FlightAware shows RED on MLAT Feeder Status
Just did the latest upgrade (which I realize may not have been the latest). Current piaware stats:
$ uname -a
Linux piaware 4.14.66-v7+ #1137 SMP Fri Aug 24 16:36:53 BST 2018 armv7l GNU/Linux
$ dpkg -l piaware
ii  piaware        3.6.2        armhf        Open Aviation Data Exchange Proto
Has anyone seen a recent solution to get MLAT stats working again? This was working up until this upgrade.
I spoke too soon. It is NOT fixed. MLAT still shows Red on FA.com.
Any thoughts?
Go to your feeder page on FA, hit the white gear icon on the upper right below the map. Scroll in the log box at the bottom and see what mlat-client messages say.
Here’s what I’ve got. Seems like it’s clean.
[2018-08-28 15:28 CDT] mlat-client(1391): fa-mlat-client 0.2.10 starting up
[2018-08-28 15:28 CDT] mlat-client(1391): Using UDP transport to 70.42.6.197 port 8860
[2018-08-28 15:28 CDT] mlat-client(1391): Listening for Beast-format results connection on port 30105
[2018-08-28 15:28 CDT] mlat-client(1391): Listening for Extended Basestation-format results connection on port 30106
[2018-08-28 15:28 CDT] mlat-client(1391): Input connected to localhost:30005
[2018-08-28 15:28 CDT] mlat-client(1391): Input format changed to BEAST, 12MHz clock
[2018-08-28 15:28 CDT] mlat-client(1391): Beast-format results connection with ::1:30104: connection established
Looks like you just restarted, or this is the very top pf the log. Let things run for 5 or 10 minutes then look near the bottom for:
[2018-08-28 13:49 PDT] mlat-client(594): Receiver status: connected
[2018-08-28 13:49 PDT] mlat-client(594): Server status: synchronized with 324 nearby receivers
Unstable clock. Check you have the correct position set; check your power and USB connections.
Few more things. Still showing red. Here’s a couple more items from the log file pulled right off the device (note these are UTC, not CDT)
Aug 28 20:43:24 piaware piaware[1367]: mlat-client(1391): Receiver status: connected
Aug 28 20:43:24 piaware piaware[1367]: mlat-client(1391): Server status:   clock unstable
Aug 28 20:43:24 piaware piaware[1367]: mlat-client(1391): Receiver:  645.6 msg/s received      185.8 msg/s processed (29%)
Aug 28 20:43:24 piaware piaware[1367]: mlat-client(1391): Server:      0.1 kB/s from server    0.0kB/s TCP to server     2.1kB/s UDP to server
Aug 28 20:43:24 piaware piaware[1367]: mlat-client(1391): Results:  43.7 positions/minute
Aug 28 20:43:24 piaware piaware[1367]: mlat-client(1391): Aircraft: 62 of 113 Mode S, 50 of 75 ADS-B used
Aug 28 20:58:25 piaware piaware[1367]: mlat-client(1391): Receiver status: connected
Aug 28 20:58:25 piaware piaware[1367]: mlat-client(1391): Server status:   clock unstable
Aug 28 20:58:25 piaware piaware[1367]: mlat-client(1391): Receiver:  581.9 msg/s received      171.7 msg/s processed (30%)
Aug 28 20:58:25 piaware piaware[1367]: mlat-client(1391): Server:      0.0 kB/s from server    0.0kB/s TCP to server     2.0kB/s UDP to server
Aug 28 20:58:25 piaware piaware[1367]: mlat-client(1391): Aircraft: 52 of 95 Mode S, 53 of 74 ADS-B used
I’m going to double check the connections right now.
Also, the position is correctly set on FA.com. Is there another location in a config file somewhere that I need to post it?
All connections look solid. Just started happening once I upgraded to 3.6.2.
OK it’s temporarily back to green. Let’s see if it holds.
