Losing local connectivity
OK this is bizarre.
Pi is a B+, v2.0-4, connecting via wifi.
I was having trouble with the wifi stick crapping out, so I decided to put the DVB-T and the wifi on a powered hub to see if that would stabilize things. It SEEMED to work, but a new problem has come up. I am losing local connectivity to the pi after a half hour or so… however, it’s still feeding data to FA! I can’t ssh to it, ping it, web interface… unless I reboot it. Unfortunately, where it is, I can’t attach it to a TV, but may have to move it so that I can to figure this out.
Anyone ever see this?
Does it show the expected IP addresses in the FA site information section?
Might be getting a new DHCP lease on a different IP (possibly after the network drops out / comes back), assuming you’re using DHCP.
Try setting a static lease?
Well FA was still showing the same local IP…
For troubleshooting, I put the wifi thumb directly on the Pi, and left the SDR on the powered hub. After a half hour or so, I’m still able to get into it locally. How weird?!? I’ll update a little later…
Drats. The old issue came back up (wifi thumb just flat out dies.) Maybe this USB WiFi adapter is a POS. I’m actually moving my cable modem into the same room that the piaware box is in, so I’ll be putting it on wired ethernet soon.
In the meantime I just took a new Pi2 that has been waiting in the wings out of the box and I’m giving it a whirl. Whoa, this thing is quite a bit snappier than the B+.
I was dealing with the similar problem on Pi2. Went through 4 different power supply adapters with no success. Turned out that I initially overclocked the Pi2 to 900Mhz with over voltage and forget about that. I reduced the overclocking to 800Mhz with no over voltage and it is stable now. Is your B+ overclocked?
No overclocking - I literally opened the box today and hooked it up with the SD that the B+ was using. Vital signs still good for now…
B+ overclocking is safe, but Pi2 overclocking is problematic and is best to be avoided.
