Please bear with me - first time posting here, I’ve run piaware on a Pi2 since October 2015 with no issues that I wasn’t able to figure out via the forum or a google search. However, I now have an issue and I can’t find any solutions.
I just downloaded and installed the 3.1.0.img on an micro SD card to use on a Pi3 - knowing I wanted to use the built in wireless I edited the piaware-config.txt file per the instructions so it looks like this:
# This file configures the Piaware sdcard image
# configuration. Whenever the system boots, this
# file is read and its contents are used to
# configure the system.
# Lines beginning with a '#' are comment lines
# and are ignored. Blank lines are also ignored.
# All other lines specify configuration settings.
# WIRED NETWORK CONFIGURATION
# Should piaware use the wired ethernet port
# for network access?
wired-network yes
# Wired network configuration:
# Most networks will use DHCP
wired-type dhcp
# Alternatively, a static address configuration
# can be provided; set "wired-type" to static to use this.
wired-address 192.168.1.10
wired-netmask 255.255.255.0
wired-broadcast 192.168.1.255
wired-gateway 192.168.1.254
wired-nameservers 8.8.8.8 8.8.4.4
# WIRELESS NETWORK CONFIGURATION
# Should piaware use a wifi adaptor
# for network access? You will need to attach
# a supported USB wifi adaptor for this to work.
# change this to "yes" to enable wifi
wireless-network yes
# Wifi SSID and password.
# This should be changed to match your wireless
# network SSID and, for networks that require
# a passphrase, the passphrase.
wireless-ssid FiOS-DD69J
wireless-password mypasswordhere
# Wifi network configuration:
wireless-type dhcp
# can be provided; set "wireless-type" to static to use this.
wireless-address 192.168.1.10
wireless-netmask 255.255.255.0
wireless-broadcast 192.168.1.255
wireless-gateway 192.168.1.254
wireless-nameservers 8.8.8.8 8.8.4.4
# RECEIVER CONFIGURATION
# Type of ADS-B receiver to use with piaware.
# This is used when configuring dump1090-fa and piaware.
# Supported types are:
# rtlsdr: a USB-connected RTL2832U DVB-T dongle using librtlsdr/dump1090.
# beast: a USB-connected Mode-S Beast.
# radarcape: a network-connected Radarcape.
# other: a network-connected receiver that produces Beast binary output.
# relay: like "other", but will use a local relay so that only one
# connection to the receiver is needed, and also forwards output
# to the local dump1090 for map display.
receiver-type rtlsdr
# For a receiver type of 'rtlsdr', these control dongle settings
rtlsdr-device-index 0
rtlsdr-gain -10
rtlsdr-ppm 0
# For a receiver type of 'radarcape', radarcape-host should be set to
# the IP or hostname of the Radarcape
radarcape-host your-radarcape-hostname
# For a receiver type of 'other' or 'relay', receiver-host and receiver-port
# should set to the IP/hostname and port to connect to for data.
receiver-host your-receiver-hostname
receiver-port 30005
# OTHER CONFIGURATION
# Should automatic system updates (initiated by FlightAware) be allowed?
allow-auto-updates yes
# Should manual system updates (initiated by you from the website control
# panel) be allowed?
allow-manual-updates yes
# Should rfkill ("airplane mode") be set on all wireless/bluetooth
# devices on boot? This can reduce interference if you are using a Pi 3
# but not using wireless and the receiver is in close proximity to the Pi.
# For obvious reasons, this won't work if you are using a wireless network
# configuration.
rfkill no
When I load the card into the Pi and it boots to the GUI I get a No Wireless Interfaces Found message.
From the terminal I ran
sudo iwlist scan
and it returned both my main and guest network - my network was listed as ESSID: “FiOS-DD69J” so I popped the SD card back in my PC and edited the piaware-config.txt
to read
wireless-ssid "FiOS-DD69J"
Put it back in the Pi and still having the message that no network interfaces found. (Also, my wifi password is only letters and numbers with no special characters.)
Anyone suggestions on what I need to do to connect?
