Runs on every platform - Windows, Linux, Mac - install now super-easy - see Howto below
Boeing 787 Dreamliner above lake Chiemsee/Bavaria heading south over the Alps:
setup starts with a fresh raspbian stretch-lite image:
passwd
sudo raspi-config
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install php7.0-common php7.0-cgi php7.0-mysql php7.0-sqlite php7.0-curl php7.0 php7.0-xml php7.0-zip php7.0-gd php7.0-json
sudo apt-get install mysql-server mysql-client
sudo mysql -u root -p (leave password empty)
update mysql.user set password=password('YOUR_DB_PASSWORD') where user='root';
update mysql.user set plugin='' where user='root';
flush privileges;
sudo mysql -u root -p (use password you entered above)
create database flightairmap;
ctrl + z
sudo apt-get install build-essential debhelper librtlsdr-dev libusb-1.0-0-dev pkg-config tcl8.5-dev autoconf python3-dev python-virtualenv libz-dev git tclx8.4 tcllib tcl-tls itcl3 htop
mkdir dump1090-mutability
cd dump1090-mutability/
git clone https://github.com/mutability/dump1090.git
cd dump1090/
dpkg-buildpackage -b
cd ..
sudo dpkg -i dump1090-mutability_1.15~dev_armhf.deb
cd ~
git clone https://github.com/flightaware/dump1090.git
sudo cp -r dump1090/public_html /usr/share/dump1090-mutability/public_html
cd /usr/share/dump1090-mutability
sudo mv html original-html
sudo mv public_html html
cd html
sudo mv index.html gmap.html
sudo wget -O /etc/udev/rules.d/rtl-sdr.rules "https://raw.githubusercontent.com/osmocom/rtl-sdr/master/rtl-sdr.rules"
sudo dpkg-reconfigure dump1090-mutability
sudo shutdown -r now
sudo apt-get install lighttpd
sudo lighty-enable-mod dump1090
sudo lighty-enable-mod fastcgi
sudo lighty-enable-mod fastcgi-php
sudo service lighttpd force-reload
sudo nano /etc/php/7.0/cgi/php.ini
-> set max_execution_time to 0 within php.ini
cd /var/www/html
sudo git clone --depth=1 http://github.com/ysurac/flightairmap
sudo chmod 666 flightairmap/require/settings.php
sudo chmod 777 flightairmap/install/tmp
sudo chmod 777 flightairmap/data
sudo chmod 777 flightairmap/images/airlines
sudo cp /var/www/html/flightairmap/install/89-flightairmap-lighttpd.conf /etc/lighttpd/conf-available
sudo nano /etc/lighttpd/conf-available/89-flightairmap-lighttpd.conf (alter pathes to match your path)
sudo lighty-enable-mod flightairmap-lighttpd
sudo /etc/init.d/lighttpd force-reload
sudo cp /var/www/html/flightairmap/install/init/flightairmap.service.systemd /etc/systemd/system/flightairmap.service
sudo nano /etc/systemd/system/flightairmap.service (alter pathes to match your path)
sudo chmod 644 /etc/systemd/system/flightairmap.service
sudo systemctl enable flightairmap.service
sudo crontab -e (add the below 3 lines to crontab)
# run flightairmap daemons
0 2 * * * /usr/bin/php /var/www/html/flightairmap/scripts/update_db.php > /dev/null
#@reboot sleep 10 && /usr/bin/php /var/www/html/flightairmap/scripts/daemon-spotter.php > /dev/null
=> run installer in browser http://127.0.0.1/flightairmap/install
I am trying to install on RPI and ubuntu following the official guide as well as the step by step described here but i always end up with this:
It seems that i’m missing something. Can someone give me hint? Chrome developer tools shows this:
whats in flightairmap/require/settings.php variable $globalURL set?
// GLOBAL URL
$globalURL = ‘/flightairmap’;
and what url do you use to open flightairmap, what webserver?
I used http://192.168.1.201/install to do the initial setup which went ok , but the portal does not work (http://192.168.1.201)
still lost in 3d ![]()
apache2 with php 7
Tried $globalURL = ‘’; and now it works.
Hi, i am trying to install to strecth-lite image, followed your guide but installer says:
Error The directory data must be writable to scripts/update_db.php user.
The directory images/airlines must be writable for IVAO.
domefin - just ignore this
thanks for the info!
do i need uncomment “#@reboot sleep 10 && /usr/bin/php /var/www/html/flightairmap/scripts/daemon-spotter.php > /dev/null” ?
normally not this is just meant to be a backup method if someone fails to setup a system-service or does not want to run daemon-spotter.php as system-service.
if there is a problem with these two directories simply set them both to 777
Nice, special thanks to TomMuc! Running nicely on RPI 3. Do you guys know if it is possible to show distance between aircraft and receiver? I really like to see range and performance of my receiver…
message rate, distance and table of current aircrafts at the moment skyview is still the better option http://127.0.0.1/dump1090/gmap.html
have fun ![]()
the developer of FlightAirMaps added a new and more comprehensive install howto for raspbian: Raspbian · Ysurac/FlightAirMap Wiki · GitHub
I followed developer’s instructions and use the script for installation. Everything went well but I don’t see any aircraft. My sbs3 (network setup) is working properly as I can see data from it in Basestation. I assume I must have made some mistake in either entering it’s IP or port. Do you know if there is any data setting file on the pi where I can check that?
I didn’t install dump1090 since I believe FlightAirMaps can fetch data directly from an SBS receiver.
flightairmap/require/settings.php you find your settings. is daemon-spotter.php running as service or cronjob?
if your stats within flightairmaps are filling with data while you do not see aircrafts - then sth. with your webserver setup is wrong.
