dev444
September 29, 2009, 5:26pm
1
Currently, the Enroute method returns flights which have “0” as the departure time (aren’t in the air), but the definition from the Enroute method should exclude those flights:
Enroute returns information about flights already in the air for the specified airport and maximum number of flights to be returned. Enroute flights are returned from soonest estimated arrival to least soon estimated arrival.
–dev444
dbaker
September 29, 2009, 5:49pm
2
Can you post an example for us to work with?
dev444
September 30, 2009, 3:05am
3
Sure!
Method: Enroute
Airport: KSAN
howMany: 15
Offset: 3
Filter: [no filter]
Results (See SKW6342, SWA1937):
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:FlightAwareDirectFlight="http://directflight.flightaware.com/soap/DirectFlight">
<SOAP-ENV:Body>
<ns:EnrouteResponse SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns="FlightAwareDirectFlight">
<return xsi:type="FlightAwareDirectFlight:EnrouteStruct">
<next_offset xsi:type="xsd:int">18</next_offset>
<enroute xsi:type="SOAP-ENC:Array" SOAP-ENC:offset="[0]" SOAP-ENC:arrayType="FlightAwareDirectFlight:EnrouteFlightStruct[15]">
<item xsi:type="FlightAwareDirectFlight:EnrouteFlightStruct">
<ident xsi:type="xsd:string">AWE191</ident>
<aircrafttype xsi:type="xsd:string">A320</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254276480</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254276480</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254279900</estimatedarrivaltime>
<origin xsi:type="xsd:string">KPHX</origin>
<destination xsi:type="xsd:string">KSAN</destination>
<originName xsi:type="xsd:string">Phoenix Sky Harbor Intl</originName>
<originCity xsi:type="xsd:string">Phoenix, AZ</originCity>
<destinationName xsi:type="xsd:string">San Diego Intl</destinationName>
<destinationCity xsi:type="xsd:string">San Diego, CA</destinationCity>
</item>
<ident xsi:type="xsd:string">ASA572</ident>
<aircrafttype xsi:type="xsd:string">B737</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254272460</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254272160</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254280320</estimatedarrivaltime>
<origin xsi:type="xsd:string">KPDX</origin>
<originName xsi:type="xsd:string">Portland Intl</originName>
<originCity xsi:type="xsd:string">Portland, OR</originCity>
</item>
<ident xsi:type="xsd:string">UAL395</ident>
<aircrafttype xsi:type="xsd:string">A319</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254265860</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254265080</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254280380</estimatedarrivaltime>
<origin xsi:type="xsd:string">KORD</origin>
<originName xsi:type="xsd:string">Chicago O'Hare Intl</originName>
<originCity xsi:type="xsd:string">Chicago, IL</originCity>
</item>
<ident xsi:type="xsd:string">AAL225</ident>
<aircrafttype xsi:type="xsd:string">B752</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254260100</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254259920</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254280980</estimatedarrivaltime>
<origin xsi:type="xsd:string">KBOS</origin>
<originName xsi:type="xsd:string">Boston Logan Intl</originName>
<originCity xsi:type="xsd:string">Boston, MA</originCity>
</item>
<ident xsi:type="xsd:string">SWA1781</ident>
<aircrafttype xsi:type="xsd:string">B733</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254273120</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254273360</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281100</estimatedarrivaltime>
<origin xsi:type="xsd:string">KDEN</origin>
<originName xsi:type="xsd:string">Denver Intl</originName>
<originCity xsi:type="xsd:string">Denver, CO</originCity>
</item>
<ident xsi:type="xsd:string">AWE155</ident>
<aircrafttype xsi:type="xsd:string">A321</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254262980</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254262620</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281220</estimatedarrivaltime>
<origin xsi:type="xsd:string">KPHL</origin>
<originName xsi:type="xsd:string">Philadelphia Intl</originName>
<originCity xsi:type="xsd:string">Philadelphia, PA</originCity>
</item>
<ident xsi:type="xsd:string">ASA498</ident>
<aircrafttype xsi:type="xsd:string">B734</aircrafttype>
<filed_departuretime xsi:type="xsd:int">1254272520</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281340</estimatedarrivaltime>
<origin xsi:type="xsd:string">KSEA</origin>
<originName xsi:type="xsd:string">Seattle-Tacoma Intl</originName>
<originCity xsi:type="xsd:string">Seattle, WA</originCity>
</item>
<ident xsi:type="xsd:string">AWE198</ident>
<actualdeparturetime xsi:type="xsd:int">1254264300</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254263940</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281400</estimatedarrivaltime>
<origin xsi:type="xsd:string">KCLT</origin>
<originName xsi:type="xsd:string">Charlotte/Douglas Intl</originName>
<originCity xsi:type="xsd:string">Charlotte, NC</originCity>
</item>
<ident xsi:type="xsd:string">SKW6342</ident>
<aircrafttype xsi:type="xsd:string">E120</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">0</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254279660</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281640</estimatedarrivaltime>
<origin xsi:type="xsd:string">KLAX</origin>
<originName xsi:type="xsd:string">Los Angeles Intl</originName>
<originCity xsi:type="xsd:string">Los Angeles, CA</originCity>
</item>
<ident xsi:type="xsd:string">SWA1937</ident>
<filed_departuretime xsi:type="xsd:int">1254278760</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281820</estimatedarrivaltime>
<origin xsi:type="xsd:string">KLAS</origin>
<originName xsi:type="xsd:string">Mc Carran Intl</originName>
<originCity xsi:type="xsd:string">Las Vegas, NV</originCity>
</item>
<ident xsi:type="xsd:string">DAL1061</ident>
<actualdeparturetime xsi:type="xsd:int">1254266700</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254267000</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254282000</estimatedarrivaltime>
<origin xsi:type="xsd:string">KATL</origin>
<originName xsi:type="xsd:string">Hartsfield-Jackson Intl</originName>
<originCity xsi:type="xsd:string">Atlanta, GA</originCity>
</item>
<ident xsi:type="xsd:string">JBU411</ident>
<actualdeparturetime xsi:type="xsd:int">1254260400</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254260340</filed_departuretime>
</item>
<ident xsi:type="xsd:string">SWA94</ident>
<actualdeparturetime xsi:type="xsd:int">1254277620</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254277860</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254282120</estimatedarrivaltime>
<origin xsi:type="xsd:string">KSMF</origin>
<originName xsi:type="xsd:string">Sacramento Intl</originName>
<originCity xsi:type="xsd:string">Sacramento, CA</originCity>
</item>
<ident xsi:type="xsd:string">SWA1949</ident>
<actualdeparturetime xsi:type="xsd:int">1254277800</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254277500</filed_departuretime>
<origin xsi:type="xsd:string">KSFO</origin>
<originName xsi:type="xsd:string">San Francisco Intl</originName>
<originCity xsi:type="xsd:string">San Francisco, CA</originCity>
</item>
<ident xsi:type="xsd:string">JBU185</ident>
<actualdeparturetime xsi:type="xsd:int">1254262260</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254263220</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254282240</estimatedarrivaltime>
<origin xsi:type="xsd:string">KJFK</origin>
<originName xsi:type="xsd:string">John F Kennedy Intl</originName>
<originCity xsi:type="xsd:string">New York, NY</originCity>
</item>
</enroute>
</return>
</ns:EnrouteResponse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
mduell
September 30, 2009, 5:04am
4
Sorry, documentation error. Enroute includes all filed flights, regardless of if they’ve departed or not.
