I am running PiAware (Debian Package Add-on) 3.3.0 which is running dump1090 on lighttpd. The default server with placeholder page is running on port 80 just fine. I can connect to it with its ipv4 address and ipv6 address. When I try to connect to dump1090 (on port8080) with ipv4 everything is fine, but when try the ipv6 address it gives “refused connection”. I edit the config files and ran the main server on port 8080 and dump1090 on port 80…and I still can only connect to dump1090 on ipv4…default server, now on port 8080, I can still connect on both ipv4 and ipv6 addresses.
How do I enable dump1090 to listen on the ipv6 address?
I don’t need to send updates to flightaware over ipv6…I would like the local web server to serve over ipv6. (thanks, though…googled that a lot.)
I am using the “stock” dump1090 that came with the piaware debian packages. In the upper right corner of the (local, not flightaware) server it says: FlightAware dump1090 v3.3.0
