Thank you
When looking at a wide slice of spectrum like that, it’s important to take the antenna into account.
A broad band antenna like a disc cone will give a relatively flat response.
or you can characterise your existing antenna by using your “nose source” *. (then subtract one plot from the other)
* That’s a “Noise Source” to anyone without the BG7TBL device.
Yep!
I know you have one of those!!
How do you install that on a Pi?
I’ve never done it. <20 characters>
The AIS-catcher have added web interface including map.
I removed old built (by renaming the folder) and ran installtion script again to install the latest version of AIS-catcher which has the web interface. Copy pasted old config to new with addition of “-N 8383” to show web interface (map) on IP-of-PI:8383,
EDIT: Added “-N 8383” in the installation script, no need to do it manually now.
Now no need to install AIS-Dispatcher or OpenCPN or any other App to locally view the map.
Another Info: I have ordered ShipXplorer AIS Dongle from Amazon. Expected to reach after new year holidays. It has built-in 162 MHz Filter and LNA. The ShipXplorer is actually sister company of AirNav / Radarbox24.
This is what I have done to upgrade to latest version of AIS-catcher:
sudo mv /usr/share/aiscatcher /usr/share/aiscatcher-old
sudo bash -c "$(wget -O - https://raw.githubusercontent.com/abcd567a/install-aiscatcher/master/install-aiscatcher.sh)"
cat /usr/share/aiscatcher-old/aiscatcher.conf ##Coped config
sudo nano /usr/share/aiscatcher/aiscatcher.conf ##Pasted config and added new line -N 8383
sudo systemctl restart aiscatcher
CLICK ON SCREENSHOT TO SEE LARGER SIZE
Does the AIS dongle deff have a filter & LNA in it, can’t find any reference to it on the net.
When I receive it, I will open the plastic cover and see. I will also take photograph of internals and post here.
Please see these two posts:
https://discussions.flightaware.com/t/does-anyone-monitor-ais-ship-and-vessel-tracking/53634/249
https://discussions.flightaware.com/t/does-anyone-monitor-ais-ship-and-vessel-tracking/53634/250
I have now modified my “install-aiscatcher.sh” script. I builds the latest source code (which has -N .
The default config file is as follows
Code:
-d 00000162
-v 10
-M DT
-gr TUNER 38.6 RTLAGC off
-s 2304k
-p 3
-o 4
-u 127.0.0.1 10110
-N 8383
The announcement on completion of installation also clearly shows that web interface i(Map etc) is available at IP-OF-Pi:8383
Awesome.
I rebuilt my AIS Pi last night not knowing about this and just copied in my .conf file.
After reading about the change I added the -N variable and I now have the web pages and map complete with a SAR plane
S.
If you add 2 lines like shown below, the 2nd line will start showing distance of ships from your station.
Currently it is showing
In my config file, I have added these two lines:
-N 8383
-N STATION TORONTO LAT 43.6 LON -79.6
EDIT:
I have updated script to display both the new features when announcing completion of installation
I put that second line in without the site name. It crashed when i used a negative LAT.
It worked OK when i put it in the command line.
I added a site name and all working now.
S.
Edit. It was a negative latitude that caused it to crash.
After successful installation of new version of AIS-catcher which has Web server with map and statistics, I wanted to uninstall AIS-Dispatcher. This program was installed without sudo apt install
or sudo dpkg -i`. It was installed by some script from AISHub.
I could not find instructions on AISHub how to uninstall and completely remove all its files & folders.
They have made this program in a tricky way by using loginctl
instead of systemctl
. As the loginctl
is very unfamilier to common user, this seems to be intended to prevent most users to have any control over their App.
However after some investigation and Googling I discovered following commands to enable and disable the AIS-Dispatcher:
sudo loginctl enable-linger [USER]
sudo loginctl disable-linger [USER]
By checking my Pi, I found The [USER] for AIS-Dispatcher is “ais
I finally disabled the AIS-Dispatcher by following commands:
sudo loginctl terminate-user ais
sudo loginctl disable-linger ais
sudo reboot
I have a problem with Shipxplorer crashing and not restarting.
It has been happening quite regularly and no amount of starting fresh seems to make a difference.
Yesterday I removed a brand new microSD card from its wrapper and used the Raspberry Pi imager to write a fresh Raspery Pi OS 32 bit (with GUI).
Installed it into a Pi4 2 GB and let it start and do its thing.
Used Putty to SSH into it and did the following 3 things;
- Turn on VNC
- Run the Install from here
- Edit the config file using sudo nano /usr/share/aiscatcher/aiscatcher.conf
It runs happily for an hour to a couple of days and then just crashes with
pi@AIS:~ $ sudo systemctl status aiscatcher
● aiscatcher.service - AIS-catcher
Loaded: loaded (/lib/systemd/system/aiscatcher.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Fri 2022-12-30 11:13:18 AEDT; 2h 1min ago
Process: 1236 ExecStart=/bin/bash /usr/share/aiscatcher/start-ais.sh (code=exited, status=0/SUCCESS)
Main PID: 1236 (code=exited, status=0/SUCCESS)
CPU: 2h 2min 7.422s
Dec 30 11:13:12 AIS aiscatcher[1237]: {"class":"AIS","device":"AIS-catcher","rxtime":"20221230001312","scaled":true,"channel":"B","nmea":["!AIVDM,1,1,,B,404k1EQvK?0=<bEthUb:JhW00<1d,0*42"],"signalpower":-31.191364,"ppm":1.157407,"mmsi":>
Dec 30 11:13:14 AIS aiscatcher[1237]: {"class":"AIS","device":"AIS-catcher","rxtime":"20221230001314","scaled":true,"channel":"B","nmea":["!AIVDM,1,1,,B,14`Uu`0001:GLIabF2:uh64v08B1,0*26"],"signalpower":-19.128841,"ppm":0.578704,"mmsi":>
Dec 30 11:13:15 AIS aiscatcher[1237]: {"class":"AIS","device":"AIS-catcher","rxtime":"20221230001315","scaled":true,"channel":"B","nmea":["!AIVDM,1,1,,B,B7Ohg0P0=:Uo8lJUBKaGswWQl<0B,0*39"],"signalpower":-32.812496,"ppm":-2.314815,"mmsi">
Dec 30 11:13:17 AIS aiscatcher[1237]: {"class":"AIS","device":"AIS-catcher","rxtime":"20221230001317","scaled":true,"channel":"A","nmea":["!AIVDM,2,1,9,A,55>mwR82AwKW<HIKJ20tt<j0AE884r2222222216LiFV87=60NhEDnA8,0*66","!AIVDM,2,2,9,A,?g`>
Dec 30 11:13:18 AIS aiscatcher[1237]: cb transfer status: 1, canceling...
Dec 30 11:13:18 AIS aiscatcher[1237]: ----------------------
Dec 30 11:13:18 AIS aiscatcher[1237]: [AIS engine v0.42 #0] total: 38012 msgs
Dec 30 11:13:18 AIS aiscatcher[1237]: Reattaching kernel driver failed!
Dec 30 11:13:18 AIS systemd[1]: aiscatcher.service: Succeeded.
Dec 30 11:13:18 AIS systemd[1]: aiscatcher.service: Consumed 2h 2min 7.422s CPU time.
This is the config file
-v 10
-M DT
-u 192.168.178.154 10101
-u 127.0.0.1 10101
-u 5.9.207.224 6239
-u 31.172.90.245 45797
-u hub.shipxplorer.com 45177
-u hub.shipxplorer.com 28367
-gr TUNER 49.6 RTLAGC off
-p 0
-o 4
-u 127.0.0.1 10110
-N 8383
-N STATION MELBOURNE LAT -37.37 LON 145.04
Any suggestions as to the cause or where to look for the problem would be greatly appreciated./
S.
(1) Most common causes are:
- A dying dongle (Try another dongle)
- A bad USB extender cable (remove or replace USB cable)
- A bad USB port of Pi (try another port)
- Low voltage (try another power supply)
RPI Low Voltage Check
sudo dmesg --ctime | grep voltage
If no output, Voltage is OK
(2) What is output of this command? (possible file corruption)
cat /usr/share/aiscatcher/start-ais.sh
This is output of my healty system:
abcd@debian11:~$ cat /usr/share/aiscatcher/start-ais.sh
#!/bin/sh
CONFIG=""
while read -r line; do CONFIG="${CONFIG} $line"; done < /usr/share/aiscatcher/aiscatcher.conf
cd /usr/share/aiscatcher
/usr/local/bin/AIS-catcher ${CONFIG}
The dongle is an RTL-SDR.COM v3 and happily runs again with a restart command. I will try and swap it out but running short on supply at the moment.
The dongle is plugged directly into the Pi4. No cable.
Tried all 4 ports
No low voltage messgae. It is run using a PoE splitter from a managed PoE 8 port switch.
#!/bin/sh
CONFIG=""
pi@AIS:~ $
I’ll run it from the command line and see if I can find the reason for the crash.
S.
Try to run it using following command
Note: To break out of continous flow of data resulting by following command, press Ctrl and C keys togather
abcd@debian11:~$ sudo systemctl stop aiscatcher
abcd@debian11:~$ sudo bash /usr/share/aiscatcher/start-ais.sh
AIS-catcher (build Dec 29 2022) v0.42
(C) Copyright 2021-2022 jvde-github and other contributors
This is free software; see the source for copying conditions.There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Searching for device with SN 00000162.
UDP: open socket for host: 127.0.0.1, port: 10110, filter: OFF
UDP: open socket for host: 10.0.0.10, port: 10101, filter: OFF
UDP: open socket for host: 5.9.207.224, port: xxxxx, filter: OFF
UDP: open socket for host: ais.vesselfinder.com, port: xxxx, filter: OFF
UDP: open socket for host: hub.shipxplorer.com, port: xxxxx, filter: OFF
UDP: open socket for host: 54.204.25.151, port: xxxx, filter: OFF
UDP: open socket for host: data.aishub.net, port: xxxx, filter: OFF
HTML Server running at port 8383
[R82XX] PLL not locked!
Allocating 15 zero-copy buffers
Device : RTL2838UHIDIR
Settings : rate 2304K freqoffset 38 format CU8 tuner 42.099998 rtlagc OFF biastee OFF buffer_count 2
Model #0 : [AIS engine v0.42] ps_ema ON afc_wide OFF droop ON fp_ds OFF
{"class":"AIS","device":"AIS-catcher","rxtime":"20221230072503","scaled":true,"channel":"B","nmea":["!AIVDM,1,1,,B,14eGckh001JDSl8HuvJJ1osp0l0B,0*62"],"signalpower":-43.541355,"ppm":-0.578704,"mmsi":316009423,"status":0,"status_text":"Under way using engine","turn":0,"speed":0.100000,"accuracy":false,"lon":-79.394768,"lat":43.635372,"heading":253}
{"class":"AIS","device":"AIS-catcher","rxtime":"20221230072503","scaled":true,"channel":"A","nmea":["!AIVDM,1,1,,A,14eHd6M000rDUQ>Hv37dR5820d0H,0*32"],"signalpower":-40.045383,"ppm":-3.761574,"mmsi":316025881,"status":13,"status_text":"Reserved","turn":0,"speed":0.000000,"accuracy":true,"lon":-79.388947,"lat":43.637383,"heading":164}
^C----------------------
[AIS engine v0.42 #0] total: 2 msgs
Thanks, I’ll try that next.
Currnetly running
AIS-catcher -v 10 -M DT -u 192.168.178.154 10101 -u 127.0.0.1 10101 -u 5.9.207.224 62nnn -u 31.172.90.245 45nnn -u hub.shipxplorer.com 45nnn -u hub.shipxplorer.com 28nnn -gr TUNER 49.6 RTLAGC off -p 1 -o 2 -u 127.0.0.1 10110 -N 8383 -N STATION MELBOURNE LAT -37.37 LON 145.04
Nearly 8 hours so far
