sileck
July 20, 2019, 5:02pm
1
Hi guys,
I am completely new to tracking with an ADS-B receiver.
To run a project, I need the aircraft.json file. Unfortunately I cannot find this file. I do run a raspberry pi with dump1090, which has been already installed. I do not feed any flight tracking website with my received ADS-B data.
As far as I know, the file should be located at /var/run/dump1090-fa/
It happens that there is no such folder…
The address :8080/data/aircraft.json doesn’t help either.
Do I have to configure the program dump1090 to create this file? Or do you have any other idea, how I can find the aircraft.json file?
Thank you very much in advance.
sileck
July 20, 2019, 6:22pm
3
I use dump1090. It was already installed on the device. My professor borrowed me the Pi.
There is no data folder…
Only the following folders are included in the dump1090 folder:
.git
-pthreads
-public_html
-rtlsdr
-testfiles
-tools
Maybe I should reinstall the program…
The problem is that you are using a different version of the program.
git remote -v
This will tell you which program is being used.
Have you checked these folders:
/run/dump1090
/run/dump1090-mutability
You can also check the command line, post the output of this:
pgrep -a dump1090
Somewhere in that output should be an argument named --json-dir, this is where the aircraft.json will be.
sileck
July 20, 2019, 6:49pm
5
first of all, thank you for your help
I think, I have a bigger problem…
fatal: no git-repository
I don’t have these folders…
There is only a file “dump1090.pid” in the run folder, nothing else which refers to dump1090
wiedehopf:
pgrep -a dump1090
Somewhere in that output should be an argument named --json-dir , this is where the aircraft.json will be.
Outcome:
314 ./dump1090 --quite --gain -10 --net --net-beast
Do you have another sd-card?
Put the piaware sd-card image on it if you don’t need the specific dump1090 version provided on the RPi.
Alternatively you can change the command line parameters and add --json-dir if that dump1090 version supports it.
dump1090 --help should give you the options.
sileck
July 21, 2019, 9:13am
7
That seems to be the problem. json is not supported. --help shows no options for implementing --json. Adding it manually doesn’t work.
I’ll try another SD card with dump1090-fa this evening. Or I speak to my professor this week to deinstall the current version and install dump1090-fa.
caius
July 21, 2019, 11:48am
8
Sounds like a very old version of dump1090. I think it use to use a file called data.json and aircraft.json was added later.
sileck
July 26, 2019, 12:57pm
9
Got it. Indeed, it was an old version. Got dump109-fa now and it works
thank you everybody
