Hello all. I have a weird problem and I have no idea how to begin troubleshooting.
I have a RTL-SDR stick v3 (no filter), controlled by a Rpi 2, connected with ethernet. Works as good as possible with a dipole antenna with respect to obstacles, gain, etc. Near no problem.
Then I asked one of my friends to give me a blue FlightAware stick to test, I was curious about differences.
But afther replacement things got worse. Way worse. The blue stick is reporting more than 99% of messages received as Mode S with no position information.
Then troubleshooting: gain changed from 20 to 49 manually, no effect. RTL-SDR had a 5m USB cable, working just fine, changed this with a new 1.8m cable, no improvment.
I am using the same dipole antenna which on RTL-SDR reported up to 90nm, usually around 60-ish. This antenna on the blue stick reported a maximum 38nm.
Checked the antenna itself, no problem.
Then while receiving a specific plane, changed the FA blue receiving ModeS messages with RTL-SDR which was decoding ADSB messages now. Sure, RSSI was lower, but that is expected.
From a software perspective, nothing changed, seems all working as it supposed to be.
Any ideas?
The RTL-SDR v3 has a metal case.
Maybe you have a lot of noise and need to use a dongle with a metal case to reduce the noise.
You can buy the cases on their own, except they are currently out of stock.
You could try to move the dongle to the metal case used by the RTL-SDR v3.
https://www.rtl-sdr.com/buy-rtl-sdr-dvb-t-dongles/
You could also try lowering gain even more.
Of course, noise cannot be ruled out. It’s near my computer, a laptop and of course Rpi. I tried to switch the computer and monitor off during night to see if I gain something, but nothing.
The stick is connected to the dipole antenna with a very short cable, around 4cm. A support made from plastic vice (one handed clamp from Volfcraft) is squeezing the USB connector enough to support the stick and dipole assembly. This clamp is supported itself by an aluminium pole which in turn is clamped to the table. This whole assembly does not seem to interfere with antenna since the RTL-SDR is working as good as possible.
Since I loan this stick I won’t be so happy to replace the case for troubleshooting. And investing in a new stick just to replace the case is not so encouraging.
Some people have reported almost no reception with the FA ProStick+ due to interference from FM or TV or mobile towers.
If the interference is above a certain threshold, it seems that the LNA overloads and useful reception becomes impossible.
Either add a filter in front, or just continue using your current setup.
The blue version includes the filter already. Adding another filter just increses loss.
While de RTL-SDR does not include the filter, it works better.
That is why I think this is not the problem.
The LNA is located before the filter. So if it starts to overload you just lose your signal at that point.
Also a filter only attenuates, so it can be useful to use a 2nd filter for strong interference.
Its strange to overload the LNA with a half wave dipole whose gain is not much.
As for strong interference, that should prevent RTL-SDR working without filter.
Is your dipole cut for 1090MHz or another frequency?
The RTL-SDR does not have a preamp built in.
The Prostick plus has a 20dB preamp before the filter.
I run a Prostick Plus here and I need additional filtering to prevent the internal preamp overloading and reducing performance in exactly the way you have seen.
Do you know the specifications of the components used and how easily they overload?
@LawrenceHill Yes, homemade dipole for 1090. On RTL-SDR has good performance, seen more than 90nm. What is strange is the RSSI seems to stop about -17 or -18db while RTL-SDR goes lower. I will try to add a FM filter in front of it to introduce a small loss.
@wiedehopf no idea about the components. The blue stick has a warranty sticker on it and because is not mine I don’t want to open it.
Try a home made Spider for 1090.
Compared to dipole, It will give better:
- message count
- aircraft count
- max. range
QUICK SPIDER - No Soldering, No Connector
@abcd567 I have materials ordered for a collinear from RG213. A spider was on plan but won’t be that soon.
Now I added a FM filter in front (from RTL-SDR) and tried gains of 20.7 22.9 25.4. At 25.4 I lost the plane around 20nm away so I need more tests. But for the time being I had ADSB messages with location with lower RSSI, which is a step ahead.
FM (88 ~ 108 Mhz) is far away from 1090 mhz, and unlikely to affect it unless you have an FM transmitter nearby.
It is the Cell/Moble signal which is prime suspect for interfering with 1090 Mhz as GSM850 and GSM900 are very close to 1099 Mhz.
You can determine existance of these signals by a simple scan described in this post:
Do I Need A Filter?
I changed antenna with a previously known working CoCo which is more selective (based on scan results). Same result overall.
For the moment I have nothing more to change, hopefully soon I will make another CoCo based on a thick coaxial.
But for the moment the conclusion is … waste of time.
Either this particular example is bad or there is something wrong which I can’t figure out.
A bit later edit: the blue stick cannot decode nothing below RSSI -18, while most of the messages are mode S. RTL-SDR goes below -30 (seen -33.9) and same messages from the same plane are ADSB.
I found that the voltage at the stick input sometimes was below 4.4. Changed the power supply, now I get some proper ADSB messages decoded, but only from less than 20nm away which is weird. Gain was 29.7
I am working on a collinear antenna made out of RG214 with VF of 0.66 to see if that changes something. Should have a narrow bandwidth.
That sounds pretty low to me.
What happens if you set the gain higher?
I had no planes to try more gain. However, the plane was less than 10nm away at low atitude.
Probably high RF issues - overloading the receiver. (Nearby cell sites etc) Locate the discussion topic “Do I need a filter” and consider some of the testing suggested there to see what may be impacting your install.
Done that already. I think this is not the cause, see above.
well, the issues you describe are common outcome for the overload of the received by RF, and several people who have helped many others on the forum with very similar issues have already suggested consideration of that thread.
Maybe take the time to run the spectrum scan and post the output for others to review the RF conditions in your location and then someone can provide you with advice that is specific you your RF environmental conditions.
