How to Make PiAware Compatible with fr24feed
I have built fr24feed in Debian system, how can I use this device to run PiAware at the same time
Installing dump1090 fa · wiedehopf/adsb-wiki Wiki · GitHub
Or let the script handle it:
Automatic installation for dump1090 fa · wiedehopf/adsb-wiki Wiki · GitHub
Then just install piaware.
Saying debian system, so you’re not using an ARM based computer?
In this case you will need to compile piaware and dump1090-fa.
You can also use piaware with dump1090-mutability as long as that provides beast data on port 30005.
Going that route the above instructions are not valid.
What is your exact setup, what does your /etc/fr24feed.ini look like?
Share your ADS-B data - Real-time flight tracker | Flightradar24.
My Debian system is built on a desktop computer, which is also my NAS.
/etc/fr24feed.ini
receiver=“dvbt”
fr24key=“****************”
bs=“yes”
raw=“yes”
logmode=“2”
mlat=“yes”
mlat-without-gps=“yes”
My fr24feed is working properly, and I want to use this system to run piaware at the same time.
  • First change FR24 setting
    receiver=“dvbt”
    to
    receiver=“beast-tcp”
    host=“127.0.0.1:30005”
  • Next PURGE the dump1090-mutability ver 1.14 which was installed by the fr24feed when it is run in receiver=“dvbt” mode.
    To check it’s existance:
    apt-cache policy dump1090-mutability
    To purge it:
    sudo dpkg --purge dump1090-mutability
  • Last install dump1090-fa and piaware data feeder by following method
Piaware v 3.7.1 on Debian 10.0 (Buster) amd64 / Intel PC
