That Youtube site refers to uploader’s site http://fuzzthepiguy.tech/gain-control/
In above site it uses following installation script for piaware ver 5.0 from my Github site
Upon release of piaware ver 6.0, I added [outdated] to the name of ver 5.0 scripts, and posted new version-less scripts which work for piaware versions 6 and above. It works OK on ver 7.2 also. If you want to install it, use the current script from here:
Maximize the Browser or increase the width of the table.
EDIT:
The above mentioned problem is NOT caused by embedding Set-Gain.
I have checked another Pi’s Skyaware map which does not have Set-Gain button embedded. That browser also has same problem when Browser width is reduced. (Please see screenshot below).
My Google Chrome also facing a minor issue. Please refer to the screenshot for detail. is it the browser issue as well? (With the RED BOX highlighted) I tried on Firefox and it seems look normal.
I would like to add this to mine. Where would I enter the command? Do I need to get to the pi@piaware prompt or from any command line window prompt? I’m not at all familiar with linux so I’ll need step by step instructions. I just upgraded to 7.2 and it took me quite awhile to get it up and running. Since then, I’m only seeing a little less than 1/2 of my normal daily totals. I don’t know what the problem is but I’d like to start off looking at the gain settings.
