Piaware 3.7.2 insall on top of stretch
I installed piaware 3.7.2. I did not want to install the sd card version. I already have a piaware setup via sd card install and all works well the last 3 years. The issue I am running into is flightaware status page will not load via the pi’s ip address. I have to go to ip:8080 just to get to my dump1090 page. Is there a way to fix this or is it only an option with the sd card image?
Any help on this would be great.
Thank you all
-Mark
The top level status page is provided by the piaware-web package which is usually only installed on piaware sdcard images. You could try installing that package on a non-piaware-sdcard image but YMMV.
Successfully installed piaware-web on Armbian Buster / OrangePiPC
pi@orangepipc:~$ uname -a
Linux orangepipc 4.19.62-sunxi #5.92 SMP Wed Jul 31 22:07:23 CEST 2019 armv7l GNU/Linux
pi@orangepipc:~$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
pi@orangepipc:~$ apt-cache policy piaware
piaware:
  Installed: 3.7.2
  Candidate: 3.7.2
pi@orangepipc:~$ sudo apt-get install piaware-web
That did it. Thank you for this. Now I just need to wait for UAT 978 supprot for Buster.
cheers
-Mark
@gottdestodes6661
I have installed dump978-fa 3.7.2, dump1090-fa 3.7.2, and piaware 3.7.2 on Armbian Buster/OrangePiPC using package install.
The dump1090-fa map shows lot of planes (Station 76000).
I never saw a plane on dump978 map or on graphs by @wiedehopf, although the command sudo systemctl status dump978-fa and sudo systemctl status piaware show OK.
I have used following method, as described on
https://flightaware.com/adsb/piaware/install:
wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.7.2_all.deb
sudo dpkg -i piaware-repository_3.7.2_all.deb
sudo apt-get update
sudo apt-get install dump1090-fa
sudo apt-get install dump978-fa
This is the error I receive when I try to sudo apt-get install dump978-fa
dump978-fa : Depends: libsoapysdr0.5-2 but it is not installable
Recommends: skyaware978 but it is not going to be installed
Recommends: soapysdr-module-rtlsdr but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Please see this post:
So would you suggest I do the whole install over again or just change the source to stretch and install dump979 then go back to buster?
Thank you for all this help.
IF your dump1090-fa and piaware are working ok, then no need to install them again.
(verify by sudo systemctl status dump1090-fa and sudo systemctl status piaware)
In this case do following:
  1. Change source to stretch (step 3)
  2. install dump978-fa and skyaware978 (step 5)
  3. Change source back to buster (step 6)
  4. Configure (step 7)
Compiling dump978-fa for buster is a better approach.
