I would have thought there would be a receiver-type hackrf option.
If I manually start dump1090-fa I can get it to see the hackrf, but it’s not “feeding” it
I have tried this on the command line by itself also to no avail: /usr/share/dump1090-fa/start-dump1090-fa --device-type hackrf --write-json /run/dump1090-mutability/
Are there any documents/links you could point me to as a hint? I tried a fresh install from packages and it still needs some sort of config to get going.
Incidentally, for anyone trying it - the HackRF is lousy at doing this… definitely not the best use case for a HackRF, the cheap dongles do way better.
I wanted to say that… I paid $150 for an Airspy R2 and I though it is a bit too much.
$350 for a HackRF is way out there. Like cracking nuts with a microscope.
