Hi. It is cable connected, but being a Pi zero that’s via a USB ethernet adaptor that the SDR is also plugged into.
As I couldn’t get any connection, I wondered if resetting just the dongle rather than the whole device would help. I did and I could see that the Pi was doing something when plugged back in (green light flashing) and I can now SSH. So here are the logs:
pi@piaware : ~ $ sudo systemctl --no-pager status dump1090-fa
Active: active (running) since Fri 2021-06-25 09:17:41 UTC; 19min ago
Main PID: 427 (dump1090-fa)
Memory: 5.5M
└─427 /usr/bin/dump1090-fa --device-index 0 --gain -10 --ppm 0 --max…
Jun 25 09:17:41 piaware systemd[1]: Started dump1090 ADS-B receiver (Flight…on).
Jun 25 09:17:41 piaware dump1090-fa[427]: Fri Jun 25 09:17:41 2021 UTC dum… up.
Jun 25 09:17:43 piaware dump1090-fa[427]: rtlsdr: using device #0: Generic …000)
Jun 25 09:17:43 piaware dump1090-fa[427]: Detached kernel driver
Jun 25 09:17:43 piaware dump1090-fa[427]: Found Rafael Micro R820T tuner
Jun 25 09:17:43 piaware dump1090-fa[427]: rtlsdr: enabling tuner AGC
Jun 25 09:17:43 piaware dump1090-fa[427]: Allocating 4 zero-copy buffers
Hint: Some lines were ellipsized, use -l to show in full.
pi@piaware : ~ $ sudo journalctl --no-pager -n50 -u dump1090-fa
– Logs begin at Fri 2021-06-25 09:17:01 UTC, end at Fri 2021-06-25 09:42:41 UTC. –
Jun 25 09:17:41 piaware systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Jun 25 09:17:41 piaware dump1090-fa[427]: Fri Jun 25 09:17:41 2021 UTC dump1090-fa 5.0 starting up.
Jun 25 09:17:43 piaware dump1090-fa[427]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001000)
Also, without any other intervention, the open page showing the error message is now showing aircraft again. So my guess is that the problem lies with the USB / ethernet adaptor!
