radar.php
#!/usr/bin/php
<?php
#phpinfo();
#var_dump(ini_get_all());
#ini_set('error_reporting', E_ALL);
// below a sample create statement for database table
// CREATE TABLE aircrafts (id INT NOT NULL AUTO_INCREMENT, message_date VARCHAR(100), now VARCHAR(100), hex VARCHAR(100), flight VARCHAR(100), distance VARCHAR(100), altitude VARCHAR(100), lat VARCHAR(100), lon VARCHAR(100), track VARCHAR(100), speed VARCHAR(100), vert_rate VARCHAR(100), seen_pos VARCHAR(100), seen VARCHAR(100), rssi VARCHAR(100), messages VARCHAR(100), category VARCHAR(100), squawk VARCHAR(100), nucp VARCHAR(100), mlat VARCHAR(100), tisb VARCHAR(100), rec_msg_sec VARCHAR(100), PRIMARY KEY (id))
// set the rectangle and altitude to store aircraft-data in database - if your lon is negative be aware to use the right values for max and min
$user_set_array['max_lat'] = 50.000000; $user_set_array['min_lat'] = 46.000000; $user_set_array['max_alt'] = 10000;
$user_set_array['max_lon'] = 14.000000; $user_set_array['min_lon'] = 10.000000;
// set the rectangle and altitude to send alert message - if your lon is negative be aware to use the right values for max and min
$user_set_array['alert_max_lat'] = 49.000000; $user_set_array['alert_min_lat'] = 47.000000; $user_set_array['alert_max_alt'] = 5000;
$user_set_array['alert_max_lon'] = 13.000000; $user_set_array['alert_min_lon'] = 11.000000;
// set lookup-interval default is 1 (must be integer between 1 - 900) this is the frequency the script runs and writes to database or looks for alerts
$user_set_array['sleep'] = 1;
// set your google email-address for alert-messages - if you want to use mailer.php instead gmail set method 'gmail' to 'webmail' or 'pushover' and a key according to mailer.php
$user_set_array['alert_method'] = 'gmail'; $user_set_array['email_address'] = 'YOUR_EMAIL@gmail.com'; $user_set_array['secret_email_key'] = 'YOUR_USER_KEY';
// set parameters for database connection
$user_set_array['db_name'] = 'adsb'; $user_set_array['db_host'] = '127.0.0.1'; $user_set_array['db_user'] = 'USERNAME'; $user_set_array['db_pass'] = 'PASSWORD';
// set path to aircraft.json file
$user_set_array['url_json'] = 'http://127.0.0.1/dump1090/data/';
// set path to your mailer.php file
$user_set_array['url_mailer'] = 'http://YOUR_WEBSPACE.COM/mailer.php';
// set the absolute limit of alert-messages (default is 1000) this script is allowed to send over its whole runtime
$user_set_array['mailer_limit'] = 1000;
// set aircraft suspend time (default is 900) - change only if needed - time in seconds an aicraft is suspended from alert-messages after sending an alert-message for this aircraft
$user_set_array['aircraft_suspend_time'] = 900;
// set this to true if you want alerts and/or database writes from those aircrafts matching your hex_code_array.txt or flight_code_array.txt files within limited area or whole site-range, with or without wildcards
$user_set_array['filter_mode_alert'] = false; $user_set_array['filter_mode_alert_limited'] = false;
$user_set_array['filter_mode_database'] = false; $user_set_array['filter_mode_database_limited'] = false;
$user_set_array['filter_mode_wildcard'] = false;
// set path to your hex_code_array.txt and flight_code_array.txt files
$user_set_array['hex_file_path'] = '/home/pi/hex_code_array.txt';
$user_set_array['flight_file_path'] = '/home/pi/flight_code_array.txt';
// set your timezone see http://php.net/manual/en/timezones.php
$user_set_array['time_zone'] = 'America/Chicago';
// wildcard search function for external filter data
function func_wildcard_search($code, $user_code_array, $wildcard_mode) {
$match = false;
$code = strtoupper($code);
if ($wildcard_mode) {
foreach ($user_code_array as $pattern) {
if (preg_match('/^' . trim($pattern) . '$/', $code)) $match = true;
} else {
$user_code_array = array_map('trim', $user_code_array);
if (in_array($code, $user_code_array)) $match = true;
return $match;
// function to compute distance between receiver and aircraft
function func_haversine($lat_from, $lon_from, $lat_to, $lon_to, $earth_radius = 3440) {
$delta_lat = deg2rad($lat_to - $lat_from);
$delta_lon = deg2rad($lon_to - $lon_from);
$a = sin($delta_lat / 2) * sin($delta_lat / 2) + cos(deg2rad($lat_from)) * cos(deg2rad($lat_to)) * sin($delta_lon / 2) * sin($delta_lon / 2);
$c = 2 * atan2(sqrt($a), sqrt(1-$a));
return $earth_radius * $c;
$i = 0;
$alert_message = '';
$sent_alert_messages = 0;
$alert_trigger_array = array();
$start_time = time();
date_default_timezone_set($user_set_array['time_zone']);
// fetch receiver.json and read receiver latitude and longitude
$json_receiver_location = json_decode(file_get_contents($user_set_array['url_json'] . 'receiver.json'), true);
isset($json_receiver_location['lat']) ? $rec_lat = $json_receiver_location['lat'] : $rec_lat = 0;
isset($json_receiver_location['lon']) ? $rec_lon = $json_receiver_location['lon'] : $rec_lon = 0;
while (true) {
$x = 0;
$sql = '';
$start_loop_microtime = microtime(true);
// fetch aircraft.json and read timestamp and overall message number
$json_data_array = json_decode(file_get_contents($user_set_array['url_json'] . 'aircraft.json'), true);
isset($json_data_array['now']) ? $ac_now = $json_data_array['now'] : $ac_now = '';
isset($json_data_array['messages']) ? $ac_messages_total = $json_data_array['messages'] : $ac_messages_total = '';
// fetch and read external filter data files
if ($user_set_array['filter_mode_alert'] || $user_set_array['filter_mode_database']) {
$hex_code_array = explode(',', str_replace('%', '.', strtoupper(file_get_contents($user_set_array['hex_file_path']))));
$flight_code_array = explode(',', str_replace('%', '.', strtoupper(file_get_contents($user_set_array['flight_file_path']))));
// compute receiver message rate averaged over 30 seconds
$message_rate_array[] = array('messages' => $ac_messages_total, 'time' => $ac_now);
if (time() - $message_rate_array[0]['time'] > 30) array_shift($message_rate_array);
$delta_message_number = $message_rate_array[count($message_rate_array) - 1]['messages'] - $message_rate_array[0]['messages'];
$delta_message_time = $message_rate_array[count($message_rate_array) - 1]['time'] - $message_rate_array[0]['time'];
$delta_message_time > 0 ? $message_rate = round($delta_message_number / $delta_message_time, '1') : $message_rate = 0;
// loop through aircraft section of aircraft.json file
foreach ($json_data_array['aircraft'] as $row) {
isset($row['hex']) ? $ac_hex = $row['hex'] : $ac_hex = '';
isset($row['flight']) ? $ac_flight = trim($row['flight']) : $ac_flight = '';
isset($row['altitude']) ? $ac_altitude = $row['altitude'] : $ac_altitude = '';
isset($row['lat']) ? $ac_lat = $row['lat'] : $ac_lat = '';
isset($row['lon']) ? $ac_lon = $row['lon'] : $ac_lon = '';
isset($row['track']) ? $ac_track = $row['track'] : $ac_track = '';
isset($row['speed']) ? $ac_speed = $row['speed'] : $ac_speed = '';
isset($row['vert_rate']) ? $ac_vert_rate = $row['vert_rate'] : $ac_vert_rate = '';
isset($row['seen_pos']) ? $ac_seen_pos = $row['seen_pos'] : $ac_seen_pos = '';
isset($row['seen']) ? $ac_seen = $row['seen'] : $ac_seen = '';
isset($row['rssi']) ? $ac_rssi = $row['rssi'] : $ac_rssi = '';
isset($row['messages']) ? $ac_messages = $row['messages'] : $ac_messages = '';
isset($row['category']) ? $ac_category = $row['category'] : $ac_category = '';
isset($row['squawk']) ? $ac_squawk = $row['squawk'] : $ac_squawk = '';
isset($row['nucp']) ? $ac_nucp = $row['nucp'] : $ac_nucp = '';
isset($row['mlat']) ? $ac_mlat = implode(' ', $row['mlat']) : $ac_mlat = '';
isset($row['tisb']) ? $ac_tisb = implode(' ', $row['tisb']) : $ac_tisb = '';
$ac_lat && $ac_lon ? $ac_dist = round(func_haversine($rec_lat, $rec_lon, $ac_lat, $ac_lon), 1) : $ac_dist = '';
// generate sql insert statement per aircraft in range of user set altitude/latitude/longitude and optionally according only to hex or flight numbers in hex_code_array.txt and flight_code_array.txt
#var_dump($hex_code_array); var_dump($flight_code_array); // show arrays for debug
if ($user_set_array['filter_mode_database'] && $user_set_array['filter_mode_database_limited']) {
if (($ac_altitude != '' && $ac_altitude < $user_set_array['max_alt'] && $ac_lat < $user_set_array['max_lat'] && $ac_lat > $user_set_array['min_lat'] && $ac_lon < $user_set_array['max_lon'] && $ac_lon > $user_set_array['min_lon']) && (func_wildcard_search($ac_hex, $hex_code_array, $user_set_array['filter_mode_wildcard']) || ($ac_flight != '' && func_wildcard_search($ac_flight, $flight_code_array, $user_set_array['filter_mode_wildcard'])))) {
$sql .= "INSERT INTO aircrafts VALUES (NULL, '" . date("Y-m-d G:i:s l", $ac_now) . "', '$ac_now', '$ac_hex', '$ac_flight', '$ac_dist', ";
$sql .= "'$ac_altitude', '$ac_lat', '$ac_lon', '$ac_track', '$ac_speed', '$ac_vert_rate', '$ac_seen_pos', '$ac_seen', ";
$sql .= "'$ac_rssi', '$ac_messages', '$ac_category', '$ac_squawk', '$ac_nucp', '$ac_mlat', '$ac_tisb', '$message_rate');";
$sql .= PHP_EOL;
$x++;
} else if ($user_set_array['filter_mode_database']) {
if (($ac_altitude != '' && $ac_altitude < $user_set_array['max_alt'] && $ac_lat < $user_set_array['max_lat'] && $ac_lat > $user_set_array['min_lat'] && $ac_lon < $user_set_array['max_lon'] && $ac_lon > $user_set_array['min_lon']) || (func_wildcard_search($ac_hex, $hex_code_array, $user_set_array['filter_mode_wildcard']) || ($ac_flight != '' && func_wildcard_search($ac_flight, $flight_code_array, $user_set_array['filter_mode_wildcard'])))) {
$sql .= PHP_EOL;
$x++;
} else {
if ($ac_altitude != '' && $ac_altitude < $user_set_array['max_alt'] && $ac_lat < $user_set_array['max_lat'] && $ac_lat > $user_set_array['min_lat'] && $ac_lon < $user_set_array['max_lon'] && $ac_lon > $user_set_array['min_lon']) {
$sql .= PHP_EOL;
$x++;
// set and modify alert-trigger-array and build alert-message optionally according only to hex or flight numbers in hex_code_array.txt and flight_code_array.txt
if ($user_set_array['filter_mode_alert'] && $user_set_array['filter_mode_alert_limited']) {
if (($ac_altitude != '' && $ac_altitude < $user_set_array['alert_max_alt'] && $ac_lat < $user_set_array['alert_max_lat'] && $ac_lat > $user_set_array['alert_min_lat'] && $ac_lon < $user_set_array['alert_max_lon'] && $ac_lon > $user_set_array['alert_min_lon']) && (func_wildcard_search($ac_hex, $hex_code_array, $user_set_array['filter_mode_wildcard']) || ($ac_flight != '' && func_wildcard_search($ac_flight, $flight_code_array, $user_set_array['filter_mode_wildcard'])))) {
if (!array_key_exists($ac_hex, $alert_trigger_array)) {
$alert_message_subject = urlencode('### STRAFER-ALERT ### ' . $ac_flight . ' ' . $ac_hex . ' : ' . $ac_dist . 'Nm ' . $ac_lat . ' ' . $ac_lon . ' : ' . $ac_altitude . 'ft @ ' . date('Y-m-d G:i:s l', $ac_now));
$alert_message_body = urlencode($ac_flight . ' ' . $ac_hex . ' : ' . $ac_dist . 'Nm <a href="http://www.google.com/maps/place/' . $ac_lat . ',' . $ac_lon . '/@' . $ac_lat . ',' . $ac_lon . ',12z">' . $ac_lat . ' ' . $ac_lon . '</a> : ' . $ac_altitude . 'ft @ ' . date('Y-m-d G:i:s l', $ac_now));
$alert_message = 'key=' . $user_set_array['secret_email_key'] . '&subject=' . $alert_message_subject . '&body=' . $alert_message_body;
if ($ac_hex) {
$alert_trigger_array[$ac_hex] = time();
#var_dump($alert_trigger_array); // show array for debug
} else if ($user_set_array['filter_mode_alert']) {
if (($ac_altitude != '' && $ac_altitude < $user_set_array['alert_max_alt'] && $ac_lat < $user_set_array['alert_max_lat'] && $ac_lat > $user_set_array['alert_min_lat'] && $ac_lon < $user_set_array['alert_max_lon'] && $ac_lon > $user_set_array['alert_min_lon']) || (func_wildcard_search($ac_hex, $hex_code_array, $user_set_array['filter_mode_wildcard']) || ($ac_flight != '' && func_wildcard_search($ac_flight, $flight_code_array, $user_set_array['filter_mode_wildcard'])))) {
if ($ac_hex) {
} else {
if ($ac_altitude != '' && $ac_altitude < $user_set_array['alert_max_alt'] && $ac_lat < $user_set_array['alert_max_lat'] && $ac_lat > $user_set_array['alert_min_lat'] && $ac_lon < $user_set_array['alert_max_lon'] && $ac_lon > $user_set_array['alert_min_lon']) {
if ($ac_hex) {
// delete aircraft after user set seconds from already-message-sent-trigger
$outdated_entry = time() - $user_set_array['aircraft_suspend_time'];
foreach ($alert_trigger_array as $key => $value) {
if ($value < $outdated_entry) {
unset($alert_trigger_array[$key]);
// send alert-message according to absolute limit for maximum number of messages and reset alert-message
if ($alert_message != '' && $sent_alert_messages < $user_set_array['mailer_limit']) {
if ($user_set_array['alert_method'] == 'gmail') {
$email = $user_set_array['email_address'];
$header = 'MIME-Version: 1.0' . PHP_EOL;
$header .= 'Content-type: text/html; charset=iso-8859-1' . PHP_EOL;
$header .= 'From: ' . $user_set_array['email_address'] . PHP_EOL;
$header .= 'Reply-To: ' . $user_set_array['email_address'] . PHP_EOL;
$header .= 'X-Mailer: PHP ' . phpversion();
mail($user_set_array['email_address'], urldecode($alert_message_subject), urldecode($alert_message_body), $header);
} else if ($user_set_array['alert_method'] == 'pushover') {
file_get_contents($user_set_array['url_mailer'] . '?mode=pushover&' . $alert_message);
} else if ($user_set_array['alert_method'] == 'webmail') {
file_get_contents($user_set_array['url_mailer'] . '?mode=webmail&' . $alert_message);
$sent_alert_messages++;
// if db connection is ok write selected aircraft data to database
try {
$db = new PDO('mysql:host=' . $user_set_array['db_host'] . ';dbname=' . $user_set_array['db_name'] . '', $user_set_array['db_user'], $user_set_array['db_pass']); $db_insert = '';
$db->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
if ($sql) { $db->exec($sql); $db_insert = 'inserted'; }
$db = null;
} catch (PDOException $db_error) {
$db_insert = 'db-error' . PHP_EOL . $db_error->getMessage();
// generate terminal output and set sleep timer to get minimum a full second until next aircraft.json is ready to get fetched
$runtime = (time() - $start_time);
$runtime_formatted = sprintf('%d days %02d:%02d:%02d', $runtime/60/60/24,($runtime/60/60)%24,($runtime/60)%60,$runtime%60);
($runtime > 0) ? $loop_clock = number_format(round(($i / $runtime),6),6) : $loop_clock = number_format(1, 6);
$process_microtime = (round(1000000 * (microtime(true) - $start_loop_microtime)));
print('upt(us): ' . sprintf('%07d', $process_microtime) . ' - ' . $loop_clock . ' loops/s avg - since ' . $runtime_formatted . ' - run ' . $i . ' @ ' . number_format($message_rate, '1', ',', '.') . ' msg/s -> ' . sprintf('%03d', $x) . ' dataset(s) => ' . $db_insert . PHP_EOL);
sleep($user_set_array['sleep']);
$i++;
sample hex_code_array.txt
hex1, hex2, hex3
sample flight_code_array.txt
flight1, flight2, flight3
mailer.php
<?php
#phpinfo();
// set key (letters/numbers only) according to the key you set in radar.php
$user_key = 'YOUR_USER_KEY';
// set your email address if you want to use email alert
$user_email = 'YOUR_EMAIL@EMAIL.COM';
// set your pushover token and key if you want to use pushover alert
$pushover_api_token = 'YOUR_API_TOKEN'; $pushover_user_key = 'YOUR_USER_KEY';
isset($_GET['key']) ? $key = $_GET['key'] : $key = '';
isset($_GET['mode']) ? $mode = $_GET['mode'] : $mode = '';
isset($_GET['subject']) ? $subject = urldecode($_GET['subject']) : $subject = '';
isset($_GET['body']) ? $body = urldecode($_GET['body']) : $body = '';
if ($key == $user_key && $mode == 'webmail') {
$header .= 'From: ADS-B RADAR' . PHP_EOL;
$header .= 'Reply-To: ' . $user_email . PHP_EOL;
$header .= 'X-Mailer: PHP '. phpversion();
mail($user_email, $subject, $body, $header);
} else if ($key == $user_key && $mode == 'pushover') {
curl_setopt_array($ch = curl_init(), array(
CURLOPT_URL => 'https://api.pushover.net/1/messages.json',
CURLOPT_POSTFIELDS => array('token' => $pushover_api_token, 'user' => $pushover_user_key, 'message' => $body, 'html' => '1'),
CURLOPT_SAFE_UPLOAD => true,
CURLOPT_RETURNTRANSFER => true,
curl_exec($ch);
curl_close($ch);
