I had to force it to allow the downgrade but that made no difference.
As said above, I’ve tried different dongles and different USB ports so sadly it’s not as simple as that.
You mean due to the proximity of the ethernet cable? For the moment, I’m testing on the bench so I’ve thrown a wpa_supplicant.conf file at it and am working via WiFi so no ethernet connected.
I don’t think I even own a powered USB hub and I already tried the firmware/kernel using that method, despite the usual warning not to do it unless instructed by an RPi engineer.
Still the same
I know it works with the Airspy because I’ve seen a post elsewhere by someone who’s got it working, it’s just this damn RTL-SDR that’s the issue. And yes, I appreciate that I’m going to be using this particular setup with an Airspy but not just yet.
I think that’s right. I wrote a fresh SD card and installed just rtl-sdr.
pi@raspberrypi:~ $ rtl_test
Found 1 device(s):
0: Realtek, RTL2832U, SN: 00001000
Detached kernel driver
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode...
Allocating 15 zero-copy buffers
lost at least 3714 bytes
lost at least 286 bytes
lost at least 158 bytes
lost at least 5494 bytes
lost at least 4260 bytes
lost at least 3402 bytes
lost at least 3846 bytes
lost at least 2416 bytes
lost at least 700 bytes
lost at least 444 bytes
However, after a reboot:
Found 1 device(s):
rtlsdr_read_reg failed with -7
rtlsdr_write_reg failed with -7
No supported tuner found
rtlsdr_demod_write_reg failed with -7
rtlsdr_demod_read_reg failed with -7
FWIW, I’m new to the Raspberry Pi and Piaware and ADS-B tracking in general. Picked up a 4 B 1GB at MicroCenter earlier.
Tried booting from the default piaware image and it doesn’t seem to - running it headless though. The USB stick from flightaware doesn’t even heat up like it does when I’m running dump1090 on a Windows machine with it, which makes me think it’s not interfacing with the USB device.
There really isn’t any reason to use the piaware sd-card image if you manage to use a standard Raspbian.
The sd-card image is made so that you never need to use the console of the RPi basically.
If you have console access installing piaware should be really easy
Sorry, I should have been more specific and said that I’m not getting data. Piaware and dump1090 are installed fine now.
Also getting this, like Keithma
sudo rtl_test
Found 1 device(s):
