I had an issue with a a feeder. I was able to isolate it to a RadarBox1090 stick. I pulled that stick and was running 978 only using the:
sudo systemctl disable dump1090-fa
sudo systemctl disable piaware
Then when the new stick arrived I configured it and ran:
sudo systemctl start dump1090-fa
sudo systemctl start piaware
I did this through the command-line Alt-F2
Nothing…Can’t get the feeder back on 1090.
I ran rtl-eeprom and I get the correct info back.
I ran sudo rtl_test -t and it sees the stick.
I even went so far as to wipe the boot disk and installed a clean version of 8.2. When that didn’t work I downgraded to 7.0 and then upgraded through the web interface.
Either way I can’t get 1090 back all I get is:
“no ADS-B data program is serving on port 30005, not starting multilateration client yet”
Fourth. When I run the rtl_test with just the 1090 stick it says:
Found 1 device(s):
0: Generic, RTL2832U, SN: 77771111153705700
Using Device 0: Generic RTL2832U
Supported gain values (29): (Gain Values Omitted by author)
[R82xx] PLL not locked!
Sampling at 204800S/s
I have a device with the same serial number: 77771111153705700
I believe it is “test” hardware accidently sold to the public a couple years ago.
The SN cannot be changed.
The device works fine for me.
Just use the given SN to select that device.
Thanks for the help. A buddy knows how to flash eeprom chips. I have a good one from RadarBox that can be used. The problem is that both SDRs that came off of the same Pi Zero 2 W. Which makes me think something on that unit is corrupting the SDRs.
