@psionmark So if you haven’t bought a second pi yet, there is a way to make this work:
After installing pihole:
Use an editor to open /etc/lighttpd/external.conf
You could use the following command:
sudo nano /etc/lighttpd/external.conf
Now copy and paste the following:
#this should go into /etc/lighttpd/external.conf
server.modules += (
"mod_alias"
# Listen on port 8080 and serve the map there, too.
$SERVER["socket"] == ":8080" {
alias.url += (
"/dump1090-fa/data/" => "/run/dump1090-fa/",
"/dump1090-fa/" => "/usr/share/dump1090-fa/html/",
"/data/" => "/run/dump1090-fa/",
"/" => "/usr/share/dump1090-fa/html/"
url.redirect += (
"^/dump1090-fa$" => "/dump1090-fa/"
Press CTRL-o and ENTER to save
Press CTRL-x to exit
Restart lighttpd:
service lighttpd force-reload
Now it should be all running (theoretically)
This will host dump1090 webview on the port 8080, so you will have to use 192.168.1.123:8080 or whatever the rpi ip is to access it.
Edit: one test has been successful with a modification incorporated in this post (mod_alias was missing)
