I have Move the micro SD card from raspberry pi B to a pi 2 and my stats for flightaware are down.
Planefinder and fr24 are still fed and I can reach my dump muta 1.15 development Webpage that show planes.
What did I miss?
Best regards,
Regis
PS : I run latest update/upgrade and kernel already.
By changing the Pi, your MAC-address has changed (the unique address of your Ethernet adapter).
This is the hardware address that identifies your site. You have to register a new site, because of that, even you did not change the location.
There are also ways to fake your MAC-address, so that it looks like your new Pi has the address from the old one, but if you are not experienced, I would not suggest to do so.
You do need a better antenna or antenna placement - it looks like you have a maximum range of just over 50nm - it shouldn’t be difficult to get 3 or 4 times that wit even a simple antenna placed outside.
I got top notch FA antenna gain +6from Wifi expert on eBay and I am about to set the filter amp for +12 gain.
I moved to PI2 to use one usb to power the filter amp using one free port (consume 60ma).
I need to get a MINI usb cable tonight and I will reclaim the device.
I live in ground floor level in city… I know this is not optimised, but I train to move the setup in November to Eastern France where I expect more efficient capture.
EDIT: new device reclaim, but I wonder why I did not claim the device under wifi, I wouldn’t have this problem today.
I tried for a bit to spoof the mac address but I failed and rolled back. It makes like a new device, fresh start, with pre-amp filter, I am looking forward for improvements.
