I’ve recently finished setting up my ADSB Receiver on a Pi 2 and have an LCD i2c of which I can use in order to display flight information. I have attempted using this GitHub repository for it: GitHub - mattdy/flightpi: Takes input from an ADS-B receiver, outputs via LCD and LEDs connected to a Raspberry Pi and I just keep getting errors despite updating the API links (for some reason some I/O error which I don’t quite understand?). If anyone has any other repositories that I could use in order to output some flight data, that would be great. I can easily buy an OLED if necessary.
I’ve been using Python 2.7 in order for it to work, Python 3 doesn’t seem to support the module it requires. I do think I have all the libraries installed however.
Ohh I’m terrible, sorry. You clearly stated LCD, i2C. I got hung up on the OLED thing mainly because its something was studying earlier today of all things.
Something’s telling me that the GPIO isn’t initiated correctly. What specific unit are you using and what chipset is it based on? What comes up when you query the I2C bus? “i2cdetect -y 1” I’m grasping at straws as I’ve only worked with LED on Arduino - bit different here.
Interesting concept though with setting up certain parms to spit out on an LCD or OLED device here so I’m all eyes if someone smart has already gone through the pain of setting this up. (cough- FA’s “jailed” flight-feeders!).
There are a few here who know exactly how this works…
If going the LED route, I suspect 3.2 inch plus…why not just do package install on top of the desktop environment and show it though :localhost on the browser?
After some quick research, that project is meant for not only the LCD, but also an Arduino to run an LCD setup according to the Fritzing example. It looks like that project will take some manipulation to work stand-alone for what think you’re trying to do.
First off it appears the I2C address is hardcoded in the LCDThread.py:
class LcdThread(threading.Thread):
def __init__(self, address=0x20, width=20):
I would expect it to also crap out when the ArduinoThread is called unless you have one piggy-backed and/or the calls rem’d out.
And SBSThread will more than likely crap out if dump1090-fa isn’t running and spitting data on port 30003.
I’m not a Python expert, maybe someone else can jump in if they look at the project pages…
Well done! Is the working version sync’d with your Github?
Looks like long story short - comment the arduino thread iterations out and correct the I2c address for your particular device. Is it still working with Beast, or did you end up changing the port back?
It is the working version in my GitHub repository. Basically the issue was the IP Address, so where it says “Mercury” in FlightPi.py, it needs to be replaced with your local IP of the raspberry pi, and then the port stays the same, which is 30003. I’ve updated the API Links in my repository if anyone wants to have a go, plus publishing instructions later.
