Gang I have been tuning my primary receiver and the last bit is to get it set to the optimal gain for my area. Right now the process is running with Automatic Gain set at the command line and I can see it cycle the gain setting while I monitor my receiver’s stats based on the stat themselves, I can see a message rate of 600/sec go to 300/sec and then change to 400, 500, etc as the system continues to try different gain settings. What I would like to do is lock it in at the peak and I have no way of showing that setting (that I can see).
When I run:
sudo systemctl status dump1090-fa -l
Active: active (running) since Mon 2018-12-10 11:17:04 EST; 22h ago
Main PID: 422 (dump1090-fa)
└─422 /usr/bin/dump1090-fa --device-index 0 --gain -10 --ppm 0 --net-bo-port 30005 --max-range 360 --net --
Dec 10 11:17:04 brain1090 systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Dec 10 11:17:04 brain1090 dump1090-fa[422]: Mon Dec 10 11:17:04 2018 EST dump1090-fa 3.6.3 starting up.
Dec 10 11:17:05 brain1090 dump1090-fa[422]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001000)
Dec 10 11:17:05 brain1090 dump1090-fa[422]: Found Rafael Micro R820T tuner
Dec 10 11:17:05 brain1090 dump1090-fa[422]: rtlsdr: enabling tuner AGC
it does not show me the gain in use at this moment, just the -10 in the command line. So with all that said, is there a way for me to show the setting at any given moment?
I get that but what I am trying to do is find out what gain setting is yielding the best results so that I can set that setting in the configuration instead of AGC. I am monitoring the system and I have seen it go from almost 700 messages/sec to 50 messages/sec then back up to 500 messages/sec in the last hour and not in a gradual way that would indicate less traffic in the area so clearly the tuner is running through settings.
AGC when used for ADS-B effectively just ramps up to max gain and sits there (and for obscure reasons the AGC’s “max gain” is slightly higher than what you can manually set). It’s not actually changing the gain in practice. The change in message rate is probably just normal variation (it is very dependent on what the SSRs are doing)
AGC is discouraged because, in most cases, it is too slow to react.
These devices were meant for TV reception, where the signal strength doesn’t vary very much.
A few people have report that it works well for them, however, they are in the minority.
Make RSSI column visible in your SkyView’s Plane table as per instructions below, then click the RSSI column title to sort “High to Low” and “Low to High”.
After sorting “High to Low”, check RSSI column, and if there are too many messages above -3dBFS, reduce gain.
Ended up running the mod that @abcd567 suggested and running through the gain settings one at a time for 10 minutes each. Ended up at 49.6 with minimal numbers of anything over -3dBFS in the list at a glance. Thanks for the help. Attached is my last 24 hours of rate and DbFS higher than -3.
Tuning your settings matters.
Can you tell when I started tinkering with them again?
Next is to change my cable to something ultra low attenuation like LMR400.
Also as you have 2 stations anyway you could choose to set one of them at a gain which would lose you close in aircraft but may capture ones far away better.
Depending on the setup that may not help though if the noise is too strong.
(Increasing gain does not help receiving weaker signals because they drown in noise)
You also need to consider if you are already maxed out due to terrain
My 2nd station is not really a reliable thing to use for me as it is also a testbed/dev station for other Pi stuff. I just happen to run a second receiver on it with a less than optimal receiver & antenna combo because I can.
I did make the changes to the graphs per your suggestion, let us see what comes from them over the next 24 hours and I’ll adjust as necessary from there.
I also plan to move my primary antenna to a better location over the weekend. My house is an A frame and the antenna is on the side of the A instead of at the peak of the A right now. That combined with a lower attenuation cable should add quite a bit to what I am able to see.
Attached is the compass rose map of my coverage. My antenna is on the South East corner of the house and the A frame is blocking direct views to the west and north west. The antenna move will also get the few trees that are in my vicinity out of the way.
