web 5588 or any other port of your choice (above 1000 and not those in use between 29999-30011
location dd.mmm:dd.mmm your lat/long to 4 digit precision
then after chmod 0755 mdx or chmod +x mdx (same to create executable)
run it and see what happens. will be around for a while if more assistance needed
good luck. HTH
ed1 I see you used filezilla to transfer files to pi. are they for pi or other os ?
ed2 file mdx you can make it as mdx.sh no differene. I just prefer it without the .sh
ed3 how do you access your pi ? putty ?
Abcd567, thanks. I will have to apply this when I get home. Like I had said before, I am very ignorant to any Linux operating system and this is slowly giving me a feel of the operation. The editor also kills me too.
odd ! does everything else work similar to the pics I posted ?
location set ? google maps key ?
see the problem with deco/mixer is ‘closed code’ and is hard to determine
how it works therefore too many trials needed to get it working properly.
surely does not work off-line.
yes I know exactly what you mean. most of the time I use mc (file editor with gui).
try sudo apt-get install -y mc
when you call mc from anywhere the gui pops-up. F4 to edit file, F2 to save, F3 to view only.
similar to TotalCommander for Windoze.
@glennblum
As the old mm2.sh was scraped, and a new one created, there is low chance the problem is with it. This leaves the uploaded files as main suspect. May be these got corrupt. Delete both and run the modesmixer2 again. It should still give error but of different type.
I used Flizilla because it was recommended. Its ok but I dont think it what should be used. I think that Filzilla is currupting the files and also I am not able to install the .sqb and siluettes into MM2 file folder.
Access by PUTTY.
abcd567,
I actually went ahead and reformatted, re-mounted Pi Aware and to include MM2 which is all running good except no sqb or sils showing. I ran out of time tonight to try again and like you said, I think that filezilla corrupted my files and that is where I feel the problems exist. This may not be the programs fault and maybe my fault.
The original files on my “windows 10” computer maybe the culprit, or because I cant get the silhouette folder and .sqb file into MM2 directory. Filezilla refuses to allow it to happen.
I downloaded and installed winspc. I think that I need to get a new .sqb and silhouettes folder to upload. Mine maybe corrupted. This will happen tomorrow. Many thanks to you and the rest here for your knowledge and understanding.
Neither could I copy files from Windows to mm2 folder directly. The only place I could copy is /home/pi/. This happened both with Filezilla and WinSCP.
Later I transferred both to mm2 by following commands in PuTTY
