Hi,
I have an issue with Piaware 2.x with multiple dump1090’s. MLAT doesn’t work.
My setup uses 3 raspberry pi’s running their own dump1090 with their own receiver and antenna. Only one is running Piaware. This is mij hostlist:
Host Name, IP Address, services:
ted1090-4, 192.168.11.8, dump1090 & piaware
ted1090-2, 192.168.11.34, dump1090
ted1090-3, 192.168.11.32, dump1090
I have updated my Piaware en dump1090 to the latest versions. I was running Piaware 1.20-1 and dump1090 1.1-1.
pi@ted1090-4 $ dpkg -l | grep piaware
ii piaware 2.1-1 armhf Open Aviation Data Exchange Protocol for ADS-B FlightFeeders
pi@ted1090-4 $ dpkg -l | grep dump
ii dump1090 1.2-2 armhf ADS-B Ground Station System for RTL-SDR
The raspberry pi with Piaware (host name ted1090-4, IP 192.168.11.8 ) is listening to his own local dump1090 and also to the other dump1090’s on the other 2 raspberry’s using netcat. I used these command’s to connect them:
pi@ted1090-4 $ nc -d 192.168.11.34 30005 | nc 127.0.0.1 30004 &
pi@ted1090-4 $ nc -d 192.168.11.32 30005 | nc 127.0.0.1 30004 &
Netstat shows how the hosts and ports are connected:
pi@ted1090-4 $ netstat
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 ted1090-4.bachstr:51252 ted1090-2.bachstr:30005 ESTABLISHED
tcp 0 0 localhost:50809 localhost:30002 ESTABLISHED
tcp 0 1897 localhost:30005 localhost:40219 ESTABLISHED
tcp 23 0 localhost:40219 localhost:30005 ESTABLISHED
tcp 0 0 ted1090-4.bachstr:43948 ted1090-3.bachstr:30005 ESTABLISHED
tcp 278 0 localhost:30004 localhost:55368 ESTABLISHED
tcp 0 0 localhost:30002 localhost:50809 ESTABLISHED
tcp 0 0 localhost:55381 localhost:30004 ESTABLISHED
I noticed that MLAT was enabled by default. After the update I got these errors in the /tmp/piaware.out log every 30 seconds:
07/09/2015 10:01:29 mlat(2607): Input connected to localhost:30005
07/09/2015 10:01:29 mlat(2607): Problem reading receiver messages: Out of range timestamp seen (last 103288483998, now 100657028850)
07/09/2015 10:01:29 mlat(2607): Ensure that only one receiver is feeding data to this client.
07/09/2015 10:01:29 mlat(2607): A single multilateration client cannot handle data from multiple receivers.
07/09/2015 10:01:29 mlat(2607): Lost connection to localhost:30005
07/09/2015 10:01:29 mlat(2607): Reconnecting in 30.0 seconds
Can I really not use MLAT because I am using multiple dump1090’s to feed one Piaware?
But updates from dump1090 to FlightAware are still send normaly every 5 minutes:
07/09/2015 10:03:49 5826 msgs recv'd from dump1090 (2809 in last 5m); 5826 msgs sent to FlightAware
The errors stopped after I disabled MLAT from the control panel at the flightaware website and restarted Piaware.
After enabling MLAT again and restart Piaware the errors came back:
07/09/2015 10:08:49 3017 msgs recv'd from dump1090 (2742 in last 5m); 3017 msgs sent to FlightAware
07/09/2015 10:13:49 5826 msgs recv'd from dump1090 (2809 in last 5m); 5826 msgs sent to FlightAware
07/09/2015 10:14:19 manual update (user-initiated via their flightaware control page) requested by adept server
07/09/2015 10:14:19 manualUpdate in adept config is enabled, allowing update
07/09/2015 10:14:19 performing manual update, action: restart_piaware
07/09/2015 10:14:19 update request complete
07/09/2015 10:14:19 restarting piaware. hopefully i'll be right back...
Stopping piaware server: piaware07/09/2015 10:14:19 piaware (process 2550) is shutting down because it received a shutdown signal (SIGTERM) from the system...
07/09/2015 10:14:19 removing pidfile /var/run/piaware.pid
07/09/2015 10:14:19 piaware (process 2550) is exiting...
Starting piaware server: piaware.
07/09/2015 10:14:22 ****************************************************
07/09/2015 10:14:22 piaware version 2.1-1 is running, process ID 2596
07/09/2015 10:14:22 your system info is: Linux ted1090-4 3.18.11-v7+ #781 SMP PREEMPT Tue Apr 21 18:07:59 BST 2015 armv7l GNU/Linux
07/09/2015 10:14:22 connecting to FlightAware piaware.flightaware.com/1200
07/09/2015 10:14:23 FlightAware server SSL certificate validated
07/09/2015 10:14:23 encrypted session established with FlightAware
07/09/2015 10:14:23 autoUpdate in adept config is enabled, allowing update
07/09/2015 10:14:23 manualUpdate in adept config is enabled, allowing update
07/09/2015 10:14:23 multilateration support enabled (use piaware-config to disable)
07/09/2015 10:14:23 ADS-B data program 'dump1090' is listening on port 30005, so far so good
07/09/2015 10:14:23 Starting faup1090: /usr/bin/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --lat 52.086 --lon 5.089
07/09/2015 10:14:23 Started faup1090 (pid 2605) to connect to dump1090
07/09/2015 10:14:23 logged in to FlightAware as user tedsluis
07/09/2015 10:14:23 multilateration data requested, enabling mlat client
07/09/2015 10:14:23 Starting multilateration client: /usr/lib/fa-mlat-client/fa-mlat-client --input-connect localhost:30005 --results beast,connect,localhost:30004 --udp-transport 70.42.6.194:7994:2173717795
07/09/2015 10:14:24 piaware received a message from dump1090!
07/09/2015 10:14:24 piaware has successfully sent several msgs to FlightAware!
07/09/2015 10:14:24 mlat(2607): fa-mlat-client 0.2.2 starting up
07/09/2015 10:14:24 mlat(2607): Using UDP transport to 70.42.6.194:7994
07/09/2015 10:14:24 mlat(2607): Input connected to localhost:30005
07/09/2015 10:14:24 mlat(2607): Problem reading receiver messages: Out of range timestamp seen (last 96032748744, now 93401435784)
07/09/2015 10:14:24 mlat(2607): Ensure that only one receiver is feeding data to this client.
07/09/2015 10:14:24 mlat(2607): A single multilateration client cannot handle data from multiple receivers.
07/09/2015 10:14:24 mlat(2607): Lost connection to localhost:30005
07/09/2015 10:14:24 mlat(2607): Reconnecting in 30.0 seconds
07/09/2015 10:14:25 mlat(2607): Beast-format results connection with localhost:30004: connection established
07/09/2015 10:14:53 282 msgs recv'd from dump1090; 282 msgs sent to FlightAware
07/09/2015 10:14:55 mlat(2607): Input connected to localhost:30005
07/09/2015 10:14:55 mlat(2607): Problem reading receiver messages: Out of range timestamp seen (last 96398421150, now 93767750544)
07/09/2015 10:14:55 mlat(2607): Ensure that only one receiver is feeding data to this client.
07/09/2015 10:14:55 mlat(2607): A single multilateration client cannot handle data from multiple receivers.
07/09/2015 10:14:55 mlat(2607): Lost connection to localhost:30005
07/09/2015 10:14:55 mlat(2607): Reconnecting in 30.0 seconds
07/09/2015 10:15:22 server is sending alive messages; we will expect them
07/09/2015 10:15:25 mlat(2607): Input connected to localhost:30005
07/09/2015 10:15:25 mlat(2607): Problem reading receiver messages: Out of range timestamp seen (last 96759375834, now 94128057990)
Does this works as designed? Am I doing something wrong? Or will this be fixed in th future?
Any help would be very welcome!
Ted
http://flightaware.com/adsb/stats/user/tedsluis#stats-7002
