Hey all,
I recently obtained a new Micro SD card and installed the latest version of Raspberry Pi OS (Bookworm). After installing Piaware per the instructions at “PiAware - dump1090 ADS-B integration with FlightAware - FlightAware” the IP of the Pi on the local machine only displays a “forbidden” message and I am forced to use IP:80 to display the splash screen of Piaware. On the splash screen all services display in red and read “PiAware does not appear to be running.” “Sudo piaware-status” delivers the following:
PiAware master process (piaware) is running with pid 1191.
PiAware ADS-B client (faup1090) is running with pid 1471.
PiAware ADS-B UAT client (faup978) is not running.
PiAware mlat client (fa-mlat-client) is running with pid 2337.
Local ADS-B receiver (dump1090-fa) is running with pid 741.
Local ADS-B UAT receiver (dump978) is not running.
dump1090-fa (pid 741) is listening for ES connections on port 30005.
no program appears to be listening for UAT connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
got ‘couldn’t open socket: connection refused’
dump978 is NOT producing data on localhost:30978.
The station is claimed and appears to be reporting to FA as well, Graphs1090 shows activity.
This indicates at least the 1090 service IS running which directly conflicts with what the main page says. Further, planes are visible with range rings on IP:8080. I am running 978 as well which appears to be down and will not come up. Also attempting to assign the receivers with “sudo piaware-config rtlsdr-device-index 00001090” and “sudo piaware-config uat-sdr-device driver=rtlsdr,serial=00000978” gives me the error “warning: cannot set option ‘rtlsdr-device-index’, option only supported on PiAware or FlightFeeder SD card images”. This is an “Add-on” install if that makes any difference in troubleshooting steps.
uname -a
Linux raspberrypi 6.1.0-rpi8-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.73-1+rpt1 (2024-01-25) aarch64 GNU/Linux
cat /etc/os-release
PRETTY_NAME=“Debian GNU/Linux 12 (bookworm)”
NAME=“Debian GNU/Linux”
VERSION_ID=“12”
VERSION=“12 (bookworm)”
VERSION_CODENAME=bookworm
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“Debian -- User Support”
BUG_REPORT_URL=“https://bugs.debian.org/”
apt-cache policy dump1090-fa
dump1090-fa:
Installed: 9.0
Candidate: 9.0
Version table:
*** 9.0 500
500 http://flightaware.com/adsb/piaware/files/packages bookworm/piaware arm64 Packages
100 /var/lib/dpkg/status
apt-cache policy dump978-fa
dump978-fa:
Installed: 9.0
Candidate: 9.0
Version table:
*** 9.0 500
Any help solving this is appreciated.
Thanks.
