FlightInfoEx returns only 15 results, ignores SetMaximumResultSize
I’ve set the SetMaximumResultSize value to 30 and then run the FlightInfoEx command with howMany=30. I only get 15 back even though there are way more than 15 flights within the past two weeks. I use the same account and key when issuing both commands. When I run SetMaximumResultSize I get this back {“SetMaximumResultSizeResult”:0} which indicates that it should have set it properly.
Any hints at what I’m doing wrong? I know there are only two weeks worth of data for FlightInfoEx, but the flights I try have more than 15 flights in the last two weeks so I would expect more to be returned.
Here is one of the flights I tried:
http://flightxml.flightaware.com/json/FlightXML2/FlightInfoEx?ident=ENY4194&howmany=30&offset=0
howMany must be spelled with an uppercase M for it to be honored.
Arrrg… thanks for catching that!
