First thing’s first, if you’re not saving your data to a CSV file then you’re not going to be able to generate anything
. I used vbscript to capture and store the data to a CSV file and decided to change it over to Python. Everything I’ve done is with Python 2.7. Comments are in the code if you want to use Python 3.4. Don’t ask me how to setup Python or Pyspark, there are resources that you can google to figure this out though installing Apache Spark/pyspark is a bit of a pain. Apache Spark/pyspark is what will be required for creating the KML files.
So what the below will do is capture everything that is on my ADSB receiver at 192.168.10.58. The line with url=, change this to your URL. The line with fileName, change the T:/TEMP to the folder where you want to save your CSV files. Note that the CSV files are named based on UTC date, so for example, dump1090_2017-01-30.csv.
Just run the script from a laptop and have the data saved locally to the laptop or to a network drive.
#import urllib.request #for Python 3.4
import urllib2 #for Python 2.7
import json
import os
import time
from time import gmtime, strftime
from datetime import datetime
# change the below to your receiver IP address
url = 'http://192.168.10.58/dump1090/data/aircraft.json'
headers = {'Cache-Control':'no-cache','Pragma':'no-cache','If-Modified-Since':'Sat, 1 Jan 2000 00:00:00 GMT',}
while 1:
#Python 3.4
#request=urllib.request.Request(url, None, headers)
#response = urllib.request.urlopen(request)
#Python 2.7
request=urllib2.Request(url, None, headers)
response = urllib2.urlopen(request)
data = response.read().decode('utf8')
jsonPlane = json.loads(data)
# change the below to the folder you want to save the CSV files, filenames format is dump1090_YYYY-MM-DD.csv
fileName = 't:/temp/dump1090_'+datetime.utcnow().strftime("%Y-%m-%d")+'.csv'
if os.path.isfile(fileName):
ADSBFile = open(fileName, 'a')
else:
ADSBFile = open(fileName, 'w')
ADSBFile.write('UTC,ICAO,flight,spd,lat,lon,altitude,mlat
for plane in jsonPlane'aircraft']:
resultStr = datetime.utcnow().strftime("%Y-%m-%d %H:%M:%S") + ','
if int(plane'seen']) <= 1:
if 'seen_pos' in plane:
if 'hex' in plane:
resultStr = resultStr +str(plane'hex']) + ','
else:
resultStr = ','
if 'flight' in plane:
resultStr = resultStr + str(plane'flight']).strip() + ','
else:
resultStr = resultStr + ','
if 'speed' in plane:
resultStr = resultStr + str(plane'speed']) + ','
else:
if 'lat' in plane:
resultStr = resultStr + str(plane'lat']) + ','
else:
if 'lon' in plane:
resultStr = resultStr + str(plane'lon']) + ','
else:
resultStr = resultStr +','
if 'altitude' in plane:
resultStr = resultStr + str(plane'altitude']) + ','
else:
if 'mlat' in plane:
resultStr = resultStr + 'True'
else:
resultStr = resultStr + 'False'
#write results to a file
ADSBFile.write(resultStr+'
print (resultStr)
ADSBFile.close()
time.sleep(1)
The contents of the CSV will be something like this:
UTC,icao,flight,spd,lat,lon,altitude,mlat
2017-01-30 03:58:00,ad2c19,AAL1360,479,42.410392,-80.064335,37000,False
2017-01-30 03:58:00,0c20a6,CMP470,413,42.646086,-79.040499,25475,False
2017-01-30 03:58:00,c013de,,492,45.459983,-81.852633,37025,True
2017-01-30 03:58:00,c04602,ANT511,453,46.588303,-78.498118,37000,False
2017-01-30 03:58:00,ac0417,ASH6101,472,43.187714,-81.081273,28875,False
2017-01-30 03:58:00,a60c7a,4104,463,42.726901,-79.686712,31700,True
2017-01-30 03:58:00,c04829,,318,43.461914,-79.463,9525,True
2017-01-30 03:58:00,c05d43,,179,44.010113,-79.70993,8800,True
2017-01-30 03:58:00,a836fb,UAL391,344,43.52178,-80.147029,14175,False
2017-01-30 03:58:00,c05ead,,282,44.078219,-80.3765,17725,True
2017-01-30 03:58:00,c00f7d,,202,43.754309,-79.404471,3250,True
2017-01-30 03:58:00,4ba95a,THY18A,491,43.703659,-78.226361,26650,False
2017-01-30 03:58:00,a88700,,441,43.943916,-81.547525,36125,True
2017-01-30 03:58:00,c028cd,WJA675,437,44.36142,-81.45316,33850,False
2017-01-30 03:58:00,c00b7d,SKV7668,291,43.665208,-79.579402,5675,True
2017-01-30 03:58:00,c080ac,WJA725,441,44.362152,-81.641759,32325,False
2017-01-30 03:58:00,c05bd2,ACA140,224,43.840104,-79.578683,4200,True
2017-01-30 03:58:00,c00b7c,SKV7598,485,44.212383,-78.037094,37000,True
You could put this into a mysql if you want, but I don’t so not sure how to get pyspark to pull the data from a db but pretty sure that is possible.
I’ll followup sometime this week with the code to analyze the CSV to generate the KML files.
