Ok . I’ll use the script I wasn’t doubting the script. I just wanted to wrap my head around why things were different. Thanks for the explanation.
Update: changed my mind. The auto script apparently didn’t like the arm64 architecture, stating “Unable to download a program version for your platform!”. So i’ll just do it manually.
Is there any chance that as part of that failed automatic script, it would have removed dump1090-fa in its entirety? OR, is dump1090-fa not installed as part of the piaware-builder build? I thought it was there (before I ran the automatic script), but I’m not sure. Maybe it wasn’t. Maybe it was never installed.
Doh. I guess I need to install dump1090-fa then. Is there a way to install dump1090-fa similar to how installed piaware? Or, will i need to use adsbreceiver.net script or something like that?
Ok LOL. At this point (if you were me, but you didn’t want to start from scratch), what route would you take to get dump1090-fa installed ? Or should I install dump19090-somethingelse?
And those prescriptions are the version I used. I used those scripts to install 1090-fa, then 978-fa, and then piaware-builder. Works (almost) like charm. It doesn’t take too long, and now I run the arm64 version on Ubuntu bionic on the N2.
Sorry, I had the opporunity to leave work early, and I didn’t look back. No, I did not try the config script again. I completed the configuration using the manual instructions. Everything is running - Airspy, piaware, dump1090-fa, mlat, modesmixer2. Of course I’m only getting about 10 planes since I am using a 770 mhz yagi on it right now. Tomorrow I’ll switch my “real” antenna setup over to the Odroid, will change the feeder ID, and I should be in good shape.
Due to lack of reliability of the UAT, I decided to remove the UAT from the N2. The N2 only has 1090 and the 978 is now on an RPI. But, I am not able to have piaware on the N2 understand that it needs to stop looking for 978. I have changed the configuration for /etc/default/dump978-fa to enabled=no. I have disabled and mask the dump978. Yet, PiAware keeps telling me:
Jul 06 23:25:06 odroid piaware[2333]: no ADS-B data program seen listening on port 30978 for 250 seconds, next check in 60s
What do I need to do for Piaware to stop looking for 978?
Ok, I am planning to upgrade my Odroid set up, from a XU4 (which is working with an Airspy, my top unit) to a N2. Can I hope that all I need to do is to swap the SD card from the XU4 to the N2 and all will be well??? (Note the posts re ARM64 issues)The only other thing I will have to worry about, is adding a new N2 MAC address for Flightaware purposes.
