Now, it seems, the PSP is non-responsive, and knocks out the wifi dongle as well. The system will boot and connect to flightaware.com w/o the PSP attached, but not with. Same results whether I (1) plug the PSP directly into the pi USB and the wifi into the 2nd hub, (2) plug both the PSP and wifi into the pi USB, (3) use a 3a PSU on the pi, (4) set max_usb_current=1 in the pi’s /boot/config.txt, (5) boot w/ latest Piaware OS build, (6) replace the wifi dongle with another.
W/o the PSP attached, Piaware status yields:
PiAware master process (piaware) is running with pid 472.
PiAware ADS-B client (faup1090) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for connections on port 30005.
got ‘couldn’t open socket: connection refused’
UPDATE: Tried one more thing: with the Pro Stick Plus plugged directly into the pi, and no other devices, I’ve connected to the LAN via a cable. After a reboot, Piaware status yields:
PiAware master process (piaware) is running with pid 457.
PiAware ADS-B client (faup1090) is running with pid 565.
PiAware mlat client (fa-mlat-client) is running with pid 934.
Local ADS-B receiver (dump1090-fa) is running with pid 456.
dump1090-fa (pid 456) is listening for connections on port 30005.
But lsusb (thank you david.baker) shows no receiver:
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And there’s no data, no planes detected. Station is 12 miles from major international airport.
Thank you, David. Seems the on-board USB repeatedly finds the PSP but can’t use it. dmesg excerpt below:
[ 187.816772] usb 1-1-port2: over-current change
[ 188.356054] usb 1-1.5: new high-speed USB device number 127 using dwc_otg
[ 188.497980] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=2832
[ 188.497997] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 188.498009] usb 1-1.5: Product: RTL2832U
[ 188.498018] usb 1-1.5: Manufacturer: Realtek
[ 188.498029] usb 1-1.5: SerialNumber: 00001000
[ 188.506245] usb 1-1.5: dvb_usb_v2: found a ‘Realtek RTL2832U reference design’ in warm state
[ 188.540766] dvb_usb_rtl28xxu: probe of 1-1.5:1.0 failed with error -71
[ 188.541518] usb 1-1.5: USB disconnect, device number 127
[ 188.736388] usb 1-1-port2: over-current change
[ 189.926673] usb 1-1-port2: over-current change
[ 190.466024] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
[ 190.603950] usb 1-1.5: New USB device found, idVendor=0bda, idProduct=2832
[ 190.603970] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 190.604932] usb 1-1.5: can’t set config #1, error -71
[ 190.682998] usb 1-1-port2: over-current change
[ 190.916348] usb 1-1.5: USB disconnect, device number 5
Definitely power related, but given that you’ve swapped out the PSU and tried different hub setups etc it’s probably the dongle at fault. I’d RMA it.
Possibly unrelated (maybe you were trying this on a vanilla Raspbian?) but that driver should be blacklisted if you want to use the rtlsdr in SDR mode for dump1090 et al.
