How to get some historical flight details?
A friend has asked me if I can find some historical flight details - Basically he’s asking for all departures from a specific airport from a couple of years ago over a three month. It’s not a commercial request, he’s just curious.
Am I able to retrieve this somehow? I’d hope that as a contributor, I can retrieve this.
TIA.
I think that you should contact support for data access questions, but I may be wrong. Contact Information - FlightAware
There is a hefty charge depending on the volume requested for that type of info.
For additional flight/airport data, or to be included in our media alerts, please contact marketing@flightaware.com
insert sad face here
Try ADSB Exchange. It’s cheaper, Accessing Data Collected by ADS-B Exchange - ADS-B Exchange
Alternate question - is there a way to get historical info for ‘my’ fed flights ? I would like to get my max range info (when, which aircraft, location, direction/altitude/speed etc.).
I’m running FA on top of vanilla Raspian on a pi4 if that matters, using the instructions at PiAware - dump1090 ADS-B integration with FlightAware - FlightAware - works great but I don’t understand the internals enough to know what I can see from whatever it’s receiving other than using the port 8080 local web interface occasionally.
Install readsb / graphs1090 for a max range outline for the last 24h and some statistics.
(installing readsb will mean you lose the current webinterface you’re using, the feed to FA will keep working fine).
https://github.com/wiedehopf/adsb-wiki/wiki/Raspbian-Lite:-ADS-B-receiver
If you’re interested in something very specific you should start getting into some python programming and parsing aircraft.json which your current webinterface uses, it’s in /run/dump1090-fa/aircraft.json on the pi but also available via http.
(very similar aircraft.json also available from readsb readsb/README-json.md at dev · wiedehopf/readsb · GitHub)
ok - I’ll take a look, thanks. In the interim I found your tar1090 which is interesting as well to show where geographically aircraft appeared at least for a short while at the edges of what my cheapo antenna can detect.
