Hi! I managed to get the radar.php script logging, had to modify to use with Mictronics fork of dump1090-fa. But is it in any way possible to get it to log every plane regardless of position, even the ones not transmitting position, and without MLAT? Even better would be option to store planes within configured position AND planes anywhere below given altitude. I don’t mind if it makes the database large, I have low traffic here, and database is stored on external USB hard drive.
The script only logs what’s being read by dump1090, aircraft type is not transmitted, it’s read from external database. This script does not look up info in other places than the dump1090 JSONs.
Hello Tom,
many thanks for the great work. ac_counter runs like a charm.
one, of course stupid question
I have a problem with the radar
The insert into the db works fine, if I am manually starting it.
But when I am using systemd, I got the following error from status:
sudo systemctl status radar.service
● radar.service - radar.php
Loaded: loaded (/etc/systemd/system/radar.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Wed 2019-04-10 19:45:45 UTC; 4s ago
Process: 14857 ExecStart=/home/pi/radar.php (code=exited, status=203/EXEC)
Main PID: 14857 (code=exited, status=203/EXEC)
Apr 10 19:45:45 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 10 19:45:45 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
any idea?
many greetings from LEJ
Have you set the +x bit on radar.php? chmod +x radar.php
sudo journalctl -eu radar
should hopefully give some useful log in regards to the problem.
@Surgraph, many thanks, but I did the ```
sudo chmod 755 /home/pi/radar.php
@wiedehopf,
this brought only the information, that it starts and stops every 10 seconds ;-(
Apr 11 18:49:03 piaware systemd[1]: radar.service: Main process exited, code=exited, status=203/EXEC
Apr 11 18:49:03 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 11 18:49:03 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
Apr 11 18:49:13 piaware systemd[1]: radar.service: Service hold-off time over, scheduling restart.
Apr 11 18:49:13 piaware systemd[1]: Stopped radar.php.
Apr 11 18:49:13 piaware systemd[1]: Started radar.php.
Apr 11 18:49:13 piaware systemd[1]: radar.service: Main process exited, code=exited, status=203/EXEC
Apr 11 18:49:13 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 11 18:49:13 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
Apr 11 18:49:23 piaware systemd[1]: radar.service: Service hold-off time over, scheduling restart.
Apr 11 18:49:23 piaware systemd[1]: Stopped radar.php.
Apr 11 18:49:23 piaware systemd[1]: Started radar.php.
Apr 11 18:49:23 piaware systemd[1]: radar.service: Main process exited, code=exited, status=203/EXEC
Apr 11 18:49:23 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 11 18:49:23 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
many thanks from LEJ
Can you show me:
cat /etc/systemd/system/radar.service
sure:
[Unit]
Description=radar.php
[Service]
Restart=always
RestartSec=10
StandardOutput=/var/log/radarLog.log
StandardError=/var/log/radarError.log
[Install]
WantedBy=multi-user.target
there one sees also the 10 seconds ;-(
I added the logs, but it did not worked without them either …
Greetings from LEJ
Oh you specified log files, then the journalctl will of course show nothing
Let’s see both of them please
cat /var/log/radarError.log
cat /var/log/radarLog.log
And also:
ls -l /home/pi/radar.php
they are both not existing
I changed again to null and did run: sudo journalctl -eu radar again, which is producing the same output as the status query
greetings from LEJ
If you put it null which basically means nothing there is no log at all.
Just remove these two lines completely:
then:
sudo systemctl daemon-reload
sudo systemctl restart radar
then check the log again.
How do you start the radar.php on the command line?
What does this say?
cat /home/pi/radar.php | head
same ;-(
Apr 11 19:22:16 piaware systemd[1]: Started radar.php.
Apr 11 19:22:16 piaware systemd[1]: radar.service: Main process exited, code=exited, status=203/EXEC
Apr 11 19:22:16 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 11 19:22:16 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
Apr 11 19:22:27 piaware systemd[1]: radar.service: Service hold-off time over, scheduling restart.
Apr 11 19:22:27 piaware systemd[1]: Stopped radar.php.
Apr 11 19:22:27 piaware systemd[1]: Started radar.php.
Apr 11 19:22:27 piaware systemd[1]: radar.service: Main process exited, code=exited, status=203/EXEC
Apr 11 19:22:27 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 11 19:22:27 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
Apr 11 19:22:28 piaware systemd[1]: Stopped radar.php.
Apr 11 19:22:28 piaware systemd[1]: Started radar.php.
Apr 11 19:22:28 piaware systemd[1]: radar.service: Main process exited, code=exited, status=203/EXEC
Apr 11 19:22:28 piaware systemd[1]: radar.service: Unit entered failed state.
Apr 11 19:22:28 piaware systemd[1]: radar.service: Failed with result ‘exit-code’.
I am running the latest flightaware flash, and only installed radar and ac_counter and Mariadb, I promise ;.-)
What does this say?
and this?
which php
pi@piaware:~ $ cat /home/pi/radar.php | head
4#!/usr/bin/php
Why is there a 4 in front of the # at the beginning of the file?
Heureka
I bow to you to have spotted this, and I have no idea how this happened
I offer you a beer the next time I am in Munich
many thanks and have a nice evening from LEJ
I’m probably close to the furthest spot one could be from Munich while still being in Bavaria, but thank you i’ll raise a virtual one
If you had started it on the command line with the same command as in the service file it would have been rather obvious.
But you probably used php and gave the file as an argument, this works no matter what the first line says.
same here!
Hi
after some setup challenges i got the script working.
It’s running now for eight minutes on my device accessing the dump stream on my remote Raspberry.
This is what i get in the window where it runs:
upt(us): 0022351 - 0.971171 loops/s avg - since 0 days 00:09:15 - run 539 @ 478,1 msg/s -> 000 dataset(s) =>
Now 9 Minutes, but the database is still empty:
mysql> use adsb;
Database changed
mysql> SELECT * FROM aircrafts;
Empty set (0.00 sec)
Any ideas? There’s plenty of aircrafts visible which can be found also while accessing the aircraft.json
Additional note: I’ve read the thread again and did some tests with the hits for the user who had the same issue.
I selected all germany as Lat/Long and all filters are set to “false”.
The only thing i left alone was the alert.
But there are no errors, simply no datasets are created.
Any help would be appreciated.
