Thanks again for your help, and, explanations!
Tried briefly AIS using a demo version of an app on a tablet, hot unplugged SDR, plugged into tablet, run the app, couldn’t figure out if I was getting anything useful, so hot plugged back into RPi.
RTL_AIS_driver in demo mode said this:
00:20 ------------------
00:20 11:00:20 eu.ebctech.rtl_sdr_ais_driver Version= 1.1.9 VersionCode= 33
00:22
00:22 #####RequestStartofDriver
00:23 #rtl_sdr_ais_driver Device StartParam:
fd:90 usbfs_path:/dev/bus/usb/001/002 left_freq_hz:161975000 right_freq_hz:162025000 sample_rate:24000 output_rate:48000 dev_index:0 gain_percent:-100 ppm:0 bandwidth:300000 ais_port:10110 ais_host:127.0.0.1 sec_for_decoder_stat:30 edge:0 add_sample_num:0 dc_filter:0 agc:0 show_nmea:1 show_levels:0 show_waterfall:0 demo:1
00:23 Edge tuning disabled.
00:23 DC filter disabled.
00:23 RTL AGC disabled.
00:23 Add Sample Index disabled.
00:23 AIS decoder seconds for stat = 30.
00:23 Buffer size: 163.84 mS
00:23 Downsample factor: 64
00:23 Low pass: 25000 Hz
00:23 Output: 48000 Hz
00:23 Opening device with rtlsdr_open2 deviceidx 0 fd 90 at /dev/bus/usb/001/002
00:23 Found Rafael Micro R820T tuner
00:23 init_ais_decoder
00:23 Log NMEA sentences to console ON
00:23 AIS data will be sent to host 127.0.0.1 port 10110
00:23 ais_host=127.0.0.1 ais_port=10110,show_levels=0,debug_nmea=1,addsample=0,waterfall=0
00:23 Set TUNER GAIN to AUTO GAIN:
00:23 set ppm_error to 0
00:23 set (midle)frequency to 162000000
00:23 set sample rate to 1600000
00:23
Demod Thread start…
00:23 CPU WakeLock acquire
00:23 Cpu wake lock. OK
00:23 Driver Start OK
00:24 !AIVDM,1,1,A,37Ok<vgPCE:lHtWd<sR81
h0170,05E
00:37 !AIVDM,1,1,B,37Ok<UPPC8bkmm1dNg3kjw<20v@,0*4F 00:43 !AIVDM,1,1,,A,17PGTB0P00:l5e5d
:OtKwwp0PRr,00C
00:46 !AIVDM,1,1,A,37P1iG061q:l@FId@6B?ikH0Q1@,0*67 00:53 A: Received correct: 3 | wrong CRC: 9 | wrong size: 3 00:53 B: Received correct: 1 | wrong CRC: 7 | wrong size: 5 00:53 ------------------ 00:53 11:00:53 eu.ebctech.rtl_sdr_ais_driver Version= 1.1.9 VersionCode= 33 00:53 00:53 #####RequestStatusOfDriver 00:53 driver is running 01:12 !AIVDM,1,1,,B,17PGTB0P00:l5dsd
:NLKwwp082,0*6B 01:23 A: Received correct: 3 | wrong CRC: 21 | wrong size: 10 01:23 B: Received correct: 2 | wrong CRC: 13 | wrong size: 7 01:24 !AIVDM,1,1,,B,17PGTc0P01:l5eKd
:dLBOwv0d1m,03D
01:34 !AIVDM,1,1,A,17PGTc0P01:l5eSd:dLBOwv0pDe,0*4F 01:43 !AIVDM,1,1,,A,B7Oe@S000JdtPAs::4kQ3wn5oP06,0*4A 01:45 !AIVDM,1,1,,B,39N
1>5000:l3o;dWm:UcoSb0Dg:,01F
01:53 A: Received correct: 5 | wrong CRC: 29 | wrong size: 17
01:53 B: Received correct: 4 | wrong CRC: 23 | wrong size: 8
01:55 !AIVDM,1,1,A,17PGTc0P00:l5eEd:h<BOwv0PR6,0*41 02:05 !AIVDM,1,1,,B,37OmClPOhBbl6NidWq
5R36:210@,00F
02:21 !AIVDM,1,1,A,H7Og4GQ0E8U05AE<00000000000,046
02:23 A: Received correct: 7 | wrong CRC: 42 | wrong size: 22
02:23 B: Received correct: 5 | wrong CRC: 32 | wrong size: 16
02:32 !AIVDM,1,1,B,17PGTB0P00:l5dcd:MdKwwp0hCJ,0*5B 02:41 !AIVDM,2,1,6,B,59N
1>82E1LCDiKN21<D60P5Lf2222222222216BpND:5nk0F0EH4nA,0*61 !AIVDM,2,2,6,B,888888888888880,2*21 02:42 !AIVDM,1,1,,A,17PGTB0P00:l5e9d
:O<Kwwp0hI,0*79 02:44 !AIVDM,1,1,,A,B7Oe@S000:dtPEs::4oQ3wnUoP06,0*5A 02:53 A: Received correct: 9 | wrong CRC: 56 | wrong size: 28 02:53 B: Received correct: 7 | wrong CRC: 40 | wrong size: 22 02:53 !AIVDM,1,1,,A,37P1iG0tis:lBkMd
D=jaB1b0P00,006
02:55 !AIVDM,1,1,B,17Oh2jPPAF:l8=wdWv2n9Tqf0D1D,01D
02:55 !AIVDM,1,1,A,37OmClP00?bl6eidWqgRu2?h20sP,032
02:59 !AIVDM,1,1,A,37OgOr?PCR:lApcd=4c=pul011@,0*07 03:02 !AIVDM,1,1,,A,17PGTB0P00:l5dwd
:OdKwwp0t2L,025
03:13 !AIVDM,1,1,A,37Oh2jPOiG:l8DudWtN64lpJ00Kh,04D
03:17 !AIVDM,1,1,A,H7Og4GTTCBD:<1V19Ejij>0h731t,025
03:21 !AIVDM,1,1,A,17PGTB0P00:l5dad:PLKwwp0h=4,0*6F 03:23 A: Received correct: 16 | wrong CRC: 65 | wrong size: 34 03:23 B: Received correct: 8 | wrong CRC: 49 | wrong size: 26 03:23 ------------------ 03:23 11:03:23 eu.ebctech.rtl_sdr_ais_driver Version= 1.1.9 VersionCode= 33 03:23 !AIVDM,1,1,,A,37OgOr?PCS:lA1Od
>Lc0pjd0150,0*7E
03:23
03:23 #####RequestStopDriver
03:23
Demod Thread end…
03:23 Stopping was successful!
03:24
User cancel, exiting…
03:24 OK rtl_ais_andro says bye!
03:24 Driver Exit OK
03:24 Wake lock released
03:24 close Android USBDeviceConnection
I guess I should install AIS application on RPi, briefly shut down tar1090, run AIS and see, I noticed there is a lengthy AIS thread, need to read that I think.
