ZMS
November 14, 2018, 11:26am
62
team - - does anybody have an idea, if/how it is possible to recalculate from hex_ICAO out of dump1090 (e.g. hex [3c6570] -->) to the aircraft type A333 … :: see: List of ICAO
would love to see the aircraft-type in my generated list - e.g. :
b.t.w.
! you have to think from “top-right” to “bottom-left”- what makes sense! this was my missinterpretation of the skript! thanks for advise once more –
ZMS
November 15, 2018, 11:33am
64
thanks TomMuc … was not able to find a basestation-DB, where i have been able to import.
e.g. https://data.flightairmap.com/
… loocks to be one of the biggest secrets in the plane-spotter scene
…as also direct DB/json exchange is not wanted/possible : only a manual synch over https://www.planespotters.net/ or http://www.airframes.org/ …
or do you have any other hint in hands?
TomMuc
November 15, 2018, 12:37pm
65
hey zms - how to install etc. i have no time at the moment to guide you. but you can send me a pm with your email and i’ll send you the latest basestation.sqb.
cheers
tom
LVONL
November 15, 2018, 10:30pm
66
Anyone who have a new radar.php for the new aircraft.json as used by dump1090-fa?
Variables in:
https://github.com/flightaware/dump1090/blob/master/net_io.c
After I updated dump to version ver 1.15~dev nothing is written to the database.
I would also like that the records will send to the database without looking at the coordinates only the altitude of the aircraft.
dump1090-fa is not dump1090-mutability.
If you need the changes just scroll up and read my conversation with ZMS it should help you.
(this is the changes to radar php you need, really you didn’t find them? Dump1090 MySQL Database Script with Alert and Filter - #56 by wiedehopf )
Anyway just use a wider net regarding the coordinates.
Use these settings to catch all airplanes
$user_set_array['max_lat'] = 90.000000; $user_set_array['min_lat'] = 0.000000; $user_set_array['max_alt'] = 80000;
$user_set_array['max_lon'] = 180.000000; $user_set_array['min_lon'] = -180.000000;
Make sure max is always bigger than min. Otherwise it won’t work.
Good luck.
LVONL
November 16, 2018, 11:11am
69
isset($row['gs']) ? $ac_speed = $row['gs'] : false;
isset($row['baro_rate']) ? $ac_vert_rate = $row['baro_rate'] : false;
isset($row['alt_baro']) ? $ac_altitude = $row['alt_baro'] : false;
Hmmm tried it, but it won’t work…
After that I tried:
foreach ($json_data_array['aircraft'] as $row) {
isset($row['hex']) ? $ac_hex = $row['hex'] : $ac_hex = '';
isset($row['flight']) ? $ac_flight = trim($row['flight']) : $ac_flight = '';
isset($row['alt_baro']) ? $ac_altitude = $row['alt_baro'] : $ac_altitude = '';
isset($row['lat']) ? $ac_lat = $row['lat'] : $ac_lat = '';
isset($row['lon']) ? $ac_lon = $row['lon'] : $ac_lon = '';
isset($row['track']) ? $ac_track = $row['track'] : $ac_track = '';
isset($row['speed']) ? $ac_speed = $row['speed'] : $ac_speed = '';
isset($row['vert_rate']) ? $ac_vert_rate = $row['vert_rate'] : $ac_vert_rate = '';
isset($row['seen_pos']) ? $ac_seen_pos = $row['seen_pos'] : $ac_seen_pos = '';
isset($row['seen']) ? $ac_seen = $row['seen'] : $ac_seen = '';
isset($row['rssi']) ? $ac_rssi = $row['rssi'] : $ac_rssi = '';
isset($row['messages']) ? $ac_messages = $row['messages'] : $ac_messages = '';
isset($row['category']) ? $ac_category = $row['category'] : $ac_category = '';
isset($row['squawk']) ? $ac_squawk = $row['squawk'] : $ac_squawk = '';
isset($row['nucp']) ? $ac_nucp = $row['nucp'] : $ac_nucp = '';
isset($row['mlat']) ? $ac_mlat = implode(' ', $row['mlat']) : $ac_mlat = '';
isset($row['tisb']) ? $ac_tisb = implode(' ', $row['tisb']) : $ac_tisb = '';
Worked when I run an echo $hex; but also no input in the database…
grrrr, can I send you my radar.php so you can check it?
script is running well but no data uploaded to the database…
pi@raspberrypi:~ $ sudo systemctl status radar.service ● radar.service - radar.php
Loaded: loaded (/etc/systemd/system/radar.service; enabled)
Active: active (running) since Fri 2018-11-16 12:10:18 CET; 4s ago
Main PID: 5609 (radar.php)
CGroup: /system.slice/radar.service
└─5609 /usr/bin/php /home/pi/radar.php
Nov 16 12:10:18 raspberrypi systemd[1]: Started radar.php.
probably you have lat and lon set wrong.
can you paste that section in here?
Also paste some output from the script when you run it.
One screen is enough.
LVONL
November 16, 2018, 8:54pm
71
I think I’ve a problem. I installed MariaDB so MYSQL is not running anymore. Could it be that?
Are you really asking if the database does not work if it’s not running?
Nice program @TomMuc
I have gone up a very steep learning curve to get to the point where “SELECT * FROM aircrafts;” gives me a table with actual data.
The next questions is based on moving from a small scale environment to collecting on going data in an ever expanding data-set
how do I run the program on the Raspi 3b so it runs at startup, and automatically thereafter.
Sorry if these are noobie questions,
TomMuc
February 8, 2019, 9:25am
74
you can autostart with cron or systemservice. all needed info you’ll find here in the forum in the several threads about the scripts.
Read the first post, the section titled
is what automatically starts the script.
So there seems to be no php5 anymore… what should the apt-get be changed to?
Using php instead of php5 should work.
pi@piaware:~ $ sudo apt-get install php-common php-cgi php-mysql php-sqlite php-curl php
Reading package lists… Done
Building dependency tree
Package php-sqlite is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘php-sqlite’ has no installation candidate
sudo apt-get install php-common php-cgi php-mysql php-sqlite3 php-curl php
do it like that
The php and sql package naming/numbering system makes their installation hard for a non-expert user.
They do indeed… thanks for the help
I noticed aircraft type isn’t in the database… can someone help me out in adding it?
