":43.20331,"lon":-79.34496},"pressure_altitude":14350,"true_track":355.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1792,"vv_src":"geometric"}
2023-10-15 13:46:11.430 | 23-10-15 13:46:11.430 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-25,"ground_speed":336,"metadata":{"errors":0,"received_at":1697391971.403,"rssi":-19.1},"nic":9,"north_velocity":336,"position":{"lat":43.21047,"lon":-79.34569},"pressure_altitude":14225,"true_track":355.7,"uplink_feedback":2,"utc_coupled":true,"vertical_velocity_geometric":-1792,"vv_src":"geometric"}
2023-10-15 13:46:15.457 | 23-10-15 13:46:15.457 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-25,"geometric_altitude":13650,"ground_speed":335,"metadata":{"errors":3,"received_at":1697391975.403,"rssi":-19.6},"nic":9,"north_velocity":335,"position":{"lat":43.21667,"lon":-79.34631},"pressure_altitude":14100,"true_track":355.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-1728,"vv_src":"geometric"}
2023-10-15 13:46:16.777 | 23-10-15 13:46:16.777 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-25,"ground_speed":334,"metadata":{"errors":1,"received_at":1697391976.729,"rssi":-21.0},"nic":9,"north_velocity":334,"position":{"lat":43.21884,"lon":-79.34652},"pressure_altitude":14075,"true_track":355.7,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1728,"vv_src":"geometric"}
2023-10-15 13:46:29.736 | 23-10-15 13:46:29.735 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":true,"uat_in":true},"east_velocity":-24,"emergency":"none","emitter_category":"A2","flightplan_id":"0725","geometric_altitude":13225,"ground_speed":327,"gva":2,"metadata":{"errors":3,"received_at":1697391989.72,"rssi":-18.6},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":327,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.23875,"lon":-79.34856},"pressure_altitude":13675,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":false,"transmit_mso":5,"true_track":355.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1728,"vv_src":"geometric"}
2023-10-15 13:46:32.943 | 23-10-15 13:46:32.943 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-24,"ground_speed":325,"metadata":{"errors":4,"received_at":1697391992.914,"rssi":-20.3},"nic":9,"north_velocity":325,"position":{"lat":43.24356,"lon":-79.34903},"pressure_altitude":13600,"true_track":355.8,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1728,"vv_src":"geometric"}
2023-10-15 13:46:57.546 | 23-10-15 13:46:57.546 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-28,"ground_speed":307,"metadata":{"errors":1,"received_at":1697392017.513,"rssi":-20.2},"nic":9,"north_velocity":306,"position":{"lat":43.27944,"lon":-79.3527},"pressure_altitude":12900,"true_track":354.8,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-1792,"vv_src":"geometric"}
2023-10-15 13:46:58.804 | 23-10-15 13:46:58.804 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-30,"geometric_altitude":12375,"ground_speed":306,"metadata":{"errors":0,"received_at":1697392018.743,"rssi":-19.2},"nic":9,"north_velocity":305,"position":{"lat":43.28113,"lon":-79.35292},"pressure_altitude":12850,"true_track":354.4,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1728,"vv_src":"geometric"}
2023-10-15 13:47:02.450 | 23-10-15 13:47:02.450 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-39,"ground_speed":304,"metadata":{"errors":3,"received_at":1697392022.39,"rssi":-18.2},"nic":9,"north_velocity":302,"position":{"lat":43.2862,"lon":-79.35371},"pressure_altitude":12750,"true_track":352.6,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1792,"vv_src":"geometric"}
2023-10-15 13:47:06.983 | 23-10-15 13:47:06.983 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","callsign":"FEX150","capability_codes":{"es_in":true,"tcas_operational":true,"uat_in":true},"east_velocity":-64,"emergency":"none","emitter_category":"A2","geometric_altitude":12150,"ground_speed":300,"gva":2,"metadata":{"errors":6,"received_at":1697392026.952,"rssi":-18.8},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":294,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.29255,"lon":-79.35519},"pressure_altitude":12600,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":false,"transmit_mso":32,"true_track":347.7,"uplink_feedback":1,"utc_coupled":true,"vertical_velocity_geometric":-1728,"vv_src":"geometric"}
2023-10-15 13:47:10.821 | 23-10-15 13:47:10.820 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-87,"ground_speed":298,"metadata":{"errors":1,"received_at":1697392030.796,"rssi":-20.2},"nic":9,"north_velocity":286,"position":{"lat":43.29763,"lon":-79.35704},"pressure_altitude":12500,"true_track":343.1,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1600,"vv_src":"geometric"}
2023-10-15 13:47:12.771 | 23-10-15 13:47:12.771 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-99,"ground_speed":297,"metadata":{"errors":2,"received_at":1697392032.75,"rssi":-19.6},"nic":9,"north_velocity":281,"position":{"lat":43.30025,"lon":-79.35822},"pressure_altitude":12450,"true_track":340.6,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1600,"vv_src":"geometric"}
2023-10-15 13:47:17.428 | 23-10-15 13:47:17.428 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","capability_codes":{"es_in":true,"tcas_operational":true,"uat_in":true},"east_velocity":-123,"emergency":"none","emitter_category":"A2","flightplan_id":"0725","geometric_altitude":11875,"ground_speed":294,"gva":2,"metadata":{"errors":7,"received_at":1697392037.355,"rssi":-16.7},"mops_version":2,"nac_p":10,"nac_v":2,"nic":9,"nic_baro":1,"nic_supplement":false,"north_velocity":268,"operational_modes":{"atc_services":false,"ident_active":false,"tcas_ra_active":false},"position":{"lat":43.30609,"lon":-79.36148},"pressure_altitude":12325,"sda":2,"sil":3,"sil_supplement":"per_hour","single_antenna":false,"transmit_mso":14,"true_track":335.3,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1536,"vv_src":"geometric"}
2023-10-15 13:47:18.748 | 23-10-15 13:47:18.748 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-129,"ground_speed":294,"metadata":{"errors":0,"received_at":1697392038.7,"rssi":-15.1},"nic":9,"north_velocity":265,"position":{"lat":43.30783,"lon":-79.3626},"pressure_altitude":12300,"true_track":334.0,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1536,"vv_src":"geometric"}
2023-10-15 13:47:19.755 | 23-10-15 13:47:19.754 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-135,"geometric_altitude":11800,"ground_speed":293,"metadata":{"errors":0,"received_at":1697392039.732,"rssi":-14.8},"nic":9,"north_velocity":261,"position":{"lat":43.30903,"lon":-79.36345},"pressure_altitude":12275,"true_track":332.7,"uplink_feedback":0,"utc_coupled":true,"vertical_velocity_geometric":-1536,"vv_src":"geometric"}
2023-10-15 13:47:20.321 | 23-10-15 13:47:20.320 [I] {"address":"c05530","address_qualifier":"adsb_icao","airground_state":"airborne","east_velocity":-137,"ground_speed":293,"metadata":{"errors":0,"received_at":1697392040.311,"rssi":-18.2},"nic":9,"north_velocity":260,"position":{"lat":43.30976,"lon":-79.36397},"pressure_altitude":12250,"true_track":332.2,"uplink_feedback":7,"utc_coupled":true,"vertical_velocity_geometric":-1536,"vv_src":"geometric"}
Managed to get 64 bit bookworm to work with a Mode S Beast, GPS hat(via GSPD) and graphs1090 with one minor issue. Beast Splitter wouldn’t compile on a 1GB RPI, I had to swap it for a 2GB(I seam to recall having this issue in the past). I suppose I could have just installed the package, as it is available.
Yeah, beast-splitter and dump978-fa both use Boost, and Boost is very memory-hungry when compiling. You could try building with DEB_BUILD_OPTIONS=noopt as a last resort (I’m not sure if that sets CXXFLAGS correctly, though, I should probably check that works as expected)
(1) @jonhawkes2030 : Did yiu run sudo rpi-update, or succeeded without it?
(2) An easier option is to add a 1.5 GB swap file in the Raspberrypi OS to increase total memory to 2.5 GB (1 GB ram + 1.5 GB swap). This is possible since microSD cards >= 8 GB have enough spare space to do it.
I have tried this and it worjs fine. After building the dump978 and beast splitter packages, this swap file can be deleted to free the space on microSD card.
Please see following post where I have given detailed “How-to” to add a swap file to build dump978-fa with a Pi having only 1 GB ram.
I notice on the Raspberry Pi forums that they do not recommend upgrading from Bullseye to Bookworm but rather to start over with a new Bookworm image. Are they serious ? I don’t want to reinstall everything I have on the RPi. I would think others are in the same situation.
The reason they recommend that is because between major version of distros like Debian there are a lot of changes of libraries and dependencies. It’s possible to upgrade from one to the other, but you might run in to unexpected problems resulting from that and they can be difficult to troubleshoot.
If you want to try that, I’d recommend taking an image of your SD card prior, so you can go back to a known working system if you do have problems. If everything works, then you can carry on as normal, but you have the option to go back to how it was if not.
I do backups fairly regularly, so yes I could just go back and use an SD card with Bullseye on it. However it’s nice to be using the latest and greatest version in the software world.
So, upgrading from Bullseye to Bookworm is not just a matter of a simple sudo apt full-upgrade . There’s several steps involved according to this link: https://gist.github.com/jauderho/6b7d42030e264a135450ecc0ba521bd8
Has anyone done this yet?
Thanks.
Yes, I have done this last month, successfully and twice
No issues at all.
NOTE: It was not an upgrade of Bullseye with piaware and dump1990-fa already installed, as is your case. I wrote a fresh image Bullseye to microSD card, then upgraded it to Bookworm, and only after upgrade of OS, built and installed piaware and dump1090-fa packages from source code.
Ok, so I would just start at step 3 do 3.1 and 3.2 and skip all the rest of the steps ( step 5, 5.1, 5.2 step 6, 6.1, 6.2).
