You are absolutely correct sir. From the first line of the latest change log:
2019-09-26:
* rpi-eeprom included
- This will automatically update the SPI EEPROM on the Raspberry Pi 4 to the latest stable version.
See https://rpf.io/eeprom for more information.
Well, the Raspian people do, and they have apparently already added the tool to so that it is updated automatically.
Edit: Ah, I see what you mean. I was not wondering why it was in a separate tool, but why they recommended on the website to update the eeprom automatically (somewhat hidden) but did not include it in the image, which they subsequently have.
A good thing, too. might as well update documentation, but the no harm done I trying to install something that is already installed.
The following packages will be upgraded:
firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
firmware-realtek libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc
libraspberrypi0 raspberrypi-bootloader raspberrypi-kernel raspi-config
Hmm. I know I’m having a brain fart. I have a 64 GB sdcard for this thing (yeah, way overkill). Trying to use Etcher on it and it only did /boot and then said that checksums didn’t match up. Tried three times and that was the case. Then I read somewhere that sdcards greater tahn 32 GB needed to be formatted differently, which sent me down a path of “SD Card Formatter” and GUI format. Still no go. I have to take a break though. I’ll revisit in the evening, hopefully with a clearer head.
I use 64GB , 128GB and 192GB with no issues.
Don’t modify the /boot/ files until the verification has completed and the device has been USB ejected.
I then re-insert it to create the ssh.txt file
The microSD card must be formatted as fat32. Windows cannot do it because of a 32GB limit. Use third party solution such as EaseUS Partition Master to format higher capacity cards as fat32. I use 64 gb cards in my RPi’s.
I should have had faith in Etcher. I ended up swapping out the USB card reader that came with the Pi and instead put the SD Card in the card reader already in my Dell, and I had no problem running Etcher then.
Ok guys – I did this once not too long ago on an Odroid N2, and for the life of me I failed to document it.
I’ve got Raspbian GNU/Linux 10 (buster) running. Obviously I want to install the piaware addon (along with anything else I have to install to support both RTLs and Airspys) – dump1090-fa. All that typical stuff so that it’s like an sd card image but more configurable.
Is there a single link I can go to and find the actual instructions for installing whatever the latest piaware / dump1090-fa that are preferred for Buster? I’d appreciate any help. I was following some things earlier up in this thread, but I got confused and it looked like some of the things being referenced were installing / compiling sources from dev versions before the latest stuff was released.
Thank you. All done. Looks good. But I have to wait til tomorrow and swap the Airspy out of the Odroid into the PI4 and do some configuring. Thank you so much.
Thanks, Jon. I’ve got the Airspy working on the Odroid now. I’ll be installing on the PI4 tomorrow.
I have to get the Airspy stuff setup, modesmixer installed, and should be set.
The end goal is to see if I’ll be able to run 20/24 on the Airspy instead of 12 without having MLAT crap out like it does on the Odroid.
(sidenote: Odroid with nothing special for cooling and the Airspy/Dump1090-FA running is about 6C cooler than the PI4 is (with heatsinks, fan, and no software other than standard OS stuff). so I have to give thumbs up to the Odroid for it’s lower temp)
