Hey. I have a spreadsheet with aircraft movement info. I’m running the registrations of jet aircraft listed through google, hopefully finding reg info. on a site like airport-data.com and using the FAA Database as a back up. All I’m needing is the Owner info.
I was doing pretty ok till I ran into N65HU. It turns out that although it is registered to Jacura Delaware Inc, Hop-A-Jet charters it out. I knew that these things happened but forgot until I ran into that. I am now needing a way to see if a charter company uses the aircraft as it is charter/fractional companies that I’m targeting.
Also can anyone identify this aircraft type:EC-100, Reg: G-CEDJ. Thinking about it, maybe it’s a eurocopter?
Also, the following regs are showing conflicting info:
N9789S, listed on the records as a C-750 but all I can find is a Turbo Commander
N107CE, listed on records as a C550, FAA/Google shows that it doesn’t exist.
HI-840, listed on records as a LJ-31 but all I can find is a picture of a Jetstream 31
N377TA LJ-35, non existant
N991A1 LJ-35, not even valid
N16099, listed as LJ-60, shows as some old plane owned by a museum. Vultee V-1A
Much, much, much thanks to anyone who can help me.
