Distributor ID: |
Debian |
Description: |
Debian GNU/Linux 12 (bookworm) |
Release: |
12 |
Codename: |
bookworm |
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“Debian -- User Support”
BUG_REPORT_URL=“https://bugs.debian.org/”
Step-1: Plese issue following command. It may fix the problem
sudo apt --fix-broken install
Step-2: If above command does not fix the problem then issue following commands
sudo apt install libboost-regex-dev
sudo apt install --reinstall beast-splitter
Step-3: If above commands also do not fix the problem, then as a last resort install manually by using method given below
step (3.1) Increase RAM to 2.5 GB by adding a swap file
(after beast-splitter has been built and installed, you can delete this file to free space on microSD card)
