My is running raspberry for at least 6yrs without any major issues and without any changes. So I simply don’t get enough practice in trouble shooting. I do feed flightaware as well as FR24 – no change here neither. Every now and then I do run upgrade/update commands.
Early this year I have installed software providing me with performance statistics. This helped me to identify a significant increase in CPU usage. Please see attached.
I have seen posts reporting similar problems, but I wasn’t smart enough in distilling a path forward out of the discussions/replies.
While I’m picking brains here one more observation. What the h… is the RPI downloading pretty much every night? Please see also attached.
Ah OK, I misread the CPU graph as being total system CPU (which is relative to the whole system) not just the dump1090 CPU stats (which are relative to a single CPU).
It’s a little unusual to see that much of a spike on a Pi 2 - usually you’d see that more on a Pi Zero / ZeroW or Pi 1 due to the older generation ARM core on those systems - but I suspect you have the gain cranked all the way up, which tends to make the demodulator see more false-positive preamble detections, and the demodulator changes mean that there’s more work to be done per preamble detection.
6.0 will have some options to turn off more of that extra work (at the expense of slightly worse decoding) if the extra CPU is a problem.
