I’ve tried it, but discovered my uW variable attenuator passes nothing below 2GHz.
They can be had cheap for TV if you still have an interest
An attenuator will “attenuate” the signals you want by exactly the same amount as the noise you don’t. By adding an attenuator, you’ll be trading long range (weak) signals for local.
An attenuator compliments a filter, but it does not replace it.
I still have a rough time assimilating a single graph without a watermark to illustrate whether or not a change in setup is having an affect. Example:
I’d be looking to take fish out of my diet and scratch my head over ham. In reality it’s the same untouched feeder dealing with air traffic.
That said, I can somewhat identify from the previous post that Pro Stick Plus seems to present an issue in that setup, but so does fish on mine. As constructive criticism, I think it would help to show a side-by-side against a watermark setup since air traffic and environment are so unpredictable.
I’m comparing apples to oranges, but that’s my whole point. Please don’t take this the wrong way, I mention this with full respect.
(1) The drop and rise is drastic and very steep, almost a vertical rise/fall, very distinct as compared to your ham & fish example.
(2) Removal & insertion of filter and attenuaters was repeated several times, and each time a steep change took place.
(3) That test was done 4 years ago . I have done another test 2 months ago with same steep drops & rise. You can see it here:
Up to 21:20 EDT > Antenna connected to Pro Stick PLUS through FA Light Blue Filter
From 21:20 to 21:50 EDT > Antenna connected to Pro Stick PLUS directly (Filter removed).
From 21:50 to 22:00 EDT > Antenna connected to Pro Stick PLUS through FA Light Blue Filter
From 22:00 to 22:25 EDT > Antenna connected to Pro Stick PLUS directly (Filter removed).
From 22:25 EDT to end of graph > Antenna connected to Pro Stick PLUS through FA Light Blue Filter
NOTE:
Every time I removed and inserted the Filter, I made sure that all connectors are fully tightened, so the drastic drop is not due to loose connection.
I’m not dogging you amigo, just trying to help with an idea to make your tests that much better is all. I know you have gobs of equipment laying around, may as well put it to use.
I never took anything you mentioned as “dogging me”. I always take it as a constructive advice / criticism intended for help, correction & improvement, and I am thankful to you for it.
This test involves FA Antenna and ProStickPro (Blue).
Unfortunately I have only one FA antenna and one ProStick Plus (Blue), so I cannot do a true side-by-side test.
I dont have “gobs of equipment laying around”
My Dongles are:
3 x Generic
2 x Orange ProStick
1 x Blue ProStickPlus
1 x Green FlightStick (RB24)
1 x Red FlightStick (RB24) for 978 Mhz
My Filters are:
2 x FA Light Blue
1 x RB Blue
1 x Triple-filtered LNA (RTL-SDR Blog) + Bias-T
My Antennas are:
1 x FA Antenna
2 x Stock Mag mount whips of DVB-T
2 x Coiled Mag mount whips of different dimensions $4 each
2 x Magmount with V-Stub Whip
1 x V-Stub QuickSpider (made of coax only, no SO239)
Not specific to you, but I’ve wondered about about this point. N-connectors are very tolerant of tightening because the mating surface isn’t the RF connection. SMA’s are quite a different design and can be a bit finicky.
For interest, how do you satisfy " fully tightened". (finger tight?, 12" shifter? …?)
I have finger-tightened SMA connector innumerable number of times. I am Lucky that up till now I never got poor performance by finger tightening of SMA connectors (except when I removed the external filter, seems the filter had bad threads on its connectors). However, apart from above, your advise to use a torque wrench is sound, as it eliminates any chance of a loose connection. It is a simple and low cost tool which all of us should have & use.
Finger tight plus a quarter turn works well for me. I live in a very small condo so I don’t have much storage space for tools. My equipment resides on a 12" by 16" shelf in a closet.
Just remember SMA connectors were never designed for a large number of mating cycles. They were designed for semi-permanent use on microwave rigid coax. I think the original design limit was only about 100 cycles.
Let me see if I can find the picture of the “name brand QCd” connector that was cycled a few too many times and cross-threaded to boot. It had enough metallic dust in it to short out. Just sayin…
The work-around I use to avoid that possibility is to fit my equipment with M-F adapters.
At first sight, these just look like they will add a bit of avoidable miss-match until you realise how short lived SMA connections can be.
Fit these adapters and your wear surfaces become disposable.
