RPi 2 + Buster - tried to install package of “dump1090-mutability ver 1.15~dev” which was built on RPi2+Stretch - dump1090-mutability ver 1.15~dev OK, Lighttpd failed
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/dump1090/master/install_dump1090_mut_1.15.sh)"
--2019-06-28 08:00:27-- https://raw.githubusercontent.com/abcd567a/dump1090/master/install_dump1090_mut_1.15.sh
Saving to: ‘STDOUT’
- 100%[===================================>] 649 --.-KB/s in 0s
2019-06-28 08:00:27 (6.03 MB/s) - written to stdout [649/649]
Hit:1 http://flightaware.com/adsb/piaware/files/packages stretch InRelease
Hit:2 http://repo.feed.flightradar24.com flightradar24 InRelease
Hit:3 http://archive.raspberrypi.org/debian buster InRelease
Hit:4 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:5 https://apt.rb24.com rpi-stable InRelease
Reading package lists... Done
Building dependency tree
26 packages can be upgraded. Run 'apt list --upgradable' to see them.
libusb-1.0-0 is already the newest version (2:1.0.22-2).
libusb-1.0-0 set to manually installed.
lighttpd is already the newest version (1.4.53-4).
librtlsdr0 is already the newest version (0.6-1+rpt1).
librtlsdr0 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 26 not upgraded.
--2019-06-28 08:00:47-- https://github.com/abcd567a/dump1090/releases/download/v1/dump1090-mutability_1.15_dev_armhf.deb
Resolving github.com (github.com)... 192.30.253.113
Connecting to github.com (github.com)|192.30.253.113|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://github-production-release-asset-2e65be.s3.amazonaws.com/190436968/71765200-8794-11e9-876b-5bff59a44412?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20190628%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20190628T070048Z&X-Amz-Expires=300&X-Amz-Signature=cc9cfecebf47d08e453c31d73abaa2c75482ec775d1fce686b1c717612d96c05&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Ddump1090-mutability_1.15_dev_armhf.deb&response-content-type=application%2Foctet-stream [following]
--2019-06-28 08:00:48-- https://github-production-release-asset-2e65be.s3.amazonaws.com/190436968/71765200-8794-11e9-876b-5bff59a44412?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20190628%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20190628T070048Z&X-Amz-Expires=300&X-Amz-Signature=cc9cfecebf47d08e453c31d73abaa2c75482ec775d1fce686b1c717612d96c05&X-Amz-SignedHeaders=host&actor_id=0&response-content-disposition=attachment%3B%20filename%3Ddump1090-mutability_1.15_dev_armhf.deb&response-content-type=application%2Foctet-stream
Resolving github-production-release-asset-2e65be.s3.amazonaws.com (github-production-release-asset-2e65be.s3.amazonaws.com)... 52.216.237.99
Connecting to github-production-release-asset-2e65be.s3.amazonaws.com (github-production-release-asset-2e65be.s3.amazonaws.com)|52.216.237.99|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 603480 (589K) [application/octet-stream]
Saving to: ‘/home/pi/dump1090-mutability_1.15_dev_armhf.deb’
/home/pi/dump1090-mutabil 100%[===================================>] 589.34K 1.19MB/s in 0.5s
2019-06-28 08:00:49 (1.19 MB/s) - ‘/home/pi/dump1090-mutability_1.15_dev_armhf.deb’ saved [603480/603480]
Selecting previously unselected package dump1090-mutability.
(Reading database ... 43387 files and directories currently installed.)
Preparing to unpack dump1090-mutability_1.15_dev_armhf.deb ...
Unpacking dump1090-mutability (1.15~dev) ...
Setting up dump1090-mutability (1.15~dev) ...
Enabling lighttpd integration..
Enabling dump1090: ok
Run "service lighttpd force-reload" to enable changes
Restarting lighttpd..
Job for lighttpd.service failed because the control process exited with error code.
See "systemctl status lighttpd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript lighttpd, action "restart" failed.
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2019-06-28 08:01:00 BST; 51ms ago
Process: 9996 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255/EXCEPTION)
Warning: lighttpd failed to restart.
Processing triggers for systemd (241-5+rpi1) ...
--2019-06-28 08:01:06-- https://raw.githubusercontent.com/osmocom/rtl-sdr/master/rtl-sdr.rules
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.124.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.124.133|:443... connected.
Length: 5794 (5.7K) [text/plain]
Saving to: ‘/etc/udev/rules.d/rtl-sdr.rules’
/etc/udev/rules.d/rtl-sdr 100%[===================================>] 5.66K --.-KB/s in 0.001s
2019-06-28 08:01:06 (3.84 MB/s) - ‘/etc/udev/rules.d/rtl-sdr.rules’ saved [5794/5794]
already enabled
Active: activating (auto-restart) (Result: exit-code) since Fri 2019-06-28 08:02:17 BST; 50ms ago
Process: 10381 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255/EXCEPTION)
STATUS
dum01090-mutability
pi@raspberrypi:~ $ sudo systemctl status dump1090-mutability
● dump1090-mutability.service - LSB: dump1090 daemon (mutability variant)
Loaded: loaded (/etc/init.d/dump1090-mutability; generated)
Active: active (running) since Fri 2019-06-28 08:11:52 BST; 6min ago
Docs: man:systemd-sysv-generator(8)
Process: 415 ExecStart=/etc/init.d/dump1090-mutability start (code=exited, status=0/SUCCESS)
Tasks: 3 (limit: 2200)
Memory: 4.8M
CGroup: /system.slice/dump1090-mutability.service
└─495 /usr/bin/dump1090-mutability --net --ppm 0 --fix --lat 43.58 --lon -79.62 --max-ran
Jun 28 08:11:50 raspberrypi systemd[1]: Starting LSB: dump1090 daemon (mutability variant)...
Jun 28 08:11:52 raspberrypi systemd[1]: Started LSB: dump1090 daemon (mutability variant).
Lighttpd
pi@raspberrypi:~ $ sudo systemctl status lighttpd
Active: failed (Result: exit-code) since Fri 2019-06-28 08:11:56 BST; 1min 19s ago
Process: 656 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, stat
Jun 28 08:11:56 raspberrypi systemd[1]: lighttpd.service: Service RestartSec=100ms expired, scheduli
Jun 28 08:11:56 raspberrypi systemd[1]: lighttpd.service: Scheduled restart job, restart counter is
Jun 28 08:11:56 raspberrypi systemd[1]: Stopped Lighttpd Daemon.
Jun 28 08:11:56 raspberrypi systemd[1]: lighttpd.service: Start request repeated too quickly.
Jun 28 08:11:56 raspberrypi systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Jun 28 08:11:56 raspberrypi systemd[1]: Failed to start Lighttpd Daemon.
Piaware
pi@raspberrypi:~ $ sudo systemctl status piaware
Active: active (running) since Fri 2019-06-28 08:25:32 BST; 34s ago
Main PID: 1029 (piaware)
Tasks: 4 (limit: 2200)
Memory: 10.5M
├─1029 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/st
├─1067 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-ty
└─1077 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --
Jun 28 08:25:36 raspberrypi piaware[1029]: no ADS-B data program seen listening on port 30978 for 3
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): fa-mlat-client 0.2.10 starting up
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): Using UDP transport to 70.42.6.198 por
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): Listening for Beast-format results con
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): Listening for Extended Basestation-for
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): Input connected to localhost:30005
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): Input format changed to BEAST, 12MHz c
Jun 28 08:25:37 raspberrypi piaware[1029]: piaware received a message from dump1090-mutabi!
Jun 28 08:25:37 raspberrypi piaware[1029]: mlat-client(1067): Beast-format results connection with :
Jun 28 08:25:42 raspberrypi piaware[1029]: piaware has successfully sent several msgs to FlightAware
