Why does FA give nice maps for flights in the US and from North America to Europe but gives maps that show only part of the flight for flights to Asia:?: FA gives a map of North/South America Europe, and Africa for flights over the Atlantic. I know FA tracks only FAA tracked flights, but if does fine on the US/Europe flights, why does it do so terribly on the US/Asia flights:?: example www.flightaware.com/live/flight/ACA7
Iâll point out that FA does not do well mapping flights south of the Mexican border either. Itâs simply not in the data from the FAA. FA does the best they can with what they get.
FA: What do you think the impact would be to simply not plot the route of flights outside the US, or stop trying to track them at a certain point?
Flights outside of US donât do well on the map display and they cause considerable confusion amongst users. I personally would rather the map show the track to the border and then stop. Since you apparently do get some information outside of the US and are trying to plot it, it makes a mess of the map.
An alternative that would be okay with me (but you would probably get objections from other users) would be to simply not show a map at all for the individual flight pages for flights outside of the US. The flights might show up on the airport map displays while they are close to their origin/destination and on inbound/outbound activity lists , but NOT show maps on the individual flight pages.
Personally, Iâm in favor of mapping out all the data that FA gets from the FAA. I think FAâs disclaimer of possible unreliability is completely appropriate.
Of the overseas flight maps I see, many more are right than are erroneous. I can understand why a track stops in mid-ocean.
If one needed total map reliability, should FA stop showing domestic flights because of maps like âAIR1â?
Messed up maps are confusing to new users who encounter them for the first time. Thatâs the nature of the beast. Users learn and adapt. I wouldnât use a few bad maps as the basis for not displaying a whole classification of map data, most of which is as good as one can get.
I think itâs approriate, too, but many people donât read it or donât think it applies to their flight. I just thought it might be better not to show content that seems to confuse everyone when it is probably incomplete anyway. At least until Karl tinkers with the mapping engine.
Whatâs your alternative, BT? Iâd think youâd have to drop down to manual deletion of a few bad maps (that disappear anyway on the next IFR flight). That could be just as confusing as youâd get postings asking why there isnât a map with flight âXYZâ.
Further, if you manually delete bad maps, why shouldnât I argue that you should manually delete confusing flight plan entries? If you happened to read one of my comments on a different topic, youâd see that I was confused by four âscheduledâ flight plans from PHNL to KOAK that had identical times for departure and arrival. How do you fly four flight plans from A to B? Perhaps I could make a case that they ought to not be shown because they only confuse users. mduell says, however, that theyâll be gone in a day or so anyway.
Arenât my extraneous flight plans comparable to your bad maps?
I still say FA should post all the data it gets, incomplete and confusing or not. With a little time and thought, itâs not that hard to figure out what was going on. Viewing FA without potentially confusing data is like eating a sandwich without the bread crusts. Some people will like it that way, but for others it removes a lot of food for thought.
I do not need âtotal map reliability.â Whatever FA gives is better than nothing. Besides, I really like those flight maps.
Right on!
I did not ask why there wasnât a map for a specific flight. I was asking why FA tracks some flights which were not, at any time, in FAA airspace when FA says in the FAQ, âFlightAware can only track aircraft that are being tracked by the FAA, which means aircraft only in the United States.â (emphasis added)
I realize FA gets some Canadian flights (but not all) that are in Canadian air space from take-off to landing. However, I canât think any others that arenât, at least in part, flying over U.S.-controlled space. Do you have an example?
Although neither the origin nor destination of AFR489 is in the U.S., the flight does cross the western half of the Atlantic in U.S.-controlled air space.
There is a significant distinction between U.S. air space (within the U.S.) and U.S.-controlled air space (which includes over international waters out to approximately mid-ocean). By international agreement, U.S. ATC covers most of the western North Atlantic and a hefty chunk of the Pacific, including waters to and beyond Hawaii.
FAâs maps do show trans-oceanic flight segments under control of U.S. ATC. The reliability of those mapped segments may be under some question since there are no permanant radar installations over the oceans. However, satellite links of airborne GPS reports are probably quite good.
When a flight crosses over to âThe Far Sideâ (of the ocean), however, it might as well have fallen off the face of the earth. U.S. ATC gets no position reports and, for us, No Data = No Map.
In the case of AFR489, the only position data is position reports made by the pilots on HF. Look at the tracklog and youâll see a position report every hour or so.
I didnât know that. FA should have put âin US controlled airspace,â instead of âin the United States.â The western Alantic is not in the United States.
Here is the long answer to internationally tracked flights.
âFlightAware can only track aircraft that are being tracked by the FAA, which means aircraft only in the United States. For flights arriving in the US from an international origin, FlightAware will be able to track the US once the flight is handed off to the US. For flights departing the US for an international destination, FlightAware will be able to track the flight until it leaves the US and then it will be lost with no arrival ever recorded or the arrival time will be the time it left the US.â
Did I get you on your soap box? I donât know that we actually do disagree in a real sense. Just different thoughts on how it should be presented. But you can probably ask 100 FA users how it should be done and youâll come up with 102 answers.
The map errors and the duplicated flight plans donât bother me in the least. But I am a pilot, and I have been a software developer specializing in map displays, so I understand both situations better than most. But to folks who donât have a lot of experience with one or the other, they can be confusing. I was simply throwing out some alternatives.
But if Karl says heâs working on a cool solution, I canât wait to see how he does it! Iâm sure it will be good!
