Apparently affecting some flights.
Apologies if this is was posted earlier and I missed it.
https://hackaday.com/2019/06/09/gps-and-ads-b-problems-cause-cancelled-flights/
So apparently ADSB is failing because of the GPS dependency. I thought there was something jamming the 1090 mhz signal. From other research I made apparently “GPS Outage” is misleading, what news outlets are quoting are the “RAIM” maps, which show places where the GPS signal integrity is not perfect.
As I understand it, the RAIM map is a red herring; the “outages” shown are normal and expected (it’s to do with the number of satellites in view).
The actual problem seems to be specific to certain avionics:
ISSUE: CURRENTLY CERTAIN AIRCRAFT EQUIPPED WITH THE ROCKWELL
COLLINS GPS 4000-100 AND SELECT ADS-B OUT GPS RECEIVERS ARE INDICATING
“ADS-B FAIL, UNAVAILABLE, TCAS FAIL OR TRANSPONDER FAIL” MESSAGES.
It’s a software issue triggered by the next leap second appearing in the GPS almanac:
