Testing started yesterday 6 Feb 2019. Article below and link to FAA Advisory is in the article.
Thinking about how I might see impacts in the ADS-B data. Anything large/obvious may be easy to see, but more subtle things I’m not so sure how they would show up. I wonder if the ADS-B accuracy/uncertainty/integrity fields would change when GPS interference is active.
Aren’t they exactly for that? Displaying ANP (actual navigation performance)?
As for ADS-B interference, if the interference transmitter is not airborne you have a good chance of not having it in view just like an aircraft on the ground.
Then your station should not be affected.
Yeah, we do see the accuracy metrics drop off when there’s GPS jamming around. Different transponders / avionics setups behave in different ways when they lose GPS entirely so you might see some drop back to dead-reckoning data while others just stop transmitting positions entirely.
Hopefully Galileo will come online next year. It will provide an alternative to the US GPS system.
Not sure how many avionics receivers can use it. Most recent mobile phones support it(Is your phone using Galileo? | GALILEO). Avionics take much longer to update, test and certify.
When I first read about these fields I guessed they were for nominal conditions. I guessed that they reflected a combination of how good the hardware set was, and/or how many satellites it was receiving. But just guessing.
I’m going to go back in ICAO 9871 (2012 edition) to see how they define these fields and if they touch on the impact of ‘interference’. On a quick look, I don’t see this, but I need to go back and take a slower more careful look.
RQ4 doesn’t have jamming capability.
What can be done is to restrict the satellite signal precision or even availability in certain areas, if needed.
The GPS usage was opened to everyone, but don’t forget that is an US Air Force asset.
Russia rebuild their positioning capability after the 90’s, and now they can rely only on those if they want.
