Hi!
Smth went wrong with cpu utilization.
Using rpi 4 with radarbox green stick. No changes in settengs were made il last 5 days.
Rebooted with no success
What could it be?
Ty
It looks like USB CPU utilization went up but overall CPU and memory utilization went down. Are you experiencing issues related to the increased USB CPU utilization?
I assume you have updated recently and causing the problem where lots other users discussed.
It’s a library issue. In the thread you will finde different solution.
yep, that’s it. dump1090 cpu usage dropped from 12-17% to about 2%. thank you
How do you get the fancy graphs on raspi?
Nothing special)
cd ~
sudo bash -c "$(wget -q -O - https://raw.githubusercontent.com/wiedehopf/graphs1090/master/install.sh)"
Then go to
http://192.168.xx.xx/graphs1090 from PC (xx.xx. - your rpi IP adress)
or
http://127.0.0.1/graphs1090 from rpi browser
Nothing special to download but a lot of work by @wiedehopf to modify the old script and support it ![]()
The best part of modification from old script of J Prochazka to current script of @wiedehopf was to eliminate its dependency on “Web Portal”, and make it a stand-alone app. Good work by @wiedehopf, who has done other improvements/enhancements as well.
