The UAT SkyView is independent: http://pi/skyview978
(with pi being the address of your pi)
With only one dongle you can deactivate dump1090-fa if you want UAT only.
Also always good to check the serials with:
rtl_test
rtl_test
I stopped dump1090 after confirming the dongle works. Serial #s look good and I have the right url for the Skyview map.
sudo journalctl -eu dump1090-fa
sudo journalctl -eu dump978-fa
(please provide the info from those logs)
pi@Pi3Ofc:~ $ sudo journalctl -eu dump1090-fa
May 04 13:56:18 Pi3Ofc systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:56:18 Pi3Ofc systemd[1]: dump1090-fa.service: Unit entered failed state.
May 04 13:56:18 Pi3Ofc systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
May 04 13:56:26 Pi3Ofc systemd[1]: Stopped dump1090 ADS-B receiver (FlightAware customization).
May 04 13:56:26 Pi3Ofc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
May 04 13:56:26 Pi3Ofc dump1090-fa[26044]: Sat May 4 13:56:26 2019 CDT dump1090-fa 3.6.3 starting up.
May 04 13:56:26 Pi3Ofc dump1090-fa[26044]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000978)
May 04 13:56:26 Pi3Ofc systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:56:26 Pi3Ofc systemd[1]: dump1090-fa.service: Unit entered failed state.
May 04 13:56:26 Pi3Ofc systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
May 04 13:56:56 Pi3Ofc systemd[1]: dump1090-fa.service: Service hold-off time over, scheduling restart.
May 04 13:56:56 Pi3Ofc systemd[1]: Stopped dump1090 ADS-B receiver (FlightAware customization).
May 04 13:56:56 Pi3Ofc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
May 04 13:56:56 Pi3Ofc dump1090-fa[26182]: Sat May 4 13:56:56 2019 CDT dump1090-fa 3.6.3 starting up.
May 04 13:56:56 Pi3Ofc dump1090-fa[26182]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000978)
May 04 13:56:56 Pi3Ofc systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:56:56 Pi3Ofc systemd[1]: dump1090-fa.service: Unit entered failed state.
May 04 13:56:56 Pi3Ofc systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
May 04 13:57:26 Pi3Ofc systemd[1]: dump1090-fa.service: Service hold-off time over, scheduling restart.
May 04 13:57:26 Pi3Ofc systemd[1]: Stopped dump1090 ADS-B receiver (FlightAware customization).
May 04 13:57:26 Pi3Ofc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
May 04 13:57:26 Pi3Ofc dump1090-fa[26319]: Sat May 4 13:57:26 2019 CDT dump1090-fa 3.6.3 starting up.
May 04 13:57:26 Pi3Ofc dump1090-fa[26319]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000978)
May 04 13:57:26 Pi3Ofc systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:57:26 Pi3Ofc systemd[1]: dump1090-fa.service: Unit entered failed state.
May 04 13:57:26 Pi3Ofc systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
May 04 13:57:57 Pi3Ofc systemd[1]: dump1090-fa.service: Service hold-off time over, scheduling restart.
May 04 13:57:57 Pi3Ofc systemd[1]: Stopped dump1090 ADS-B receiver (FlightAware customization).
May 04 13:57:57 Pi3Ofc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
May 04 13:57:57 Pi3Ofc dump1090-fa[26466]: Sat May 4 13:57:57 2019 CDT dump1090-fa 3.6.3 starting up.
May 04 13:57:57 Pi3Ofc dump1090-fa[26466]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000978)
May 04 13:57:57 Pi3Ofc systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:57:57 Pi3Ofc systemd[1]: dump1090-fa.service: Unit entered failed state.
May 04 13:57:57 Pi3Ofc systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
May 04 13:58:27 Pi3Ofc systemd[1]: dump1090-fa.service: Service hold-off time over, scheduling restart.
May 04 13:58:27 Pi3Ofc systemd[1]: Stopped dump1090 ADS-B receiver (FlightAware customization).
May 04 13:58:27 Pi3Ofc systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
May 04 13:58:27 Pi3Ofc dump1090-fa[26613]: Sat May 4 13:58:27 2019 CDT dump1090-fa 3.6.3 starting up.
May 04 13:58:27 Pi3Ofc dump1090-fa[26613]: rtlsdr: using device #0: Generic RTL2832U OEM (Realtek, RTL2838UHIDIR, SN 00000978)
May 04 13:58:27 Pi3Ofc systemd[1]: dump1090-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:58:27 Pi3Ofc systemd[1]: dump1090-fa.service: Unit entered failed state.
May 04 13:58:27 Pi3Ofc systemd[1]: dump1090-fa.service: Failed with result ‘exit-code’.
lines 960-1001/1001 (END)
Trying to use the wrong dongle. You don’t have the serial configured correctly in /etc/default/dump1090-fa
Or are you on the sd-card install?
pi@Pi3Ofc:~ $ sudo journalctl -eu dump978-fa
May 04 13:03:45 Pi3Ofc dump978-fa[11350]: raw-port: listening for connections on [::]:30978
May 04 13:03:45 Pi3Ofc dump978-fa[11350]: json-port: listening for connections on 0.0.0.0:30979
May 04 13:03:45 Pi3Ofc dump978-fa[11350]: json-port: listening for connections on [::]:30979
May 04 13:03:45 Pi3Ofc dump978-fa[11350]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
May 04 13:03:45 Pi3Ofc dump978-fa[11350]: Detached kernel driver
May 04 13:03:46 Pi3Ofc dump978-fa[11350]: Found Rafael Micro R820T tuner
May 04 13:03:46 Pi3Ofc dump978-fa[11350]: Reattached kernel driver
May 04 13:03:46 Pi3Ofc dump978-fa[11350]: Detached kernel driver
May 04 13:03:47 Pi3Ofc dump978-fa[11350]: Exact sample rate is: 2083333.135571 Hz
May 04 13:03:47 Pi3Ofc dump978-fa[11350]: [R82XX] PLL not locked!
May 04 13:03:47 Pi3Ofc dump978-fa[11350]: SoapySDR: using maximum manual gain 49.6 dB
May 04 13:03:47 Pi3Ofc dump978-fa[11350]: SoapySDR: using stream setting buffsize=262144
May 04 13:04:15 Pi3Ofc dump978-fa[11350]: [::]:30978: accepted a connection from [::1]:42536
May 04 13:23:51 Pi3Ofc dump978-fa[11350]: Caught signal 15, exiting
May 04 13:23:51 Pi3Ofc systemd[1]: Stopping dump978 ADS-B UAT receiver…
May 04 13:23:51 Pi3Ofc dump978-fa[11350]: Reattached kernel driver
May 04 13:23:51 Pi3Ofc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 13:23:51 Pi3Ofc systemd[1]: Stopped dump978 ADS-B UAT receiver.
May 04 13:23:51 Pi3Ofc systemd[1]: dump978-fa.service: Unit entered failed state.
May 04 13:23:51 Pi3Ofc systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
May 04 13:23:51 Pi3Ofc systemd[1]: Started dump978 ADS-B UAT receiver.
May 04 13:23:51 Pi3Ofc dump978-fa[17004]: raw-port: listening for connections on 0.0.0.0:30978
May 04 13:23:51 Pi3Ofc dump978-fa[17004]: raw-port: listening for connections on [::]:30978
May 04 13:23:51 Pi3Ofc dump978-fa[17004]: json-port: listening for connections on 0.0.0.0:30979
May 04 13:23:51 Pi3Ofc dump978-fa[17004]: json-port: listening for connections on [::]:30979
May 04 13:23:51 Pi3Ofc dump978-fa[17004]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
May 04 13:23:51 Pi3Ofc dump978-fa[17004]: Detached kernel driver
May 04 13:23:52 Pi3Ofc dump978-fa[17004]: Found Rafael Micro R820T tuner
May 04 13:23:52 Pi3Ofc dump978-fa[17004]: Reattached kernel driver
May 04 13:23:52 Pi3Ofc dump978-fa[17004]: Detached kernel driver
May 04 13:23:53 Pi3Ofc dump978-fa[17004]: Found Rafael Micro R820T tuner
May 04 13:23:53 Pi3Ofc dump978-fa[17004]: Exact sample rate is: 2083333.135571 Hz
May 04 13:23:53 Pi3Ofc dump978-fa[17004]: [R82XX] PLL not locked!
May 04 13:23:53 Pi3Ofc dump978-fa[17004]: SoapySDR: using maximum manual gain 49.6 dB
May 04 13:23:53 Pi3Ofc dump978-fa[17004]: SoapySDR: using stream setting buffsize=262144
May 04 13:24:21 Pi3Ofc dump978-fa[17004]: [::]:30978: accepted a connection from [::1]:42538
May 04 14:01:53 Pi3Ofc dump978-fa[17004]: Caught signal 15, exiting
May 04 14:01:53 Pi3Ofc systemd[1]: Stopping dump978 ADS-B UAT receiver…
May 04 14:01:54 Pi3Ofc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=1/FAILURE
May 04 14:01:54 Pi3Ofc systemd[1]: Stopped dump978 ADS-B UAT receiver.
May 04 14:01:54 Pi3Ofc systemd[1]: dump978-fa.service: Unit entered failed state.
May 04 14:01:54 Pi3Ofc systemd[1]: dump978-fa.service: Failed with result ‘exit-code’.
May 04 14:01:54 Pi3Ofc systemd[1]: Started dump978 ADS-B UAT receiver.
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: raw-port: listening for connections on 0.0.0.0:30978
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: raw-port: listening for connections on [::]:30978
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: json-port: listening for connections on 0.0.0.0:30979
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: json-port: listening for connections on [::]:30979
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: Detached kernel driver
May 04 14:01:54 Pi3Ofc dump978-fa[27599]: Found Rafael Micro R820T tuner
May 04 14:01:55 Pi3Ofc dump978-fa[27599]: Reattached kernel driver
May 04 14:01:55 Pi3Ofc dump978-fa[27599]: Detached kernel driver
May 04 14:01:55 Pi3Ofc dump978-fa[27599]: Found Rafael Micro R820T tuner
May 04 14:01:55 Pi3Ofc dump978-fa[27599]: Exact sample rate is: 2083333.135571 Hz
May 04 14:01:55 Pi3Ofc dump978-fa[27599]: [R82XX] PLL not locked!
May 04 14:01:55 Pi3Ofc dump978-fa[27599]: SoapySDR: using maximum manual gain 49.6 dB
May 04 14:01:56 Pi3Ofc dump978-fa[27599]: SoapySDR: using stream setting buffsize=262144
May 04 14:02:24 Pi3Ofc dump978-fa[27599]: [::]:30978: accepted a connection from [::1]:42540
lines 171-229/229 (END)
BTW,
I have only one dongle on this pi3.
So disable dump1090-fa
sudo systemctl disable --now dump1090-fa
Might also need to set
sudo piaware-config receiver-type none
so piaware doesn’t start it.
If you can’t wait you can build and install whole piaware 3.7.1 package like this:
sudo apt install -y build-essential debhelper tcl8.6-dev autoconf python3-dev python3-venv dh-systemd libz-dev
git clone --branch dev https://github.com/flightaware/piaware_builder.git
cd piaware_builder/
./sensible-build.sh stretch
cd package-stretch
dpkg-buildpackage -b
cd ..
sudo dpkg -i piaware_3.7.1_armhf.deb
sudo reboot
But this is what I get now from piaware-status:
PiAware master process (piaware) is running with pid 563.
PiAware ADS-B client (faup1090) is running with pid 712.
PiAware ADS-B UAT client (faup978) is not running.
PiAware mlat client (fa-mlat-client) is running with pid 981.
Local ADS-B receiver (dump1090-fa) is running with pid 562.dump1090-fa (pid 562) is listening for connections on port 30005.
dump978-fa (pid 565) is listening for connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
piaware is connected to FlightAware.dump1090 is producing data on localhost:30005.
Why there is “faup978 is NOT connected to the ADS-B UAT receiver.”?
You have built and installed piware
data feeder.
Did you built and install dump978-fa
also?
What is the output of following commands?
apt-cache policy dump978-fa
apt-cache policy skyview978
Yup build both.
sudo apt install build-essential debhelper dh-systemd libboost-system-dev libboost-program-options-dev libboost-regex-dev libboost-filesystem-dev libsoapysdr-dev librtlsdr-dev pkg-config libncurses5-dev libbladerf-dev
git clone --depth 1 --branch dev https://github.com/flightaware/dump978.git
git clone --depth 1 --branch dev https://github.com/flightaware/dump1090.git
cd dump1090
cd ../dump978
sudo dpkg -i ../dump1090-fa_3.7.1_armhf.deb
sudo dpkg -i ../dump978-fa_3.7.1_armhf.deb
Both your commands say 3.7.1 installed
I had the same issue with faup978 as varnav, actually skyview978 was not working either. I had to manually install skyview978 package using dpkg. I rebuilt and reinsatalled piaware 3.7.1.
I ended up running the following commands, then faup978 started working.
sudo piaware-config uat-receiver-type sdr
sudo piaware-config rtlsdr-device-index 00001090
sudo piaware-config uat-sdr-device driver=rtlsdr,serial=00000978
I think the first line did something, I believe it told me the 2nd two were already there…
Perfect! It works now.
PiAware master process (piaware) is running with pid 645.
PiAware ADS-B client (faup1090) is running with pid 904.
PiAware ADS-B UAT client (faup978) is running with pid 914.
Local ADS-B receiver (dump1090-fa) is running with pid 644.dump1090-fa (pid 644) is listening for connections on port 30005.
dump978-fa (pid 651) is listening for connections on port 30978.
faup978 is connected to the ADS-B UAT receiver.
But it seems that dump978 is not mentioned too often here.
This is NOT a piaware SD card image. It is a package install. The command sudo piaware-config [parameter] [value]
will NOT change settings of dump1090-fa
and dump978-fa
To change the settings of dump1090-fa
, edit file:
sudo nano /etc/default/dump1090-fa
To change the settings of dump978-fa
, edit file:
sudo nano /etc/default/dump978-fa
Please see following parts of Post#15
Probably that serial part worked as I did that already. So looks like sudo piaware-config uat-receiver-type sdr
did actual magic.
Most likely you are right.
This is new stuff for us all, so we will gradually discover the fine details.
Probably best way to check if it works at all is by this command
journalctl -u piaware | grep 978
I see many
0 msgs recv’d from dump978-fa (0 in last 5m); 0 msgs sent to FlightAware
Looks like it works, but my receiver picks nothing. That’s another story, will need to play with antenna, filter, etc.
Yes, you are right. Setting uat-receiver-type sdr in piaware config tells piaware to get data from dump978-fa.
By default uat-receiver-type is set to none
, and piaware closes connection to dump978-fa.
I just set the uat-receiver-type to none, and piaware stopped receiving dump978 messages. I then set uat-receiver-type to sdr, and piaware opened connection to dump978-fa and again started receiving dump978 messages.
I have now added this command in piaware installation part of post 16.
BTW great manual you have there, just I recommend to use:
git clone --depth 1 --branch v3.7.1 https://github.com/flightaware/dump978.git
git clone --depth 1 --branch v3.7.1 https://github.com/flightaware/dump1090.git
Will be faster and no need to checkout.
