Official trixie release
Is there a date for a supported release for trixie?
Flighaware has not yet made available their piaware & dump1090 packages for Trixie from their repository.
Also, they have not yet announced their target date for release of these packages
However you can build & install these packages on Raspberry Pi OS Trixie, using automated scripts. as shown in post linked below. These scripts use source code provided by Flightaware on their Github site.
These scripts work both on arm64 / armhf (Raspberry Pi OS) as well as on amd64 / x86_64 (Laptop & Desktop PC):
Install Piaware on Debian 13 Trixie
IMPORTANT NOTE:
The Build process first installs tool & dependency packages (which are large in number), and after that clones Flightaware’s source code and starts building the package. This process takes long time. Please be patient and let the script take it’s time to finish.
Pre-built packages of piaware, dump1090-fa, piaware-web and dump978-fa for Raspberry Pi OS Trixie
Some times ago, I have built and uploaded to my PPA (Personal Packages Archives) at Github, following packages:
For RPi arm64
  • piaware
  • dump1090-fa
  • piaware-web
  • dump978-fa
  • tcl-tls
For PC (Desktop & Laptop) amd64
  • piaware
  • dump1090-fa
  • piaware-web
  • dump978-fa
  • tcl-tls
These can be installed by method given here:
debian13/README.md at master · abcd567a/debian13 · GitHub
NOTE:
I strongly ecommend that after installation of packages is comleted and running ok, remove entry of my PPA from your RPi’s apt sources list. This can be done by following commands:
sudo rm /etc/apt/sources.list.d/abcd567a.list
sudo apt update
I was able to get everything installed using the pre-built packages. I got a number of errors trying the “built it yourself” method. I am using a raspberry pi 5.
Thanks!
Glad to know you succeeded.
To avoid conflict with Flightaware repositiry (when in future they release these packages), please remove entry of my PPA from your RPi’s apt sources list. This can be easily done by following commands:
sudo apt update
ok, thanks again. will remote sources.
Did anyone else install pre-build piaware & dump1090-fa ver 10.2 packages on Raspberry Pi OS Trixie as per method given in above post?
I’ve been running your piaware package on a Pi4 and Pi5 since soon after you made them available - without any issues. I use readsb, so I don’t have dump1090-fa running.
I successfully installed piaware via your method described above. All appears to be working fine as well. I also removed your repo.
One question, I did NOT install the official repository for flightaware in my system because it does not support Trixie. Will FlightAware notify us all when they release the Trixie repo?
Thanks for the easy config!
Flightaware notifies the data feeders of new PiAware upgrades primarily through the My ADS-B stats page which displays a notification banner and a gear icon allowing them to initiate upgrades.
They may also be notified via email newsletters, and the FlightAware forum.
Thanks! I’ll keep my eyes opened for the release.
@kd6ftr
Is kd6ftr your Amateur Radio call sign?
I asked because it resembles a call sign.
It was. I upgraded to Amateur Extra and changed it to a vanity call KY6MM.
