I have an RPi 3B+ and an RPi 4B with nearly the same Bookworm configuration with FA Prostick Plus blue dongles. The Pi 3B+ feeder is working but the Pi 4B isn’t.
The 4B isn’t recognizing the FA Prostick Plus. It thinks it is an Airspy. I’ve moved the dongles back and forth, but the issue remains with the Pi 4B.
The following is from the Pi 4B.
lsusb output
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1d50:60a1 OpenMoko, Inc. Airspy
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
usb-devices output
T: Bus=01 Lev=02 Prnt=02 Port=01 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d50 ProdID=60a1 Rev=01.00
S: Manufacturer=www.airspy. com
S: Product=AIRSPY
S: SerialNumber=AIRSPY SN:258C62DC3168978F
C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
The systemctl status readsb output message is:
● readsb.service - readsb ADS-B receiver
Loaded: loaded (/lib/systemd/system/readsb.service; enabled; preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Sat 2025-04-05 11:51:41 EDT; 10s ago
Docs: http s://github.com/wiedehopf/readsb
Process: 34249 ExecStart=/usr/bin/readsb $RECEIVER_OPTIONS $DECODER_OPTIONS $NET_OPTIONS $JSON_OPTIONS --write-json /run/readsb --quiet (code=exited, status=1/FAILURE)
Main PID: 34249 (code=exited, status=1/FAILURE)
CPU: 52ms
Any help is greatly appreciated.
