Piaware 3.7.1 'couldn't open socket: connection refused'
My setup is OrangePi Zero running Armbian with Dump1090-mutability with piaware, using FlightAware ProStick Plus v1.0.
I had no issues with an older version (3.6.3). In fact the disk image still works:
Screenshot%20from%202019-06-21%2012-05-25
However, on upgrading to latest version (3.7.1), I get:
got 'couldn't open socket: connection refused':
Screenshot%20from%202019-06-21%2012-07-28
Is this a bug/regression or I need to do something to fix this…
Thanks!
Normal output.
The error will hopefully be cleaned up at some point to reduce confusion.
I forgot to add… I’m not able to feed to FlightAware, most probably due to this reason.
As in, while setting up a new receiver I couldn’t claim it (by visiting PiAware - Claim and Link a Brand New PiAware Ground Station - FlightAware) - I get “No receiver found” or something similar.
I’m almost sure that error is no related to your problems.
This is my output:
PiAware master process (piaware) is running with pid 685.
PiAware ADS-B client (faup1090) is running with pid 7661.
PiAware ADS-B UAT client (faup978) is not running.
PiAware mlat client (fa-mlat-client) is running with pid 28699.
Local ADS-B receiver (dump1090-fa) is running with pid 7628.
dump1090-fa (pid 7628) is listening for connections on port 30005.
no program appears to be listening for connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
Your feeder ID is
Let’s check the output for this command, should tell us more:
sudo journalctl -u piaware | grep -v 'reported location\|--lat\|feeder ID'
Could it be you can’t claim the receiver because it’s already associated with your account?
It will remember the feeder-id when upgrading to a new version.
https://flightaware.com/adsb/stats/user/kanchudeep
Is the feeder not in the dropdown menu?
The more likely problem might be that you are not receiving any aircraft?
Have you checked the local map? http://pi/dump1090
Okay… Let me check…
Thanks!
I was wondering if any one had figured out this issue? I had to replace my router so my wireless name and password changed. I was able to get my piaware to piaware-config setup correctly, but when I restarted piaware I got the same status message:
pi@piaware:~ $ piaware-status
PiAware master process (piaware) is running with pid 761.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for ES connections on port 30005.
got ‘couldn’t open socket: connection refused’
I would appreciate any information some one could supply.
This is the underlying problem.
