Weatherproof junction box (to house the RTL-SDR LNA)
a few ft (or what is needed to get to junction box) of coax with N-connector (antenna) and SMA-(male) BEWARE: not RP-SMA). something like this or this.
You could always power the bias-t from the usb socket on your raspberry pi. The USB port provides 5v. Usb cables are cheap, just cut one to the appropriate length and solder the power wires to the bias-t. (This is what I have done).
No, that is not a problem. The power supply rating of 2 amps is its maximum output current but the LNA will not draw more than the 0.5A rating of the bias-t. The power supply will not force current into the LNA because it is rated at 2A. The LNA will just draw what it needs.
I would not recommend this one if you have zero to none experience with soldering electronics (I presume you don’t). The inserter @abcd567 uses perhaps looks a little less fancy without the casing, but it is much easier to install. If you don’t like the esthetics, there are probably seperate casing available for it.
As @LawrenceHill mentioned, instead of buying an extra power supply you can use an USB-cable. You can strip an USB cable from an old keyboard, mouse, extension cable, etc.
There are four wires inside an USB cable; in general the colours used are Red, Black, White and Green.
Cut the white and green cables, they are for data. The power cables are red (+, VCC, positive) and black (-, GND, ground, negative), connect them accordingly to the terminal of the Bias Tee inserter (aka power inserter, biaser) and plug in the USB cable to an empty USB socket of the Pi.
Rats. I thought it was just a plug and play. I thought the power connection was one that was plugged into a DC adapter. I’ve soldered before, but its been a long time and I wouldn’t call myself experienced. I think this thread has shown that while it’s possible, I think my inexperience isn’t doing me any favors. Getting my pilot’s license was easier than this! One thing I have learned though, keep your cable runs short!!!
None of the two have integral amplifier or filter.
Both these are Generic DVB-T with enhanced temprature stability + Bias-T
The “Triple filter LNA” will be sufficient to do both the the jobs of amplifying & filtering.
I have run a scan of a Generic DVB-T alone, then same DVB-T fitted with RTL-SDR Triple Filter LNA. (Both scans with dipole antenna inside the room, Gain setting 49.6 dB, scan range 24 MHz ~ 1800 MHz)
Generic DVB-T (No internal/external Filter or Amplifier)
I am not sure if RTL-SDR Triple Filter LNA passes dc to antenna port. Some one who has checked this can tell.
In case the LNA passes dc to antenna port, then while selecting an antenna, select one that does not have a dc short. In case you select an antenna with dc short, add a dc blocking capacitor between LNA and antenna.
