Boa tarde! Alguém me sabe dizer onde posso consultar a chave para inserir no PIware, Agradeço a atenção.
Ct1ATO
Read PiAware - build your own ADS-B ground station for integration with FlightAware - FlightAware
Step 5 Claim your PiAware client on FlightAware.com
Olá boa tarde!
Muito obrigado por me ter respondido. Já tenho a estação terrestre montada, mas só agora resolvi activar.Ok.vou então reivindicar o PiAware.
Até uma próxima e bons voos
Ok. Muito obrigado por ter respondido e fornecido a informação necessária. Já tenho o RTL2832U há anos, mas só agora me dediquei a mais uma actividade. Não fui piloto, sou electrotécnico e pertenci à FAP. Dedico-me à recepção de satélites de comunicações e meteorológicos, por isso o CT1ATO, indicativo da minha estação.
Os meus cumprimentos
Eduardo Mata
A sábado, 1/02/2025, 16:00, chrislfa via FlightAware Discussions <notifications@flightaware.discoursemail.com> escreveu:
Good luck, lots of information in this forum, please have a search if you want to find more information.
Hello;!
I apologize for the abuse and for writing directly by email,
I don’t know anything about computers and it took me about 4 months to get here. I had the system running for a day, but unfortunately I turned off the Raspeberri PI4 and turned it back on and lost the software. I read, I asked, I copied, I made mistakes and now I’m in a dilemma. I have the software working perfectly on Raspeberry and I can’t send the data to FlightAware, I make “localhost” sign in; “localhost:8080”; “localhost/dump1090-fa”
Sometimes I get the following response: the loclhost site is online but not responding to connection attempts, other times it says 404 or 403.
I created a map, because I was told to do it, but I don’t know if I did it well or badly, I would also like you to inform me about it.
I remembered to turn to those who know how to ask for help and try to solve the problem if possible
I am very grateful
Eduardo Mata ct1ato
Always shut it down before turning it off. In the terminal enter
sudo shutdown -h now
or from your Stats page you can click the cogwheel, select Halt and Send and shut it down in there
Be sure that you have good wifi coverage and are not right on the edge. There is no reason why your access should be intermittent if you have a good network connection.
Maybe try again but this time use the PiAware image instead of the package add-on. You can edit the file in boot
called piaware-config.txt
to set up your network. You can make an empty file in there called ssh
and this will enable ssh access. You can then claim this is a new site as explained on that page.
Agradeço a informação dada. A antena está bem colocada, o Cabo coaxial da antena até ao LNA e do LNA até ao receptor é bom com baixas perdas.A cobertura wi-fi, é bastante estavel. Tomei boa nota da ajuda e assim farei. Darei noticias do desenvolvimento do meu trabalho. Obrigado e bons vôos Eduardo
Thank you for the information given. The antenna is well placed, the coaxial cable from the antenna to the LNA and from the LNA to the receiver is good with low losses. The wifi coverage is quite stable. I have taken good note of the help and I will do so. I will give news of the development of my work. Thank you and good flights Eduardo
